Hello guys,
I have set up my Eclipse with nsight plugin, as FabianWeise suggested in here https://devtalk.nvidia.com/default/topic/1058080/general/nsight-with-cuda-10-0-nvidia-drive-trade-software-9-0-linux-building-issue/.
My project builds and I can run the debugger from the NVIDIA Learn website, but I am having issues with Eclipse “Field … could not be resolved” messages.
Eclipse complained that it can’t find anything that starts with either dw or dwvisualization, which I solved by adding /usr/local/driveworks-2.0/targets/x86_64-Linux/include to project Properties → C/C++ General → Paths and Symbols → Includes tab. I added it to all configurations and all languages and a portion of the unresolved includes disappeared.
Eclipse also complained that it can’t find some functions such as to_string(), which I solved by following the instructions in this post: https://stackoverflow.com/questions/17131744/eclipse-cdt-indexer-does-not-know-c11-containers
However, I am still having unresolved includes, which you can find below:
Description Resource Path Location Type
Field 'frameCaptureGlobalTimeStamp' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 497 Semantic Error
Field 'frameSequenceNumber' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 495 Semantic Error
Field 'imageInformation' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 495 Semantic Error
Field 'imageInformation' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 497 Semantic Error
Function 'NvMediaIPPManagerSetEventCallback' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 257 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_ERROR_CSI_INPUT_STREAM_FAILURE' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 508 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_ERROR_I2C_TRANSMISSION_FAILURE' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 514 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_ERROR_INTERNAL_FAILURE' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 501 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_INFO_EOF' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 511 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_INFO_FRAME_CAPTURE' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 513 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_INFO_PROCESSING_DONE' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 512 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_WARNING_CAPTURE_FRAME_DROP' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 492 Semantic Error
Symbol 'NVMEDIA_IPP_EVENT_WARNING_CSI_FRAME_DISCONTINUITY' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 505 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 123 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 130 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 131 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 147 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 174 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 176 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 191 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 203 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 246 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 247 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 256 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 266 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 279 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 281 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 368 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 372 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 376 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 390 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 393 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 411 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 417 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 421 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 425 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 431 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 446 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 450 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 454 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 457 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 460 Semantic Error
Symbol 'runtime_error' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 463 Semantic Error
Type 'NvMediaIPPComponent' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 482 Semantic Error
Type 'NvMediaIPPComponentType' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 481 Semantic Error
Type 'NvMediaIPPEventData' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 484 Semantic Error
Type 'NvMediaIPPEventType' could not be resolved main.cpp /Samples Nsight Cross Compile/samples/src/sensors/camera/camera_gmsl line 483 Semantic Error
What do I need to include to solve these unresolved include errors? Again, I can build the project without problems, but these fake errors are clouding real errors that could arise. Should I just ignore those?
Thank you in advance,
Mislav
