GPU • DeepStream Version
6.0 • JetPack Version (valid for Jetson only) • TensorRT Version
8001 • NVIDIA GPU Driver Version (valid for GPU only)
457.6 • Issue Type( questions, new requirements, bugs)
bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
using the command above. and provide images with different shapes. after a while, the pipeline will corrupt and output below message:
CUDA runtime error 700 cudaErrorIllegalAddress at line 584 in file jdapimin.c.
Yes. if the group of image didn’t change, it will hang on on the same image. but this image will change if i set ths nvstreammux 'properties of width and height
Could you share your image dataset and update the DeepStream to the latest version?
I test the pipeline with ds6.0 in docker on T4 dgpu, it works properly.
It can’t be right. you can use cv::Mat to random generate pictures which width is between 1920 and 300, height is between 1080 and 300. below is my pipline works on ds6.1.1.
May I ask how many pictures you have tested?
I’m sorry My dataset is privated that can’t be shared. But I have tested pic which random generated, it can also reproduce this problem
0:00:21.335788274 5215 0x55e7797ab8c0 DEBUG multifilesrc gstmultifilesrc.c:392:gst_multi_file_src_get_filename: 4999
0:00:21.335811368 5215 0x55e7797ab8c0 DEBUG multifilesrc gstmultifilesrc.c:425:gst_multi_file_src_create:<multifilesrc0> reading from file "4999.jpg".
0:00:21.335862082 5215 0x55e7797ab8c0 DEBUG multifilesrc gstmultifilesrc.c:467:gst_multi_file_src_create:<multifilesrc0> read file "4999.jpg".
0:00:21.339953721 5215 0x55e7797ab8c0 DEBUG multifilesrc gstmultifilesrc.c:392:gst_multi_file_src_get_filename: 5000
0:00:21.339976611 5215 0x55e7797ab8c0 DEBUG multifilesrc gstmultifilesrc.c:425:gst_multi_file_src_create:<multifilesrc0> reading from file "5000.jpg".
Got EOS from element "pipeline0".
Execution ended after 0:00:20.775618410
Setting pipeline to NULL ...
Freeing pipeline ...
Could you give the link of yolov5 train or test dataset or your random generated pictures?
You can also check the compatibility with your env. It may be your environmental dependence problem.
Sorry.I’m trying coco dataset and didn’t reproduce this problem. But I think I found the problem. When I crashed, the picture I read can be decoded independently, the problem is the pics before this.
Could you attach the 422.jpg to us? If you don’t want to share it to public, you can just message it to me. Or you can try to use the jpegdec plguin and check whether it’s still a problem.
