Description
The dynamic batch dimension should be -1 in TensorRT.
Environment
TensorRT Version: 8.0.1.6
Relevant Files
I convert the retinaface (Pytorch_Retinaface/convert_to_onnx.py at master · biubug6/Pytorch_Retinaface · GitHub) to onnx with dynamic axes
Steps To Reproduce
- Add dynamic axes in onnx
dynamic_ax = {'input': {0:'batch', 2: 'image_height', 3: 'image_width'}, 'output_1': {1: 'total_anchors_1'}, 'output_2': {1: 'total_anchors_2'}, 'output_3': {1: 'total_anchors_3'}}
# dynamic_ax = {'input': {0: 'batch'}}
input_names = ["input"]
output_names = ["output_1", "output_2", "output_3"]
inputs = torch.randn(1, 3, args.long_side, args.long_side).to(device)
torch_out = torch.onnx._export(net, inputs, output_onnx, export_params=True, verbose=False,
input_names=input_names, output_names=output_names, dynamic_axes = dynamic_ax, opset_version=11)
- Convert onnx to tensorrt
Here is the head of the log
[TensorRT] VERBOSE: Adding network input: input with dtype: float32, dimensions: (-1, 3, -1, -1)
[TensorRT] VERBOSE: Registering tensor: input for ONNX tensor: input
log.txt (848.4 KB)
using tensorrt api,
engine_bytes = open(weight, 'rb').read()
# with trt.Logger() as logger, trt.Runtime(logger) as runtime:
with trt.Runtime(logger) as runtime:
self._engine = runtime.deserialize_cuda_engine(engine_bytes)
assert(self._engine)
self.input_shapes = []
for binding in self._engine:
if self.engine.binding_is_input(binding):
shape = tuple(self.engine.get_binding_shape(binding))
print(shape)
self.input_shapes.append(shape)
the shape is still (1,3,-1,-1), but the expected input shape should be (-1,3,-1-1)
Any idea?
Here is onnx FaceDetector.onnx (1.7 MB)
