Dynamic creation of nvstreamdemux and linking to SRC pads
• Hardware Platform (Jetson / GPU) Laptop with NVIDIA GPU RTX 4060
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version Driver Version: 550.107.02 CUDA Version: 12.4
• Issue Type Questions
Greetings.
There is a pipeline that looks as follows:
multiurisrcbin --> queue --> nvinfer1 --> nvinfer2 --> queue --> tracker --> tee --> tiler --> queue --> videoconvert --> capsfilter --> queue --> osd --> eglglessink
There is some logic that is executed inside the tracker’s probe SRC pad that generates output for each of the sources, and also generates some output for the osd element.
There is a need to start recording one of the active batched streams to a file at a certain moment and then stop it at a certain moment. At the same time, the recording to file should include graph overlays by osd element, but of course without including tiler in the output file (since we record only one stream). Also, there is a need to take periodic screenshots with the same conditions.
To solve this task, I went the following way: when I receive a message on the bus with the string “stream-add”/“stream-remove” in the structure name, I dynamically add/remove an additional branch (of course, doing it from the main thread), which I link to the tee element of the main pipeline. Here is what the dynamic branch looks like:
tee |-> nvstreamdemux --> queue --> videoconvert --> queue --> osd --> tee --> fakesink
Also, there can be many such branches, depending on the number of active sources limited by batch-size.
In my case, a separate nvstreamdemux is used for each new branch, because when using a single nvstreamdemux for all branches, I encountered a problem where new connection to the SRC pad of the nvstreamdemux can only be made when this element is in NULL state. In my case, for example, if I already have an active stream running through nvstreamdemux, then when linking a new branch I will have to set nvstreamdemux to NULL, which will affect existing streams.
On the osd element of the dynamic branch, I have a probe on the SRC pad, from which I perform a screenshot save to a file using the nvds_obj_encode API if necessary.
Then, when needed to start recording, I dynamically create a new branch that looks like this and links to the output SRC pad of the tee element of the dynamic branch created for a particular source:
tee |-> queue --> videoconvert --> v4l2h264enc --> h264parse --> qtmux --> filesink
There are two problems I’ve encountered:
  1. The above pipeline logic works (adds and removes dynamic branches correctly) as long as I have one source. When I add a second or more sources, I stop getting data on the SRC pad of nvstreamdemux for each new branch. That is, when I set up probes on the SINK and SRC pads of nvstreamdemux for each item, I see output in the console like this:
[STREAM:0] Got on demux SINK pad! Frame source_id: 0
[STREAM:0] Got on demux SINK pad! Frame source_id: 1
[STREAM:0] Got on demux SRC pad!  Frame source_id: 0
[STREAM:1] Got on demux SINK pad! Frame source_id: 0
[STREAM:1] Got on demux SINK pad! Frame source_id: 1
That is, here you can see how frames from both sources are received by the SINK pads of both elements (nvstreamdemux), but at the same time you can see that the SRC pads only generate data for the first source (number 0). Of course, this behavior makes the whole branch inoperable.
Does anyone have positive experience in the context of trying nvstreamdemux to solve this kind of tasks?
What could be the problem in my case?
I will be glad to get any ideas/advice.
Unfortunately, I can’t share the entire source code, however I can do so for specific sections of code if needed.
For a more detailed understanding, I attach the pipeline graph during two active sources and active recording on one of them.
0.00.17.679427233-deepstream-pipeline-graph-new.dot.txt (97.3 KB)
  1. Also, there is a strange problem of osd elements conflicting during recording/capturing screenshots, and I can’t understand the reason for this behavior.
    As you can see from the video, the frame shows those overlaps that are formed after tiler and osd elements of the main branch of the batched stream. At the same time, no overlaps occur on the osd that is after the tiler (in the main branch).
    If anyone has any ideas about this?
For the recording. nvmultistreamtiler support to choose single source output by setting “show-source” property in runtime. Smart recording support start and stop recording by APIs. Smart Video Record — DeepStream documentation 6.4 documentation.
For the display overlap issue, it is caused by your “tee” after the nvinfer and before tiler or nvstreamdemux. The “tee” will clone batch meta into every branch, so all the branches share the same batch meta. any change to the batch meta in any branch will be reflected in other branches. Please do not use “tee” before nvmultistreamtiler or nvstreamdemux.
Thank you for your reply, Fiona.
  1. Do I understand correctly that by using the “show-source” property of nvmultistreamtiler, I can only record from one source at a time? If so, then the logic of my specification is precisely to implement the ability to record each source independently.
    Smart Video Record will not give advantages in this case either, because I will have to allocate branches dynamically for it as well.
    Is there any way I can realize recording of several batched streams simultaneously in runtime?
  2. I absolutely agree with you about the logic of tee operation. Knowing its behavior, I added a separate nvstreamdemux to each new branch after tee, which should perform the function of demulteplexing the batched stream, including metadata separation, as it is said in the documentation.
    Could you please help me understand what my misconceptions are?
The second issue may be avoid by adding the nvvideoconvert with “disable-passthrough=1” property setting.
E.G.
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! mux.sink_0 nvstreammux name=mux batch-size=2 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! tee name=t t.src_0 ! queue ! nvvideoconvert disable-passthrough=1 ! nvmultistreamtiler columns=2 rows=1 width=1920 height=1080 ! nvdsosd ! fakesink sync=0  uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4 ! mux.sink_1 t.src_1 ! queue ! nvvideoconvert disable-passthrough=1 ! nvstreamdemux name=dex0 dex0.src_0 ! nvvideoconvert ! nvdsosd ! nveglglessink t.src_2 ! queue ! nvvideoconvert disable-passthrough=1 ! fakesink sync=0
