• Hardware Platform (Jetson / GPU): Tesla T4
• DeepStream Version: 6.4
• TensorRT Version: 8.6.1.6-1+cuda12.0
• Issue Type( questions, new requirements, bugs): question
Hi, I’m encountering this error when attempting to convert my Dino_fan_large ONNX model to TensorRT(FP 32). I used this script for the conversion.
[05/31/2024-11:11:54] [TRT] [E] 10: Could not find any implementation for node {ForeignNode[/model/backbone/backbone.0/Constant_output_0.../model/backbone/backbone.0/body/blocks.0/mlp/mlp_v/dwconv/Transpose + /model/backbone/backbone.0/body/blocks.0/mlp/mlp_v/dwconv/Reshape]}.
[05/31/2024-11:11:55] [TRT] [E] 10: [optimizer.cpp::computeCosts::3869] Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[/model/backbone/backbone.0/Constant_output_0.../model/backbone/backbone.0/body/blocks.0/mlp/mlp_v/dwconv/Transpose + /model/backbone/backbone.0/body/blocks.0/mlp/mlp_v/dwconv/Reshape]}.)
__enter__
Error executing job with overrides: []
File "/opt/nvidia/deepstream/deepstream-6.4/test/tao_deploy/nvidia_tao_deploy/cv/common/decorators.py", line 63, in _func
raise e
File "/opt/nvidia/deepstream/deepstream-6.4/test/tao_deploy/nvidia_tao_deploy/cv/common/decorators.py", line 47, in _func
runner(cfg, **kwargs)
File "/opt/nvidia/deepstream/deepstream-6.4/test/tao_deploy/nvidia_tao_deploy//cv/dino/scripts/gen_trt_engine.py", line 106, in main
builder.create_engine(
File "/opt/nvidia/deepstream/deepstream-6.4/test/tao_deploy/nvidia_tao_deploy/cv/deformable_detr/engine_builder.py", line 173, in create_engine
with self.builder.build_engine(self.network, self.config) as engine, \
AttributeError: __enter__
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Segmentation fault
This is the gen_trt_engine.yaml file I used for the conversion.
encryption_key: "???"
results_dir: "./"
dataset:
num_classes: 91
batch_size: 4
augmentation:
input_std: [0.229, 0.224, 0.225]
model:
backbone: fan_large
num_feature_levels: 4
dec_layers: 6
enc_layers: 6
num_queries: 900
dropout_ratio: 0.0
dim_feedforward: 2048
gen_trt_engine:
gpu_id: 0
onnx_file: "/opt/nvidia/deepstream/deepstream-6.4/test/dino_model_v1.onnx"
trt_engine: "/opt/nvidia/deepstream/deepstream-6.4/test/dino_model_v3.engine"
input_channel: 3
input_width: 960
input_height: 544
tensorrt:
data_type: fp32
workspace_size: 1024
min_batch_size: 1
opt_batch_size: 10
max_batch_size: 10
# calibration:
# cal_image_dir:
# cal_cache_file: "???"
# cal_batch_size: 10
# cal_batches: 1000
What could be causing this error and how can I fix it?
