Does the tx2 support dynamic parallelism?
Do you indicate the dynamic parallelism mentioned in the below talk?
This feature is supported from the Kepler (3.x) GPU.
TX2 uses Pascal (6.2) architecture already.
Yes that is the dynamic parallelism i was referring to.
I was not certain if I can use it in the jetson tx2. But I saw multiple examples
that did so. So the answer is yes, we can use dynamic parallelism on jetson tx2 .
Thank you for the reply!
