I was trying to use the new dynamic input shapes introduced by TensorRT 6. However during the engine creation a error occurred. My logger says “ERROR: C:\source\rtSafe\cuda\caskConvolutionRunner.cpp (62) - Cask Error in nvinfer1::rt::task::CaskConvolutionRunner::createConvolution: 3 (isConsistent)”. I think this error is caused by a combination of using kSame padding with a stride size of more than one. Below I have a minimal code example which leads to the error.
#include <NvInfer.h>
#include <iostream>
#include <vector>
using namespace std;
using namespace nvinfer1;
class StdOutLogger : public ILogger
public:
StdOutLogger(ILogger::Severity severity)
: mReportedSeverity(severity)
void log(ILogger::Severity severity, char const* message) override
if (severity > mReportedSeverity)
return;
switch (severity)
case Severity::kINTERNAL_ERROR: std::cerr << "INTERNAL_ERROR: "; break;
case Severity::kERROR: std::cerr << "ERROR: "; break;
case Severity::kWARNING: std::cerr << "WARNING: "; break;
case Severity::kINFO: std::cerr << "INFO: "; break;
default: std::cerr << "UNKNOWN: "; break;
std::cerr << message << std::endl;
private:
ILogger::Severity mReportedSeverity;
Weights getKernelWeights()
Weights weights;
weights.count = 18;
weights.type = DataType::kFLOAT;
vector<float> values{ 1.f, 2.f, 3.f, 4.f, 5.f, 6.f, 7.f, 8.f, 9.f, 10.f, 11.f, 12.f, 13.f, 14.f, 15.f, 16.f, 17.f, 18.f };
weights.values = values.data();
return weights;
Weights getBiasWeights()
Weights weights;
weights.count = 2;
vector<float> values{ -1.f, -2.f };
return weights;
int main()
StdOutLogger logger(ILogger::Severity::kINFO);
auto builder = createInferBuilder(logger);
auto network = builder->createNetworkV2(1U << static_cast<size_t>(NetworkDefinitionCreationFlag::kEXPLICIT_BATCH));
auto convKernelWeights = getKernelWeights();
auto convBiasWeights = getBiasWeights();
auto input = network->addInput("input", DataType::kFLOAT, Dims4{ 1, 1, -1, -1 });
auto conv = network->addConvolution(*input, 2, DimsHW{ 3, 3 }, convKernelWeights, convBiasWeights);
// here the error occurs, without padding everything works fine
conv->setPaddingMode(PaddingMode::kSAME_LOWER);
// however if I change the strides to (1, 1) it works with the padding
conv->setStride(DimsHW{ 2, 2 });
network->markOutput(*conv->getOutput(0));
auto profile = builder->createOptimizationProfile();
profile->setDimensions("input", OptProfileSelector::kMIN, Dims4{ 1, 1, 64, 64 });
profile->setDimensions("input", OptProfileSelector::kOPT, Dims4{ 1, 1, 128, 128 });
profile->setDimensions("input", OptProfileSelector::kMAX, Dims4{ 1, 1, 256, 256 });
auto config = builder->createBuilderConfig();
config->addOptimizationProfile(profile);
auto engine = builder->buildEngineWithConfig(*network, *config);
engine->destroy();
config->destroy();
builder->destroy();
return 0;
So again the error is ERROR: C:\source\rtSafe\cuda\caskConvolutionRunner.cpp (62) - Cask Error in nvinfer1::rt::task::CaskConvolutionRunner::createConvolution: 3 (isConsistent)
Thank you in advance.
