dynamically allocate an array of structure in cuda fortran?
hi,everyone.
I am using cuda Fortran and the compiler is pgi11.8.
I want to allocate memory on device for an array of structure(say STRUCT1) ,whose member is another structure (say STRUCT2). The following is the skeleton of our code:
TYPE STRUCT2
INTEGER,ALLOCATABLE::A(:)
END TYPE
TYPE STRUCT1
TYPE(STRUCT2),ALLOCATABLE::B(:)
END TYPE
TYPE(STRUCT1),ALLOCATABLE,DEVICE::C(:)
INTEGER::NA=5,NB=5,NC=5
INTEGER::I,J
ALLOCATE(C(NC))
DO I=1,NC
ALLOCATE(C(I)%B(NB))
DO J=1,NB
ALLOCATE(C(I)%B(J)%A(NA))
END DO
END DO
when compiling it reports following warning:
/tmp/pgcudafori18dyVySZDk7.gpu(58): Warning: Cannot tell what pointer points to, assuming global memory space
when running it reports “Segmentation fault” runtime error.
The problem is cuda Fortran cannot allocate a structure array of unknow size. But this is the usual case in real applications such as CFD, the problem size (the dimension of grid block) is often determined at runtime.
Can i figure it out by using runtime API or some other alternative methods are available???
Any suggestion will be appreciate. Thanks in advance.
