I have a problem with a mac pro with mac osX 10.5.8. I define the DYLD_LIBRARY_PATH variable in the /etc/launchd.conf file. The root account has the environnement variable set at startup, but not others users.
I don’t understand why it doesn’t work on others account (admin or not) because I test the same file on 2 mac minis and it works fine.
And I precise that only this variable (the last in the launchd.conf file) is not set. PATH variable and others are set.
To finish, there is no .bash_profile file on all account.
If you have any ideas…
Thanks a lot.
Thanks a lot.
I have kind of same problem.
I tried to execute the two commands:
export PATH=/usr/local/cuda/bin:$PATH
export DYLD_LIBRARY_PATH=/usr/local/cuda/lib:$DYLD_LIBRARY_PATH
they didn’t give any error, but when I try to execute the samples all i got is:
dyld: Library not loaded: @rpath/libcupti.dylib
Referenced from: /Developer/GPU Computing/C/CUDAToolsSDK/CUPTI/sample/cupti_query/./cupti_query
Reason: image not found
Trace/BPT trap
I don’t now how to fix it. Anyone knows?
Marco
I just solved, I copied the libcupti.dylib in /usr/local/cuda/lib directory,
Marco
