I am trying to dynamically add and remove RTSP streams in deepstream using Python. There’s a repo by Nvidia which supports it but It is in C. I want to implement it using python. Should I try to refactor the code into python or is there any other way or an interface that I can use to run C code snippet using python?
Usecase: Deepstream application will read about new streams RTSP links from Firebase and will add new streams to the pipeline. I want to add it dynamically without restarting the pipeline completely.
PS. It is a very important use case as without it no product will be completely functional. If we can’t do it as of now then what do you recommend, should we convert our complete pipeline from python to c?
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.01
