dynamic nvarguscamerasrc + nvcompositor == Failed to create CaptureSession
Can anyone help me figure this out?
I am trying to dynamically (in 3 sec after pipeline start) connect nvarguscamerasrc to nvcompositor but i get
and
Error AlreadyAllocated: Device 0 (of 1) is in use
in nvargus-daemon logs and of course no camera image is shown.
At the same time when I’m trying to dynamically connect a usb camera (via v4l2src) it works fine
Also when I am connecting camera to compositor statically it works on both v4l2src and/or nvarguscamerasrc
JetPack 4.3
GStreamer 1.14.5
Jetson Nano
Raspberry Pi Camera V2 IMX219
The minimal script to reproduce the problem is here
https://gist.github.com/zhuker/dfaddd22f6acd6aa410f500cbc72fecc
run script to reproduce:
GST_DEBUG=2 python3 nvargusbug.py
to change to usb camera to see it works set
camera_desc = usb_camera
nvarguscamerasrc doesnt work:
nvarguscamerasrc name=front do-timestamp=true silent=false
    ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=30/1
    ! nvvidconv
    ! queue
v4l2src works:
v4l2src device=/dev/video1 do-timestamp=true name=front
    ! image/jpeg,width=1280,height=720,framerate=30/1
    ! jpegdec
    ! videoconvert
    ! nvvidconv
    ! queue
nvcompositor pipeline
nvcompositor name=comp
    sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1280 sink_0::height=1080
    sink_1::xpos=0 sink_1::ypos=0 sink_1::width=1280 sink_1::height=720
    videotestsrc is-live=true do-timestamp=true name=background !
        video/x-raw,width=320,height=180,framerate=30/1 !
        nvvidconv !
        comp.sink_0
    comp. ! nvegltransform ! nveglglessink
reproduce script output
Using winsys: x11
11:23:52.219097 MainThread connecting front camera
11:23:52.224443 MainThread _pad_added comp sink_1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 4
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=6048000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Acquired Frame. 1828717638
CONSUMER: Acquired Frame: 1, time 489755328562000
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:543 Failed to create CaptureSession
CONSUMER: Acquired Frame: 2, time 489755361599000
CONSUMER: Acquired Frame: 3, time 489755394972000
CONSUMER: Acquired Frame: 4, time 489755428255000
nvargus-daemon log
=== python3[20924]: CameraProvider initialized (0x7f74a97050)LSC: LSC surface is not based on full res!
(Argus) Error AlreadyAllocated: Device 0 (of 1) is in use (in src/api/CameraProviderImpl.cpp, function createCaptureSession(), line 232)
reproduce script
import datetime
import threading
import traceback
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject, GLib
def debug(*args) -> None:
    print(datetime.datetime.now().time().isoformat(), threading.current_thread().name, *args)
# doesnt work
mipi_camera = '''nvarguscamerasrc name=front do-timestamp=true silent=false
    ! nvvidconv
    ! queue
# works
usb_camera = '''
    ! jpegdec
    ! videoconvert
    ! nvvidconv
    ! queue
pipeline_desc = f'''
        nvvidconv !
        comp.sink_0
# works
# doesnt work
camera_desc = mipi_camera
Gst.init(None)
pipe = Gst.parse_launch(pipeline_desc)
bus = pipe.get_bus()
comp = pipe.get_by_name('comp')
def _pad_added(element, pad):
    debug('_pad_added', element.name, pad.name)
    srcbin = Gst.parse_bin_from_description(camera_desc, True)
    static_pad = srcbin.get_static_pad('src')
    pipe.add(srcbin)
    pipe.sync_children_states()
    static_pad.link(pad)
comp.connect('pad-added', _pad_added)
pipe.set_state(Gst.State.PLAYING)
def connect_front():
    debug("connecting front camera")
    comp.get_request_pad('sink_1')
gloop = GObject.MainLoop()
GLib.timeout_add(3000, connect_front)
try:
    gloop.run()
except:
    traceback.print_exc()
    pipe.send_event(Gst.Event.new_eos())
    keep_polling = True
    while keep_polling:
        message = bus.poll(Gst.MessageType.ANY, 1005000000)
        debug(message)
        keep_polling = message is not None
    pipe.set_state(Gst.State.NULL)
Could you check if it works in gst-launch-1.0 command? Would like to know if it is specific to running python code. Not sure but it looks like you have to specifiy format=I420(or NV12) in sinkpad of nvcompositor.
Thats the point
static gst-launch pipeline works with exactly the caps as specified
but when i want to add camera dynamically (via python) it errors out
Pretty sure when caps get reconfigured camera is opened the second time
Have a reference to below link that was verified without problem.
https://gist.github.com/jkjung-avt/86b60a7723b97da19f7bfa3cb7d2690e
