Dynamically launched kernels ~ 2.5x slower
Hi all,
we tried to use some kernels dynamically as this would decrease our cpu usage. But we found that the kernels launched from other kernels work ~ 2.5x slower. This happens even if we dynamically launch them in separate streams.
Here’s our simple test code (slightly modified vectorAdd - first we launch 1000 kernels dynamically, than we launch 1000 kernels in the usual way):
 * Copyright 1993-2013 NVIDIA Corporation.  All rights reserved.
 * Please refer to the NVIDIA end user license agreement (EULA) associated
 * with this source code for terms and conditions that govern your use of
 * this software. Any use, reproduction, disclosure, or distribution of
 * this software and related documentation outside the terms of the EULA
 * is strictly prohibited.
 * Vector addition: C = A + B.
 * This sample is a very basic sample that implements element by element
 * vector addition. It is the same as the sample illustrating Chapter 2
 * of the programming guide with some additions like error checking.
#include <stdio.h>
// For the CUDA runtime routines (prefixed with "cuda_")
#include <cuda_runtime.h>
 * CUDA Kernel Device code
 * Computes the vector addition of A and B into C. The 3 vectors have the same
 * number of elements numElements.
__global__ void
vectorAdd(const float *A, const float *B, float *C, int numElements)
    int i = blockDim.x * blockIdx.x + threadIdx.x;
    if (i < numElements)
        C[i] = A[i] + B[i];
// a kernel dynamically launching other kernels
__global__ void
vectorAddDyn(const float *A, const float *B, float *C, int numElements) {
    for (int i = 0; i < 1000; i++) {
        cudaStream_t stream;
        cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking);
        // Launch the Vector Add CUDA Kernel
        int threadsPerBlock = 256;
        int blocksPerGrid =(numElements + threadsPerBlock - 1) / threadsPerBlock;
//         printf("CUDA kernel launch with %d blocks of %d threads\n", blocksPerGrid, threadsPerBlock);
        vectorAdd<<<blocksPerGrid, threadsPerBlock, 0, stream>>>(A, B, C, numElements);
        cudaStreamDestroy(stream);
 * Host main routine
int
main(void)
    // Error code to check return values for CUDA calls
    cudaError_t err = cudaSuccess;
    // Print the vector length to be used, and compute its size
    int numElements = 50000000;
    size_t size = numElements * sizeof(float);
    printf("[Vector addition of %d elements]\n", numElements);
    // Allocate the host input vector A
    float *h_A = (float *)malloc(size);
    // Allocate the host input vector B
    float *h_B = (float *)malloc(size);
    // Allocate the host output vector C
    float *h_C = (float *)malloc(size);
    // Verify that allocations succeeded
    if (h_A == NULL || h_B == NULL || h_C == NULL)
        fprintf(stderr, "Failed to allocate host vectors!\n");
        exit(EXIT_FAILURE);
    // Initialize the host input vectors
    for (int i = 0; i < numElements; ++i)
        h_A[i] = rand()/(float)RAND_MAX;
        h_B[i] = rand()/(float)RAND_MAX;
    // Allocate the device input vector A
    float *d_A = NULL;
    err = cudaMalloc((void **)&d_A, size);
    if (err != cudaSuccess)
        fprintf(stderr, "Failed to allocate device vector A (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Allocate the device input vector B
    float *d_B = NULL;
    err = cudaMalloc((void **)&d_B, size);
        fprintf(stderr, "Failed to allocate device vector B (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Allocate the device output vector C
    float *d_C = NULL;
    err = cudaMalloc((void **)&d_C, size);
        fprintf(stderr, "Failed to allocate device vector C (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Copy the host input vectors A and B in host memory to the device input vectors in
    // device memory
    printf("Copy input data from the host memory to the CUDA device\n");
    err = cudaMemcpy(d_A, h_A, size, cudaMemcpyHostToDevice);
        fprintf(stderr, "Failed to copy vector A from host to device (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    err = cudaMemcpy(d_B, h_B, size, cudaMemcpyHostToDevice);
        fprintf(stderr, "Failed to copy vector B from host to device (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // try to launch the kernels dynamically
    vectorAddDyn<<<1, 1>>>(d_A, d_B, d_C, numElements);
    // run the kernels in the usual way
        vectorAdd<<<blocksPerGrid, threadsPerBlock>>>(d_A, d_B, d_C, numElements);
    err = cudaGetLastError();
        fprintf(stderr, "Failed to launch vectorAdd kernel (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Copy the device result vector in device memory to the host result vector
    // in host memory.
    printf("Copy output data from the CUDA device to the host memory\n");
    err = cudaMemcpy(h_C, d_C, size, cudaMemcpyDeviceToHost);
        fprintf(stderr, "Failed to copy vector C from device to host (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Verify that the result vector is correct
        if (fabs(h_A[i] + h_B[i] - h_C[i]) > 1e-5)
            fprintf(stderr, "Result verification failed at element %d!\n", i);
            exit(EXIT_FAILURE);
    printf("Test PASSED\n");
    // Free device global memory
    err = cudaFree(d_A);
        fprintf(stderr, "Failed to free device vector A (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    err = cudaFree(d_B);
        fprintf(stderr, "Failed to free device vector B (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    err = cudaFree(d_C);
        fprintf(stderr, "Failed to free device vector C (error code %s)!\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    // Free host memory
    free(h_A);
    free(h_B);
    free(h_C);
    // Reset the device and exit
    err = cudaDeviceReset();
        fprintf(stderr, "Failed to deinitialize the device! error=%s\n", cudaGetErrorString(err));
        exit(EXIT_FAILURE);
    printf("Done\n");
    return 0;
Here’s what the profiler would show:
Is this usual behavior or are we doing something wrong?
