looking at documentation, I realized that I can not find information about dwords and parameters.
all I found is open-gpu-kernel-modules/nvrm_registry.h at main · NVIDIA/open-gpu-kernel-modules · GitHub
so i have a couple of questions
- Are there any documentation for dwords and parameters?
- my “friend” says that he has documentation for all dwords and parameters
as proof he threw off the screenshots
and this
"PS_LOADBALANCE_MODE" =>
type => $type_int,
desc => "",
enums => [ "FORCE_CPU_LIMITED", "FORCE_ALWAYS_OFF", "FORCE_GPU_LIMITED", "FORCE_ALWAYS_ON", "FORCE_LOADBALANCE", "FORCE_LB", "FORCE_ALTERNATE", "FORCE_ALTERNATE_EACH_DECISION", "FORCE_HIGH_FREQUENCY_MODE", ],
values => { "FORCE_ALTERNATE" => 0x00000003, "FORCE_ALTERNATE_EACH_DECISION" => 0x00000004, "FORCE_ALWAYS_OFF" => 0x00000000, "FORCE_ALWAYS_ON" => 0x00000001, "FORCE_CPU_LIMITED" => 0x00000000, "FORCE_GPU_LIMITED" => 0x00000001, "FORCE_HIGH_FREQUENCY_MODE" => 0x00000005, "FORCE_LB" => 0x00000002, "FORCE_LOADBALANCE" => 0x00000002, },
PS_FRAMERATE_LOGGER" => {
type => $type_int,
desc => “FPS overlay and simple text logging”,
enums => [ “DISABLED”, “DISPLAY”, “LOGTOFILE”, “LOGTOETW”, “ALLOWDWM”, ],
values => { “ALLOWDWM” => 0x00000008, “DISABLED” => 0x00000000, “DISPLAY” => 0x00000001, “LOGTOETW” => 0x00000004, “LOGTOFILE” => 0x00000002, },
“LATENCY” => {
type => $type_int,
desc => "Reduces latency by limiting the number of frames the CPU can prepare before the frames are processed by the GPU. It also determines how multiple CPU-cores are used by the driver ",
enums => [ “BEST_PERFORMANCE”, “LOW_LATENCY”, “LOWEST_LATENCY”, ],
values => { “BEST_PERFORMANCE” => 0x0, “LOWEST_LATENCY” => 0x2, “LOW_LATENCY” => 0x1, },
type => $type_bool,
desc => “Allow DWM to use low latency node”,
enums => [ “OFF”, “0”, “FALSE”, “DISABLED”, “ON”, “1”, “TRUE”, “ENABLED”, ],
values => { “0” => 0x00000000, “1” => 0x00000001, “DISABLED” => 0x00000000, “ENABLED” => 0x00000001, “FALSE” => 0x00000000, “OFF” => 0x00000000, “ON” => 0x00000001, “TRUE” => 0x00000001, },
now the question where did he get it from?
