Dynamically add/delete sources
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.1.6.
• NVIDIA GPU Driver Version (valid for GPU only): 535.146.02.
• Issue Type( questions, new requirements, bugs): questions.
There python binding for gst_nvmessage_parse_stream_eos and gst_nvmessage_is_stream_eos?
How i can detect if RTSP stream stops via python code?
You can refer this sample.
Thank you for your faster answer, When message structure message.get_structure() can hold stream-eos message? @junshengy
Yes, of course. This line of code should be what you need
If I add this condition in deepstream_test3 can receive stream-eos structure?
when i handle Gst.MessageType.ELEMENT in both deepstream_test3 and runtime_source_add_delete
the Gst.MessageType.ELEMENT called twice before/after streammux log for handling eos in runtime_source_add_delete example
but the Gst.MessageType.ELEMENT called once before streammux log for handling eos in deepstream_test3 example, where not hold stream-eos in message structure
why message structure not hold stream-eos in deepstream_test3?
What make stream-eos being in message structure?
@junshengy
duplicate with When stream-eos holding in message structure
