In the SDK 3.5.1 examples there is an option “-CPU” described as “Enable CPU execution of OptiX programs. The number of threads can be set with --num-devices.”
In the code, it calls “m_scene->enableCPURendering(true)”
If I try this option I get this error:
“Optix Error: Attempting to enable CPU mode, but no CPU device found”
Sound very interesting, it reminds me “CPU Fallback”
Comments?
AD
[EDIT2] How to run CUDA in Emulation Mode? Found some hints HERE
[EDIT] The error message derives form HERE:
void
SampleScene::enableCPURendering(bool enable)
// Is CPU mode already enabled
std::vector<int> devices = m_context->getEnabledDevices();
bool isCPUEnabled = false;
for(std::vector<int>::const_iterator iter = devices.begin(); iter != devices.end(); ++iter)
if (m_context->getDeviceName(*iter) == "CPU") {
isCPUEnabled = true;
break;
// Already in desired state, good-bye.
if (isCPUEnabled == enable)
return;
if (enable)
// Turn on CPU mode
int ordinal;
for(ordinal = m_context->getDeviceCount()-1; ordinal >= 0; ordinal--)
if (m_context->getDeviceName(ordinal) == "CPU") {
break;
if (ordinal < 0)
throw Exception("Attempting to enable CPU mode, but no CPU device found");
m_context->setDevices(&ordinal, &ordinal+1);
} else
// Turn off CPU mode
// For now, simply grab the first device
int ordinal = 0;
// Check this here, in case we failed to make it into GPU mode.
updateCPUMode();
