Description
I met the OOM error when i use TensorRT 7.1.3 to generate the engine file. the network model is VNet that converted from PyTorch model to ONNX model. When i try to generate the engine file with the onnx model file (the input node data size is [1x1x96x176x176]), the engine plan file can produced successfully (config->setMaxWorkspaceSize(3_GiB)), But when i increase the Depth dimenstion (3th dimension) of the input node (the input node data size is [1x1x112x176x176]), the Out of Memory error occurred. I try to increase the workspace size by config->setMaxWorkspaceSize() with 5_GiB, 8_GiB, 10_GiB, 20_GiB
, the Out of memory error still occurred as bellowed. It seems like the setMaxWorkspaceSize()
code have no useness when i set the workspace size larger than 3GiB. I don’t know why the OOM error occur when i just change the input node data size from [1x1x96x176x176] to [1x1x96x176x176] of the onnx model. Does the tensorRT restrict the input data node size for 3D convolution neural network?
There is the error message bellowed:
&&&& RUNNING TensorRT.sample_mnist_api # C:\NVIDIA\TensorRT\TensorRT-7.1.3.4\samples\sampleMNISTAPI_Vnet\x64\Debug\sample_mnist_api_vnet3d.exe
[12/08/2020-09:54:09] [I] Building and running a GPU inference engine for MNIST API
[12/08/2020-09:54:10] [W] [TRT] Setting layouts of network and plugin input/output tensors to linear, as 3D operators are found and 3D non-linear IO formats are not supported, yet.
[12/08/2020-09:54:15] [E] [TRT] C:\source\rtSafe\safeRuntime.cpp (25) - Cuda Error in nvinfer1::internal::DefaultAllocator::allocate: 2 (out of memory)
[12/08/2020-09:54:15] [W] [TRT] GPU memory allocation error during getBestTactic: (Unnamed Layer* 115) [Convolution] + (Unnamed Layer* 118) [ElementWise] + (Unnamed Layer* 119) [Activation]
[12/08/2020-09:54:15] [E] [TRT] Try increasing the workspace size with IBuilderConfig::setMaxWorkspaceSize() if using IBuilder::buildEngineWithConfig, or IBuilder::setMaxWorkspaceSize() if using IBuilder::buildCudaEngine.
[12/08/2020-09:54:15] [E] [TRT] C:\source\builder\tacticOptimizer.cpp (1715) - TRTInternal Error in nvinfer1::builder::`anonymous-namespace'::LeafCNode::computeCosts: 0 (Could not find any implementation for node (Unnamed Layer* 115) [Convolution] + (Unnamed Layer* 118) [ElementWise] + (Unnamed Layer* 119) [Activation].)
Appreciated for any reply, Thanks.
Environment
TensorRT Version: 7.1.3
GPU Type: RTX 6000 (24GiB device memory)
Nvidia Driver Version: 451.48
CUDA Version: 11.0
CUDNN Version: 8.0.2
Operating System + Version: Windows 10
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
