After enabling these following packages in kernel configurations, AR1335 driver used for econ [e-CAM130_TRICUTX2_JETSON_TX2_TX2i_L4T28.2.1], is throwing errors while booting.
if the above mentioned packages are disabled, then econ driver loads perfectly and works fine.
attached image for error log.
Unknown symbol camera_common_remove_debugfs ( err -22)
disagrees about version of symbol camera_common_try_fmt
Unknown symbol camera_common_try_fmt ( err -22)
disagrees about version of symbol camera_common_g_fmt
Unknown symbol camera_common_g_fmt ( err -22)
etc
It seems like kernel’s symbol table is mismatching with sensor driver’s(ar1335.ko) symbols.This kind of issue occurs when extra packages added to kernel Image.
We re-command you to write an e-mail regarding your issue to techsupport@e-consystems.com.Our support engineers will help you to resolve this issue as soon as possible.
