mazzok
#1
Im quite new to cuda and C++, so this might be a newbie question
im usiung shared memory as a char array in my kernel, of which i know the size before the Kernel is launched
so my question and since declaration like
shared char A [3 * VariableA];
fails, how can i declare variable shared memory
(VariableA is part of the kernels parameter…)
Thanks !
Maz
jjp
#2
Declare it like this
extern __shared__ char A[]
and give the kernel the amount of shared memory you want (in bytes) as a third parameter, after grid dimension and block dimension.
kernel<<<gridDim, blockDim, sharedSizeInBytes>>>(..)
mazzok
#3
thank you, thats sounds promising! :)
And… what happen if you want two or three arrays in shared memory with a different size and you CAN’T use templates?
shared extern float a; //128 elements
shared extern float b; //32 elemets
shared extern float c; …
Ok. I got it: Using one array and several pointers :)
