Dynamic Pipelines gstinterpipes: Failed to obtain an intersection between upstream elements and listeners
• Jetson AGX Xavier
• DeepStream 5.0
• JetPack 4.6
• TensorRT 8
• CUDA 10.2
• Issue Type: Question/Bug
I have built a Deepstream pipeline making use of Ridgerun’s interpipes to isolate my pipelines. The pipelines look as follows:
TestSourcePipeline1:
videotestsrc --> overlay --> nvvideoconvert --> capsfilter "video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12"--> interpipesink
TestSourcePipeline2:
RtspCapturePipeline:
uridecodebin --> nvvideoconvert --> capsfilter "video/x-raw(memory:NVMM),format=(string)NV12,width=1280,height=720" --> interpipesink
ReceivePipline1:
 interpipesrc --> nvvideoconvert --> capsfilter --> "video/x-raw(memory:NVMM),format=(string)NV12,width=1280,height=720" --> interpipesink
ReceivePipline2:
OpticalFlowPipeline:
 nvstreammux --> nvof --> probe -->fakesink
on startup the whole pipeline looks like this:
RtspCapturePipeline <--> ReceivePipline1 <-
                                           => OpticalFlowPipeline
TestSourcePipeline2 <--> ReceivePipline2 <-
which works well.
I have a call back setting the ReceivePipline1 to listen to TestSourcePipeline1 . At which point TestSourcePipeline1 throws an EOS and I get the following gst warning:
basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0> transform could not transform video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)3/4, interlace-mode=(string)progressive, format=(string)NV12 in anything we support
Upon setting TestSourcePipeline1 to listen back to RtspCapturePipeline it all works fine again.
The whole time the TestSourcePipeline2 part of the pipeline continues to run smoothly. Because TestSourcePipeline2 and TestSourcePipeline1 have the same caps, it’s confusing as to why the caps can’t be negotiated. The allow-renegotiation flag is set.
Another annoying aspect is that sometimes it works as expected.
Please consult Ridgerun for the Ridgerun’s interpipes.
@ronny.jimenez
