HI:
I run android on tk1,when I power on the machine, there has no edp signal and pwm output to lcd,after three seconds,the edp signal and pwm is output to the lcd and the lcd can display but abnormal,after several seconds , when the machine has run to android ,the edp signal and pwm lose again,what should I do? there is logcat and kernel log as follow:
LOGCAT :
--------- beginning of main
I/wifiloader( 0): Using for WiFi
W/auditd ( 135): type=2000 audit(0.0:1): initialized
I/auditd ( 135): type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
E/wifiloader( 0): WiFi card is not available! try 0
I/lowmemorykiller( 0): Using in-kernel low memory killer interface
I/ ( 153): debuggerd: Mar 14 2017 19:04:01
--------- beginning of system
I/Vold ( 139): Vold 2.1 (the revenge) firing up
I/Netd ( 152): Netd 1.0 starting
D/Vold ( 139): Volume sdcard1 state changing -1 (Initializing) → 0 (No-Media)
D/Vold ( 139): Volume usbdrive state changing -1 (Initializing) → 0 (No-Media)
I/installd( 159): installd firing up
I/SurfaceFlinger( 140): SurfaceFlinger is starting
I/SurfaceFlinger( 140): SurfaceFlinger’s main thread ready to run. Initializing graphics H/W…
D/Raydium_TS_Native_Service( 176): rm_ts_service instantiate
D/Raydium_TS_Native_Service( 176): rm_ts_service created
D/Raydium_TS_Native_Service( 176): TS Service JNI: TS Stub found
D/Raydium_TS_Stub( 176): -------------------Raydium TS Stub open ---------------
D/Raydium_ts_main( 176): ## ts_main_init
D/libEGL ( 140): loaded /vendor/lib/egl/libEGL_tegra.so
E/ ( 176): ## == SPI check NG ==, 0th, g_wrtBuffer=55, g_readBuffer=b8
E/Raydium_Librm_SENSOR( 176): ## SPI Check NG, Please check H/W and spi_board_info in board-xxx.c
D/gpsd ( 179): WakeLock(Release,GPSD)
D/gpsd ( 179): WakeLock(Release,SUPL)
E/Raydium_T007B_SCAN( 176): ## == SPI check NG ==, 0th, g_wrtBuffer=55, g_readBuffer=b8
E/Raydium_ts_main( 176): ##ts_librm_sensor_module_init=fail
E/Raydium_TS_Stub( 176): Raydium TS Stub: ts_device_open Fail
E/Raydium_TS_Native_Service( 176): TS Service JNI: Get Stub operations failed
D/Raydium_TS_Native_Service( 176): rm_ts_service r = 0
D/libEGL ( 140): loaded /vendor/lib/egl/libGLESv1_CM_tegra.so
D/libEGL ( 140): loaded /vendor/lib/egl/libGLESv2_tegra.so
D/NvOsDebugPrintf( 140): NvRmPrivGetChipPlatform: Could not read platform information
D/NvOsDebugPrintf( 140): Expected on kernels without fuse support, using silicon
I/mediaserver( 158): ServiceManager: 0xb61500c0
I/AudioFlinger( 158): Using default 3000 mSec as standby time.
I/ServiceManager( 158): Waiting for service batterystats…
D/AndroidRuntime( 177):
D/AndroidRuntime( 177): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 177): CheckJNI is ON
I/art ( 177): option[0]=-Xzygote
I/art ( 177): option[1]=-Xcheck:jni
I/art ( 177): option[2]=-Xjnigreflimit:2000
I/art ( 177): option[3]=-Xstacktracefile:/data/anr/traces.txt
I/art ( 177): option[4]=exit
I/art ( 177): option[5]=vfprintf
I/art ( 177): option[6]=sensitiveThread
I/art ( 177): option[7]=-verbose:gc
I/art ( 177): option[8]=-Xms12m
I/art ( 177): option[9]=-Xmx448m
I/art ( 177): option[10]=-XX:mainThreadStackSize=24K
I/art ( 177): option[11]=-XX:HeapGrowthLimit=128m
I/art ( 177): option[12]=-Xgenregmap
I/art ( 177): option[13]=-Xgc:precise
I/art ( 177): option[14]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y
I/art ( 177): option[15]=-Ximage-compiler-option
I/art ( 177): option[16]=–runtime-arg
I/art ( 177): option[17]=-Ximage-compiler-option
I/art ( 177): option[18]=-Xms64m
I/art ( 177): option[19]=-Ximage-compiler-option
I/art ( 177): option[20]=–runtime-arg
I/art ( 177): option[21]=-Ximage-compiler-option
I/art ( 177): option[22]=-Xmx64m
I/art ( 177): option[23]=-Ximage-compiler-option
I/art ( 177): option[24]=–compiler-filter=verify-none
I/art ( 177): option[25]=-Ximage-compiler-option
I/art ( 177): option[26]=–image-classes-zip=/system/framework/framework.jar
I/art ( 177): option[27]=-Ximage-compiler-option
I/art ( 177): option[28]=–image-classes=preloaded-classes
I/art ( 177): option[29]=-Xcompiler-option
I/art ( 177): option[30]=–runtime-arg
I/art ( 177): option[31]=-Xcompiler-option
I/art ( 177): option[32]=-Xms64m
I/art ( 177): option[33]=-Xcompiler-option
I/art ( 177): option[34]=–runtime-arg
I/art ( 177): option[35]=-Xcompiler-option
I/art ( 177): option[36]=-Xmx512m
I/art ( 177): option[37]=-Xcompiler-option
I/art ( 177): option[38]=–compiler-filter=interpret-only
I/art ( 177): option[39]=-Duser.language=en
I/art ( 177): option[40]=-Duser.region=US
V/NatController( 152): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController( 152): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController( 152): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController( 152): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=1
V/NatController( 152): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=1
V/NatController( 152): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
V/NatController( 152): runCmd(/system/bin/iptables -t mangle -A natctrl_mangle_FORWARD -p tcp --tcp-flags SYN SYN -j TCPMSS --clamp-mss-to-pmtu) res=0
D/hwcomposer( 140): hdmi_primary set to: 1
D/hwcomposer( 140): cursor_enable set to: 1
D/hwcomposer( 140): didim_enable set to: 1
D/hwcomposer( 140): didim_normal set to: 3
D/hwcomposer( 140): didim_video set to: 5
W/hwcomposer( 140): Invalid display_resolution property: “”
D/hwcomposer( 140): HDMI preferred resolution set to: Max_60Hz
D/hwcomposer( 140): Compositor set to: glcomposer
D/hwcomposer( 140): Composite policy set to: auto
D/hwcomposer( 140): composite_fallback set to: 1
D/hwcomposer( 140): Overriding minimum_fps, new value = 8
D/hwcomposer( 140): imp_enable set to: 1
E/hwcomposer( 140): failed to enumerate adf devices: Success
D/hwcomposer( 140): Using DC driver
D/hwcomposer( 140): void nvfb_event_process_pipe(void*): processing pipe fd
D/hwcomposer( 140): Display 0: found 2 modes
D/hwcomposer( 140): display type 0: vblank period = 17301238 ns
D/hwcomposer( 140): virtual int dc_display::set_blank(int): display 0, [1 → 1]
I/SamplingProfilerIntegration( 177): Profiling disabled.
D/Zygote ( 177): begin preload
I/Zygote ( 177): Preloading classes…
I/art ( 177): Explicit concurrent mark sweep GC freed 1015(62KB) AllocSpace objects, 0(0B) LOS objects, 83% free, 200KB/1224KB, paused 72us total 3.162ms
I/art ( 177): Counter: 1
D/MDnsDS ( 152): MDnsSdListener::Hander starting up
D/MDnsDS ( 152): MDnsSdListener starting to monitor
D/MDnsDS ( 152): Going to poll with pollCount 1
I/art ( 177): Explicit concurrent mark sweep GC freed 442(27KB) AllocSpace objects, 0(0B) LOS objects, 81% free, 239KB/1263KB, paused 63us total 1.954ms
I/art ( 177): Explicit concurrent mark sweep GC freed 320(20KB) AllocSpace objects, 0(0B) LOS objects, 79% free, 268KB/1292KB, paused 59us total 2.022ms
I/art ( 177): Explicit concurrent mark sweep GC freed 245(14KB) AllocSpace objects, 0(0B) LOS objects, 77% free, 302KB/1326KB, paused 59us total 1.710ms
I/art ( 177): Explicit concurrent mark sweep GC freed 351(19KB) AllocSpace objects, 0(0B) LOS objects, 75% free, 332KB/1356KB, paused 60us total 2.193ms
I/art ( 177): Explicit concurrent mark sweep GC freed 375(23KB) AllocSpace objects, 0(0B) LOS objects, 73% free, 374KB/1398KB, paused 60us total 2.114ms
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGujarati-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGujarati-Bold.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGujaratiUI-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGujaratiUI-Bold.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGurmukhi-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGurmukhi-Bold.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGurmukhiUI-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansGurmukhiUI-Bold.ttf
D/hwcomposer( 140): matched: 1280 x 720 @ 60.00 Hz
D/hwcomposer( 140): display type 1: vblank period = 16666214 ns
E/hwcomposer( 140): HDCP: hdcp_open failed, error 1
D/hwcomposer( 140): Setting vblank display to Internal, new vblank period 16666214 ns
D/hwcomposer( 140): display type 2: vblank period = 0 ns
W/hwcomposer( 140): failed to load libnvcap_video.so: dlopen failed: library “libnvcap_video.so” not found
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansSinhala-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansSinhala-Bold.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansCherokee-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansCanadianAboriginal-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansYi-Regular.ttf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansHans-Regular.otf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansHant-Regular.otf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansJP-Regular.otf
E/Minikin ( 177): addFont failed to create font /system/fonts/NotoSansKR-Regular.otf
I/art ( 177): Explicit concurrent mark sweep GC freed 1525(111KB) AllocSpace objects, 0(0B) LOS objects, 71% free, 398KB/1422KB, paused 64us total 2.571ms
I/art ( 177): Explicit concurrent mark sweep GC freed 1954(94KB) AllocSpace objects, 0(0B) LOS objects, 69% free, 457KB/1481KB, paused 62us total 2.740ms
I/art ( 177): Explicit concurrent mark sweep GC freed 1982(88KB) AllocSpace objects, 0(0B) LOS objects, 67% free, 494KB/1518KB, paused 67us total 2.682ms
I/art ( 177): Explicit concurrent mark sweep GC freed 416(29KB) AllocSpace objects, 0(0B) LOS objects, 65% free, 530KB/1554KB, paused 63us total 2.548ms
I/art ( 177): Thread[1,tid=177,WaitingForJniOnLoad,Thread*=0xb5007800,peer=0x12c591a0,“main”] recursive attempt to load library “/system/lib/libmedia_jni.so”
D/MtpDeviceJNI( 177): register_android_mtp_MtpDevice
I/art ( 177): Explicit concurrent mark sweep GC freed 562(33KB) AllocSpace objects, 0(0B) LOS objects, 65% free, 549KB/1573KB, paused 63us total 2.867ms
I/art ( 177): Explicit concurrent mark sweep GC freed 371(18KB) AllocSpace objects, 0(0B) LOS objects, 63% free, 581KB/1605KB, paused 62us total 2.748ms
I/art ( 177): Explicit concurrent mark sweep GC freed 406(23KB) AllocSpace objects, 0(0B) LOS objects, 62% free, 626KB/1650KB, paused 67us total 3.065ms
I/art ( 177): Explicit concurrent mark sweep GC freed 347(20KB) AllocSpace objects, 0(0B) LOS objects, 60% free, 659KB/1683KB, paused 62us total 2.839ms
I/art ( 177): Explicit concurrent mark sweep GC freed 42(3KB) AllocSpace objects, 0(0B) LOS objects, 58% free, 712KB/1736KB, paused 65us total 2.839ms
I/wifiloader( 565): ro.wifi.sdmmc property not set, reading from sdmmc0
I/wifiloader( 567): Using for WiFi
I/art ( 177): Explicit concurrent mark sweep GC freed 1758(102KB) AllocSpace objects, 0(0B) LOS objects, 54% free, 854KB/1878KB, paused 68us total 3.604ms
E/wifiloader( 570): WiFi card is not available! try 1
E/EmojiFactory_jni( 177): Failed to load libemoji.so: dlopen failed: library “libemoji.so” not found
I/art ( 177): Explicit concurrent mark sweep GC freed 261(43KB) AllocSpace objects, 0(0B) LOS objects, 46% free, 1161KB/2MB, paused 63us total 4.584ms
I/art ( 177): Explicit concurrent mark sweep GC freed 391(27KB) AllocSpace objects, 0(0B) LOS objects, 46% free, 1194KB/2MB, paused 72us total 4.172ms
E/phs:fs ( 175): Unable to open file “/mnt/tmp/fc0”: No such file or directory
W/phs:machine( 175): Could not open “/mnt/tmp/fc0”: No such file or directory. Trying later.
E/phs:fs ( 175): Unable to open file “/mnt/tmp/fc1”: No such file or directory
W/phs:machine( 175): Could not open “/mnt/tmp/fc1”: No such file or directory. Trying later.
E/phs:governor( 175): failed to load “libgov_ui.so”: No such file or directory
E/phs ( 175): Failed to initialize scaling governors. Exiting.
I/art ( 177): Explicit concurrent mark sweep GC freed 642(40KB) AllocSpace objects, 0(0B) LOS objects, 45% free, 1203KB/2MB, paused 65us total 4.617ms
I/art ( 177): Explicit concurrent mark sweep GC freed 441(30KB) AllocSpace objects, 0(0B) LOS objects, 45% free, 1221KB/2MB, paused 63us total 4.300ms
I/art ( 177): Explicit concurrent mark sweep GC freed 700(89KB) AllocSpace objects, 0(0B) LOS objects, 44% free, 1254KB/2MB, paused 70us total 4.158ms
I/art ( 177): Explicit concurrent mark sweep GC freed 517(34KB) AllocSpace objects, 0(0B) LOS objects, 44% free, 1269KB/2MB, paused 64us total 4.852ms
I/art ( 177): Explicit concurrent mark sweep GC freed 622(32KB) AllocSpace objects, 0(0B) LOS objects, 44% free, 1298KB/2MB, paused 63us total 3.887ms
I/art ( 177): Explicit concurrent mark sweep GC freed 249(12KB) AllocSpace objects, 0(0B) LOS objects, 43% free, 1349KB/2MB, paused 95us total 4.416ms
I/art ( 177): Explicit concurrent mark sweep GC freed 464(34KB) AllocSpace objects, 0(0B) LOS objects, 42% free, 1363KB/2MB, paused 62us total 4.056ms
D/hwcomposer( 140): Display 0 layer size is 1280 x 720
D/hwcomposer( 140): Display 0 device size is 1280 x 720
D/hwcomposer( 140): Display 0 device clip is (0, 0, 1280, 720)
I/SurfaceFlinger( 140): Using composer version 1.3
D/hwcomposer( 140): config[0].x = 1280
D/hwcomposer( 140): config[0].y = 720
W/SurfaceFlinger( 140): no suitable EGLConfig found, trying a simpler query
I/SurfaceFlinger( 140): EGL information:
I/SurfaceFlinger( 140): vendor : Android
I/SurfaceFlinger( 140): version : 1.4 Android META-EGL
I/SurfaceFlinger( 140): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_EXT_create_context_robustness EGL_NV_system_time EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable
I/SurfaceFlinger( 140): Client API: OpenGL_ES
I/SurfaceFlinger( 140): EGLSurface: 8-8-8-8, config=0xcaf32d
I/SurfaceFlinger( 140): OpenGL ES informations:
I/SurfaceFlinger( 140): vendor : NVIDIA Corporation
I/SurfaceFlinger( 140): renderer : NVIDIA Tegra
I/SurfaceFlinger( 140): version : OpenGL ES 3.1 NVIDIA 349.00
I/SurfaceFlinger( 140): extensions: GL_EXT_debug_marker GL_NV_internalformat_sample_query GL_EXT_base_instance GL_EXT_blend_minmax GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_occlusion_query_boolean GL_EXT_primitive_bounding_box GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shadow_samplers GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_textu
I/SurfaceFlinger( 140): GL_MAX_TEXTURE_SIZE = 16384
I/SurfaceFlinger( 140): GL_MAX_VIEWPORT_DIMS = 16384
D/SurfaceFlinger( 140): Set power mode=2, type=0 flinger=0xb6a62000
D/hwcomposer( 140): int hwc_blank(hwc_composer_device_1*, int, int): display 0: unblank
D/hwcomposer( 140): void hwc_blank_display(nvhwc_context*, int, int): display 0: [1 → 0]
D/hwcomposer( 140): virtual int dc_display::set_blank(int): display 1, [1 → 0]
E/SurfaceFlinger( 140): eventControl(0, 1) failed Unknown error -1
D/libEGL ( 598): loaded /vendor/lib/egl/libEGL_tegra.so
I/art ( 177): Explicit concurrent mark sweep GC freed 388(15KB) AllocSpace objects, 0(0B) LOS objects, 36% free, 1786KB/2MB, paused 110us total 6.536ms
D/libEGL ( 598): loaded /vendor/lib/egl/libGLESv1_CM_tegra.so
I/art ( 177): Explicit concurrent mark sweep GC freed 545(31KB) AllocSpace objects, 0(0B) LOS objects, 36% free, 1804KB/2MB, paused 75us total 6.191ms
D/libEGL ( 598): loaded /vendor/lib/egl/libGLESv2_tegra.so
D/NvOsDebugPrintf( 598): NvRmPrivGetChipPlatform: Could not read platform information
D/NvOsDebugPrintf( 598): Expected on kernels without fuse support, using silicon
I/art ( 177): Explicit concurrent mark sweep GC freed 703(41KB) AllocSpace objects, 0(0B) LOS objects, 36% free, 1812KB/2MB, paused 75us total 5.539ms
I/System ( 177): Loaded time zone names for “” in 54ms (41ms in ICU)
I/System ( 177): Loaded time zone names for “en_US” in 37ms (22ms in ICU)
I/art ( 177): Explicit concurrent mark sweep GC freed 2534(190KB) AllocSpace objects, 0(0B) LOS objects, 34% free, 1973KB/2MB, paused 73us total 6.169ms
I/art ( 177): Explicit concurrent mark sweep GC freed 120(11KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 2039KB/2MB, paused 80us total 5.822ms
I/art ( 177): Explicit concurrent mark sweep GC freed 372(26KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 2MB/3MB, paused 70us total 5.858ms
D/AndroidRuntime( 632):
D/AndroidRuntime( 632): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 632): CheckJNI is ON
I/art ( 177): Explicit concurrent mark sweep GC freed 527(37KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 2MB/3MB, paused 70us total 5.963ms
D/AndroidRuntime( 632): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 632): Shutting down VM
E/art ( 632): Thread attaching while runtime is shutting down: Binder_1
I/AndroidRuntime( 632): NOTE: attach of thread ‘Binder_1’ failed
I/Zygote ( 177): …preloaded 3005 classes in 2034ms.
I/art ( 177): VMRuntime.preloadDexCaches starting
I/art ( 177): VMRuntime.preloadDexCaches strings total=210171 before=8585 after=8585
I/art ( 177): VMRuntime.preloadDexCaches types total=18253 before=6308 after=6349
I/art ( 177): VMRuntime.preloadDexCaches fields total=84525 before=31367 after=31737
I/art ( 177): VMRuntime.preloadDexCaches methods total=149263 before=59708 after=61080
I/art ( 177): VMRuntime.preloadDexCaches finished
I/art ( 177): Counter: 0
I/art ( 177): Explicit concurrent mark sweep GC freed 252(27KB) AllocSpace objects, 0(0B) LOS objects, 65% free, 2MB/6MB, paused 70us total 8.517ms
D/idmap ( 653): error: no read access to /vendor/overlay: No such file or directory
I/Zygote ( 177): Preloading resources…
I/art ( 177): Explicit concurrent mark sweep GC freed 83(3KB) AllocSpace objects, 0(0B) LOS objects, 65% free, 2MB/6MB, paused 83us total 6.620ms
I/art ( 177): Explicit concurrent mark sweep GC freed 93(4KB) AllocSpace objects, 0(0B) LOS objects, 64% free, 2MB/6MB, paused 70us total 5.322ms
I/art ( 177): Explicit concurrent mark sweep GC freed 117(5KB) AllocSpace objects, 0(0B) LOS objects, 64% free, 2MB/6MB, paused 77us total 6.406ms
I/art ( 177): Explicit concurrent mark sweep GC freed 99(4KB) AllocSpace objects, 0(0B) LOS objects, 63% free, 2MB/6MB, paused 76us total 5.735ms
D/AndroidRuntime( 656):
D/AndroidRuntime( 656): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 656): CheckJNI is ON
I/art ( 177): Explicit concurrent mark sweep GC freed 94(4KB) AllocSpace objects, 0(0B) LOS objects, 63% free, 2MB/6MB, paused 80us total 5.991ms
I/art ( 177): Explicit concurrent mark sweep GC freed 104(4KB) AllocSpace objects, 0(0B) LOS objects, 63% free, 2MB/6MB, paused 76us total 5.742ms
I/art ( 177): Explicit concurrent mark sweep GC freed 113(5KB) AllocSpace objects, 0(0B) LOS objects, 62% free, 2MB/6MB, paused 121us total 5.651ms
I/art ( 177): Explicit concurrent mark sweep GC freed 119(5KB) AllocSpace objects, 0(0B) LOS objects, 62% free, 2MB/6MB, paused 76us total 5.923ms
I/art ( 177): Explicit concurrent mark sweep GC freed 108(5KB) AllocSpace objects, 0(0B) LOS objects, 61% free, 2MB/6MB, paused 73us total 5.663ms
I/art ( 177): Explicit concurrent mark sweep GC freed 156(6KB) AllocSpace objects, 0(0B) LOS objects, 61% free, 2MB/6MB, paused 78us total 5.978ms
W/SurfaceFlinger( 140): Timed out waiting for hw vsync; faking it
I/art ( 177): Explicit concurrent mark sweep GC freed 139(6KB) AllocSpace objects, 0(0B) LOS objects, 60% free, 2MB/6MB, paused 80us total 13.897ms
I/art ( 177): Explicit concurrent mark sweep GC freed 85(7KB) AllocSpace objects, 0(0B) LOS objects, 60% free, 2MB/6MB, paused 112us total 14.093ms
I/art ( 177): Explicit concurrent mark sweep GC freed 111(4KB) AllocSpace objects, 0(0B) LOS objects, 59% free, 2MB/6MB, paused 73us total 11.902ms
D/AndroidRuntime( 656): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 656): Shutting down VM
E/art ( 656): Thread attaching while runtime is shutting down: Binder_1
I/AndroidRuntime( 656): NOTE: attach of thread ‘Binder_1’ failed
I/art ( 177): Explicit concurrent mark sweep GC freed 137(5KB) AllocSpace objects, 0(0B) LOS objects, 59% free, 2MB/6MB, paused 80us total 7.899ms
I/art ( 177): Explicit concurrent mark sweep GC freed 62(2752B) AllocSpace objects, 0(0B) LOS objects, 58% free, 2MB/6MB, paused 75us total 5.866ms
I/art ( 177): Explicit concurrent mark sweep GC freed 114(4KB) AllocSpace objects, 0(0B) LOS objects, 56% free, 3MB/7MB, paused 103us total 6.783ms
I/art ( 177): Explicit concurrent mark sweep GC freed 217(9KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 3MB/7MB, paused 77us total 6.772ms
I/art ( 177): Explicit concurrent mark sweep GC freed 372(16KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 3MB/7MB, paused 81us total 6.310ms
I/art ( 177): Explicit concurrent mark sweep GC freed 216(9KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 3MB/7MB, paused 76us total 5.883ms
I/art ( 177): Explicit concurrent mark sweep GC freed 115(6KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 3MB/7MB, paused 80us total 6.168ms
I/art ( 177): Explicit concurrent mark sweep GC freed 113(5KB) AllocSpace objects, 0(0B) LOS objects, 54% free, 3MB/7MB, paused 83us total 6.188ms
I/art ( 177): Explicit concurrent mark sweep GC freed 49(8KB) AllocSpace objects, 0(0B) LOS objects, 54% free, 3MB/7MB, paused 76us total 6.057ms
I/art ( 177): Explicit concurrent mark sweep GC freed 101(4KB) AllocSpace objects, 0(0B) LOS objects, 54% free, 3MB/7MB, paused 76us total 6.097ms
I/art ( 177): Explicit concurrent mark sweep GC freed 109(4KB) AllocSpace objects, 0(0B) LOS objects, 53% free, 3MB/7MB, paused 80us total 6.083ms
D/SurfaceFlinger( 140): shader cache generated - 24 shaders in 257.242401 ms
I/art ( 177): Explicit concurrent mark sweep GC freed 100(4KB) AllocSpace objects, 0(0B) LOS objects, 53% free, 3MB/7MB, paused 79us total 6.268ms
I/art ( 177): Explicit concurrent mark sweep GC freed 179(8KB) AllocSpace objects, 0(0B) LOS objects, 52% free, 3MB/7MB, paused 83us total 6.915ms
I/art ( 177): Explicit concurrent mark sweep GC freed 269(11KB) AllocSpace objects, 0(0B) LOS objects, 52% free, 3MB/7MB, paused 79us total 6.475ms
I/art ( 177): Explicit concurrent mark sweep GC freed 99(4KB) AllocSpace objects, 0(0B) LOS objects, 52% free, 3MB/7MB, paused 75us total 6.237ms
I/art ( 177): Explicit concurrent mark sweep GC freed 95(4KB) AllocSpace objects, 0(0B) LOS objects, 51% free, 3MB/7MB, paused 76us total 5.888ms
I/art ( 177): Explicit concurrent mark sweep GC freed 95(4KB) AllocSpace objects, 0(0B) LOS objects, 51% free, 3MB/7MB, paused 75us total 5.860ms
I/art ( 177): Explicit concurrent mark sweep GC freed 95(4KB) AllocSpace objects, 0(0B) LOS objects, 51% free, 3MB/7MB, paused 75us total 5.844ms
I/art ( 177): Explicit concurrent mark sweep GC freed 95(4KB) AllocSpace objects, 0(0B) LOS objects, 51% free, 3MB/7MB, paused 75us total 5.835ms
I/art ( 177): Explicit concurrent mark sweep GC freed 81(3KB) AllocSpace objects, 0(0B) LOS objects, 50% free, 3MB/7MB, paused 74us total 5.896ms
I/art ( 177): Explicit concurrent mark sweep GC freed 99(4KB) AllocSpace objects, 0(0B) LOS objects, 50% free, 3MB/7MB, paused 75us total 5.876ms
I/art ( 177): Explicit concurrent mark sweep GC freed 109(5KB) AllocSpace objects, 0(0B) LOS objects, 50% free, 3MB/7MB, paused 75us total 5.880ms
I/art ( 177): Explicit concurrent mark sweep GC freed 395(14KB) AllocSpace objects, 0(0B) LOS objects, 50% free, 3MB/7MB, paused 75us total 6.549ms
I/art ( 177): Explicit concurrent mark sweep GC freed 1173(40KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 97us total 6.033ms
I/art ( 177): Explicit concurrent mark sweep GC freed 1504(50KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 77us total 6.082ms
I/art ( 177): Explicit concurrent mark sweep GC freed 1374(48KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 76us total 6.083ms
I/art ( 177): Explicit concurrent mark sweep GC freed 209(11KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 77us total 6.033ms
I/Zygote ( 177): …preloaded 430 resources in 651ms.
I/art ( 177): Explicit concurrent mark sweep GC freed 258(16KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 85us total 6.856ms
I/wifiloader( 671): ro.wifi.sdmmc property not set, reading from sdmmc0
I/Zygote ( 177): …preloaded 41 resources in 24ms.
D/libEGL ( 177): loaded /vendor/lib/egl/libEGL_tegra.so
I/wifiloader( 673): Using for WiFi
E/wifiloader( 676): WiFi card is not available! try 2
D/libEGL ( 177): loaded /vendor/lib/egl/libGLESv1_CM_tegra.so
D/libEGL ( 177): loaded /vendor/lib/egl/libGLESv2_tegra.so
I/Zygote ( 177): Preloading shared libraries…
D/Zygote ( 177): end preload
I/art ( 177): Explicit concurrent mark sweep GC freed 406(21KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 77us total 6.681ms
I/art ( 177): Explicit concurrent mark sweep GC freed 217(8KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 71us total 5.962ms
I/art ( 177): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/8MB, paused 77us total 6.147ms
I/Zygote ( 177): System server process 677 has been created
I/Zygote ( 177): Accepting command socket connections
I/InstallerConnection( 677): disconnecting…
I/SystemServer( 677): Entered the Android system server!
D/AndroidRuntime( 691):
D/AndroidRuntime( 691): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 691): CheckJNI is ON
E/phs:governor( 698): failed to load “libgov_ui.so”: No such file or directory
E/phs ( 698): Failed to initialize scaling governors. Exiting.
V/Fingerprint-JNI( 677): FingerprintManager JNI ready.
D/SensorService( 677): nuSensorService starting…
E/Sensors ( 677): sensors_poll_context_t started
E/Sensors ( 677): HAL:open of /sys/class/invensense/mpu/enable failed with ‘No such file or directory’ (2)
E/Sensors ( 677): HAL:open of /sys/class/invensense/mpu/gyro_fifo_enable failed with ‘No such file or directory’ (2)
E/Sensors ( 677): HAL:open of /sys/class/invensense/mpu/accl_fifo_enable failed with ‘No such file or directory’ (2)
E/Sensors ( 677): HAL:ERR- Failed to get chip ID
I/Sensors ( 677): path open /dev/input/event0
I/Sensors ( 677): path open /dev/input/event2
I/Sensors ( 677): path open /dev/input/event1
E/Sensors ( 677): couldn’t find 'engthAnalyzer
E/Sensors ( 677): com.an’ input device
E/Sensors ( 677): HAL:could not open the gyro device node
V/Sensors ( 677): HAL:calibration path successfully loaded
E/Sensors ( 677): HAL:could not open gyro fifo enable
E/Sensors ( 677): HAL:could not open accel enable
E/Sensors ( 677): HAL:could not open temperature node
E/Sensors ( 677): HAL:Error opening gyro temp scale
E/Sensors ( 677): HAL:Error reading gyro temp scale
E/Sensors ( 677): HAL:error opening gyro temp offset
E/Sensors ( 677): HAL:Error opening accel FSR
I/Sensors ( 677): InvenSense MA 5.1.4
E/MPL-storeload( 677): Cannot open /mnt/factory/mpu/inv_cal_data.bin
E/MPL-storeload( 677): Cannot open file “/inv_cal_data.bin” for read
E/MPL-storeload( 677): Could not load cal file - aborting
E/Sensors ( 677): HAL:Could not open or load MPL calibration file (46)
E/Sensors ( 677): HAL:Couldn’t read gyro mounting matrix
E/Sensors ( 677): HAL:Couldn’t read accel mounting matrix
V/Sensors ( 677): HAL:enable - sensor RotationVector (handle 5) dis → dis
V/Sensors ( 677): HAL:enable - sensor LinearAccel (handle 6) dis → dis
V/Sensors ( 677): HAL:enable - sensor Gravity (handle 7) dis → dis
V/Sensors ( 677): HAL:enable - sensor Gyro (handle 0) dis → dis
V/Sensors ( 677): HAL:enable - sensor Accelerometer (handle 2) dis → dis
V/Sensors ( 677): HAL:enable - sensor MagneticField (handle 3) dis → dis
V/Sensors ( 677): HAL:enable - sensor Orientation (handle 4) dis → dis
D/SensorService( 677): nuSensorService thread starting…
I/SystemServiceManager( 677): Starting com.android.server.pm.Installer
D/SensorService( 677): new thread SensorEventAckReceiver
I/Installer( 677): Waiting for installd to be ready.
I/InstallerConnection( 677): connecting…
I/installd( 159): new connection
I/SystemServiceManager( 677): Starting com.android.server.am.ActivityManagerService$Lifecycle
I/ActivityManager( 677): Memory class: 128
I/ServiceThread( 677): Enabled StrictMode logging for ActivityManager looper.
D/AndroidRuntime( 691): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 691): Shutting down VM
I/IntentFirewall( 677): Read new rules (A:0 B:0 S:0)
I/ServiceThread( 677): Enabled StrictMode logging for android.ui looper.
I/ServiceThread( 677): Enabled StrictMode logging for android.display looper.
D/AppOps ( 677): AppOpsService published
I/SystemServiceManager( 677): Starting com.android.server.power.PowerManagerService
I/ServiceThread( 677): Enabled StrictMode logging for PowerManagerService looper.
W/libsuspend( 677): Error writing ‘on’ to /sys/power/state: Invalid argument
I/libsuspend( 677): Selected wakeup count
I/SystemServiceManager( 677): Starting com.android.server.display.DisplayManagerService
E/BatteryStatsService( 677): Failed to open /sys/kernel/wakeup_reasons/last_resume_reason
I/SystemServiceManager( 677): Starting phase 100
I/DisplayManagerService( 677): Display device added: DisplayDeviceInfo{“Built-in Screen”: 1280 x 720, 60.00163 fps, supportedRefreshRates [60.00163], density 160, 213.0 x 213.0 dpi, appVsyncOff 0, presDeadline 17666214, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer( 677): Package Manager
W/SystemConfig( 677): No directory /system/etc/sysconfig, skipping
W/SystemConfig( 677): Permissions library file /system/etc/permissions/android.hardware.nfc.xml cannot be read
I/CameraService( 158): CameraService started (pid=158)
E/HAL ( 158): load: module=/vendor/lib/hw/camera.tegra.so
E/HAL ( 158): dlopen failed: could not load library “libscf.so” needed by “camera.tegra.so”; caused by library “libscf.so” not found
E/CameraService( 158): Could not load camera HAL module
I/AudioPolicyService( 158): AudioPolicyService CSTOR in new mode
I/NvAudioPolicyManager( 158): createAudioPolicyManager++
I/AudioPolicyManager( 158): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
E/nvaudio_hw( 158): Unknown control ‘Codec VMixer Codec Switch’
E/nvaudio_hw( 158): submix open
I/nvaudiofx( 158): Unable to open /lbh/etc/nvaudio_fx.xml, trying /etc/nvaudio_fx.xml
I/nvoice ( 158): Unable to open /lbh/etc/audioConfig_qvoice_icera_pc400.xml, trying /etc/audioConfig_qvoice_icera_pc400.xml
I/AudioFlinger( 158): loadHwModule() Loaded primary audio interface from Nvidia Audio HW HAL (audio) handle 1
I/AudioFlinger( 158): HAL output buffer size 512 frames, normal sink buffer size 1024 frames
D/SELinuxMMAC( 677): Using policy file /system/etc/security/mac_permissions.xml
I/AudioMixer( 158): found effect “Multichannel Downmix To Stereo” from The Android Open Source Project
E/MonoPipe( 158): Failed to fetch local time frequency when constructing a MonoPipe (res = -32). getNextWriteTimestamp calls will be non-functional
D/AndroidRuntime( 742):
D/AndroidRuntime( 742): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 742): CheckJNI is ON
D/AndroidRuntime( 742): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 742): Shutting down VM
E/art ( 677): DexFile_isDexOptNeeded file ‘/system/framework/com.nvidia.graphics.jar’ does not exist
W/PackageManager( 677): Library not found: /system/framework/com.nvidia.graphics.jar
D/PackageManager( 677): No files in app dir /vendor/overlay
W/ResourceType( 677): Failure getting entry for 0x7f0b01e9 (t=10 e=489) (error -75)
W/PackageParser( 677): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #356
D/AndroidRuntime( 758):
D/AndroidRuntime( 758): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 758): CheckJNI is ON
D/AndroidRuntime( 758): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 758): Shutting down VM
I/wifiloader( 771): ro.wifi.sdmmc property not set, reading from sdmmc0
I/wifiloader( 773): Using for WiFi
E/wifiloader( 776): WiFi card is not available! try 3
W/ResourceType( 677): Failure getting entry for 0x7f08025b (t=7 e=603) (error -75)
D/AndroidRuntime( 787):
D/AndroidRuntime( 787): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 787): CheckJNI is ON
W/PackageParser( 677): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #209
D/AndroidRuntime( 787): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 787): Shutting down VM
W/PackageParser( 677): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #242
W/PackageParser( 677): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #245
D/AndroidRuntime( 801):
D/AndroidRuntime( 801): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 801): CheckJNI is ON
D/AndroidRuntime( 801): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 801): Shutting down VM
W/PackageManager( 677): Failed to parse /system/vendor/app/NvBenchmarkBlocker: Missing base APK in /system/vendor/app/NvBenchmarkBlocker
W/PackageManager( 677): Failed to parse /system/vendor/app/NvCPLSvc: Missing base APK in /system/vendor/app/NvCPLSvc
W/PackageManager( 677): Failed to parse /system/vendor/app/NvCPLUpdater: Missing base APK in /system/vendor/app/NvCPLUpdater
W/PackageManager( 677): Failed to parse /system/vendor/app/QuadDSecurityService: Missing base APK in /system/vendor/app/QuadDSecurityService
D/PackageManager( 677): No files in app dir /oem/app
D/AndroidRuntime( 823):
D/AndroidRuntime( 823): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 823): CheckJNI is ON
D/AndroidRuntime( 823): Calling main entry com.android.commands.pm.Pm
D/AndroidRuntime( 823): Shutting down VM
E/wifiloader( 836): WiFi auto card detection fail
I/wifiloader( 838): persist.sys.commchip_vendor not defined. Reading enumerated data
I/wifiloader( 843): mobile device is detected
I/SELinux ( 677): SELinux: Loaded file_contexts from /file_contexts
D/PackageManager( 677): No files in app dir /data/app-private
W/PackageManager( 677): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 677): Adjusting ABI for : com.android.location.fused to armeabi-v7a
I/PackageManager( 677): Adjusting ABI for : com.android.settings to armeabi-v7a
I/PackageManager( 677): Adjusting ABI for : com.android.keychain to armeabi-v7a
I/PackageManager( 677): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
I/PackageManager( 677): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
I/PackageManager( 677): Time to scan packages: 3.31 seconds
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 677): Unknown permission com.htc.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.htc.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Not granting permission android.permission.WRITE_APN_SETTINGS to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Unknown permission com.google.android.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Not granting permission android.permission.READ_LOGS to package com.qihoo.appstore (protectionLevel=50 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.INSTALL_PACKAGES to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.DELETE_PACKAGES to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.CLEAR_APP_USER_DATA to package com.qihoo.appstore (protectionLevel=2 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.ACCESS_CACHE_FILESYSTEM to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.CHANGE_CONFIGURATION to package com.qihoo.appstore (protectionLevel=50 flags=0x483e44)
W/PackageManager( 677): Unknown permission com.nd.android.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Not granting permission com.android.launcher.permission.WRITE_SETTINGS to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.DEVICE_POWER to package com.qihoo.appstore (protectionLevel=2 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.BATTERY_STATS to package com.qihoo.appstore (protectionLevel=50 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Unknown permission com.android.launcher3.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.android.launcher3.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.yulong.android.launcherL.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.zte.mifavor.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.lenovo.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.sonyericsson.home.permission.BROADCAST_BADGE in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.huawei.android.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.huawei.android.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.oppo.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.oppo.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.qiku.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.qiku.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.yulong.android.launcher3.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.yulong.android.launcher3.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.sonyericsson.home.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.sonyericsson.home.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission android.permission.RECORD_VIDEO in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.meizu.flyme.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.meizu.flyme.launcher.permission.WRITE_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.android.launcher2.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission org.adw.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.qihoo360.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.lge.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission net.qihoo.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission org.adwfreak.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission org.adw.launcher_donut.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.huawei.launcher3.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.fede.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.sec.android.app.twlauncher.settings.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.tencent.qqlauncher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.huawei.launcher2.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.ebproductions.android.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.nd.android.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.bbk.launcher2.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.yulong.android.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.android.mylauncher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission telecom.mdesk.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.ztemt.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission cn.nubia.launcher.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission dianxin.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission android.permission.ACCESS_COARSE_UPDATES in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission qiku.permission.RECEIVE_ACTIVITY_RESUMED in package com.qihoo.appstore
W/PackageManager( 677): Not granting permission android.permission.BIND_ACCESSIBILITY_SERVICE to package com.qihoo.appstore (protectionLevel=2 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.FORCE_STOP_PACKAGES to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.qihoo.appstore (protectionLevel=50 flags=0x483e44)
W/PackageManager( 677): Unknown permission android.permission.ACCESS_MTK_MMHW in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission yulong.permission.ACCESS_YLPARAMS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission qiku.permission.ACCESS_QKPARAMS in package com.qihoo.appstore
W/PackageManager( 677): Not granting permission android.permission.MANAGE_USERS to package com.qihoo.appstore (protectionLevel=18 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.INTERACT_ACROSS_USERS_FULL to package com.qihoo.appstore (protectionLevel=2 flags=0x483e44)
W/PackageManager( 677): Not granting permission android.permission.INTERACT_ACROSS_USERS to package com.qihoo.appstore (protectionLevel=50 flags=0x483e44)
W/PackageManager( 677): Unknown permission android.permission.RECEIVE_USER_PRESENT in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission qiku.permission.READ_WRITE_SAFE_SPACE in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission android.webkit.permission.PLUGIN in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission android.permission.READ_SETTINGS in package com.qihoo.appstore
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 677): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager( 677): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x58bc45)
W/PackageManager( 677): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 677): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
W/PackageManager( 677): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
W/PackageManager( 677): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager( 677): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 677): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager( 677): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 677): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
I/art ( 677): Explicit concurrent mark sweep GC freed 7345(558KB) AllocSpace objects, 2(32KB) LOS objects, 33% free, 4MB/6MB, paused 576us total 22.715ms
I/SystemServer( 677): User Service
I/lowmemorykiller( 137): ActivityManager connected
I/SystemServiceManager( 677): Starting com.android.server.lights.LightsService
I/SystemServiceManager( 677): Starting com.android.server.BatteryService
I/SystemServiceManager( 677): Starting com.android.server.usage.UsageStatsService
I/SystemServiceManager( 677): Starting com.android.server.webkit.WebViewUpdateService
I/SystemServer( 677): Reading configuration…
I/SystemServer( 677): Scheduling Policy
I/SystemServer( 677): Telephony Registry
I/SystemServer( 677): Entropy Mixer
I/EntropyMixer( 677): Writing entropy…
I/SystemServer( 677): Account Manager
I/SystemServer( 677): Content Manager
I/SystemServer( 677): System Content Providers
W/ActivityManager( 677): Can’t addPackageDependency on system process
W/CoreSettingsObserver( 677): Cannot find setting “debug_view_attributes”
W/CoreSettingsObserver( 677): android.provider.Settings$SettingNotFoundException: debug_view_attributes
W/CoreSettingsObserver( 677): at android.provider.Settings$Global.getInt(Settings.java:6735)
W/CoreSettingsObserver( 677): at com.android.server.am.CoreSettingsObserver.populateSettings(CoreSettingsObserver.java:129)
W/CoreSettingsObserver( 677): at com.android.server.am.CoreSettingsObserver.sendCoreSettings(CoreSettingsObserver.java:82)
W/CoreSettingsObserver( 677): at com.android.server.am.CoreSettingsObserver.(CoreSettingsObserver.java:65)
W/CoreSettingsObserver( 677): at com.android.server.am.ActivityManagerService.installSystemProviders(ActivityManagerService.java:9849)
W/CoreSettingsObserver( 677): at com.android.server.SystemServer.startOtherServices(SystemServer.java:452)
W/CoreSettingsObserver( 677): at com.android.server.SystemServer.run(SystemServer.java:256)
W/CoreSettingsObserver( 677): at com.android.server.SystemServer.main(SystemServer.java:170)
W/CoreSettingsObserver( 677): at java.lang.reflect.Method.invoke(Native Method)
W/CoreSettingsObserver( 677): at java.lang.reflect.Method.invoke(Method.java:372)
W/CoreSettingsObserver( 677): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
W/CoreSettingsObserver( 677): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
I/SystemServer( 677): Vibrator Service
I/SystemServer( 677): Consumer IR Service
E/ConsumerIrService( 677): Can’t open consumer IR HW Module, error: -2
I/SystemServiceManager( 677): Starting com.android.server.AlarmManagerService
I/SystemServer( 677): Init Watchdog
I/SystemServer( 677): Input Manager
I/InputManager( 677): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer( 677): Window Manager
I/WindowManager( 677): No existing display settings /data/system/display_settings.xml; starting empty
D/PermissionCache( 140): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (794 us)
I/AudioFlinger( 158): Using module 1 has the primary audio interface
I/AudioFlinger( 158): AudioFlinger’s thread 0xb3c24000 ready to run
I/AudioFlinger( 158): AudioFlinger’s thread 0xb3cb6000 ready to run
I/audio_a2dp_hw( 158): adev_open: adev_open in A2dp_hw module
I/AudioFlinger( 158): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 4
E/SoundTriggerHwService( 158): couldn’t load sound trigger module sound_trigger.primary (No such file or directory)
I/InputManager( 677): Starting input manager
I/EventHub( 677): New device: id=1, fd=85, path=‘/dev/input/event0’, name=‘touch’, classes=0x14, configuration=‘/system/usr/idc/touch.idc’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub( 677): No input device configuration file found for device ‘gpio-keys.3’.
I/SystemServer( 677): Bluetooth Manager Service
D/BluetoothManagerService( 677): Loading stored name and address
D/BluetoothManagerService( 677): Stored bluetooth Name=wx_na_wf,Address=22:22:9C:78:21:0C
I/SystemServer( 677): Input Method Service
W/EventHub( 677): Unable to disable kernel key repeat for /dev/input/event2: Function not implemented
I/EventHub( 677): New device: id=2, fd=86, path=‘/dev/input/event2’, name=‘gpio-keys.3’, classes=0x1, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub( 677): No input device configuration file found for device ‘tegra-rt5639 Headphone Jack’.
I/EventHub( 677): New device: id=3, fd=87, path=‘/dev/input/event1’, name=‘tegra-rt5639 Headphone Jack’, classes=0x80, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
W/InputMethodManagerService( 677): Couldn’t create dir.: /data/system/inputmethod
D/AndroidRuntime( 849):
D/AndroidRuntime( 849): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
I/InputReader( 677): Device added: id=-1, name=‘Virtual’, sources=0x00000301
I/InputReader( 677): Device added: id=3, name=‘tegra-rt5639 Headphone Jack’, sources=0x80000000
I/InputReader( 677): Device added: id=2, name=‘gpio-keys.3’, sources=0x00000101
W/InputReader( 677): Invalid value for touch.size.calibration: ‘normalized’
D/AndroidRuntime( 849): CheckJNI is ON
I/InputReader( 677): Touch device ‘touch’ could not query the properties of its associated display. The device will be inoperable until the display size becomes available.
I/InputReader( 677): Device added: id=1, name=‘touch’, sources=0x00005002
I/SystemServer( 677): Accessibility Manager
I/ActivityManager( 677): Config changes=1df8 {1.0 ?mcc?mnc en_US ldltr sw720dp w1280dp h720dp 160dpi xlrg long land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
I/InputReader( 677): Reconfiguring input devices. changes=0x00000004
I/InputReader( 677): Device reconfigured: id=1, name=‘touch’, size 1280x720, orientation 0, mode 1, display id 0
I/UsageStatsService( 677): User[0] Rollover scheduled @ 2000-01-02 00:00:00(946771200000)
I/ActivityManager( 677): Config changes=508 {1.0 ?mcc?mnc en_US ldltr sw720dp w1280dp h647dp 160dpi lrg long land ?uimode ?night finger -keyb/v/h -nav/h s.3}
I/SystemServer( 677): Mount Service
D/MountService( 677): got storage path: /storage/sdcard0 description: Internal storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService( 677): addVolumeLocked() StorageVolume:
D/MountService( 677): mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040782
D/MountService( 677): mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService( 677): mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService( 677): mUserLabel=null mState=null
D/MountService( 677): got storage path: /storage/sdcard1 description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 677): mStorageId=0 mPath=/storage/sdcard1 mDescriptionId=17040783 mPrimary=false
D/MountService( 677): mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService( 677): mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService( 677): got storage path: /storage/usbdrive description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 677): mStorageId=0 mPath=/storage/usbdrive mDescriptionId=17040784
D/MountService( 677): mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=0
D/MountService( 677): mAllowMassStorage=false mMaxFileSize=0 mOwner=null mUuid=null
I/SystemServer( 677): LockSettingsService
I/SystemServiceManager( 677): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
I/SystemServer( 677): Status Bar
I/SystemServer( 677): Clipboard Service
D/MountService( 677): volume state changed for /storage/sdcard1 (unmounted → removed)
D/MountService( 677): volume state changed for /storage/usbdrive (unmounted → removed)
I/SystemServer( 677): NetworkManagement Service
I/PackageManager( 677): No secure containers found
I/SystemServer( 677): Text Service Manager Service
W/PackageManager( 677): Not granting permission android.permission.WRITE_APN_SETTINGS to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.READ_LOGS to package com.qihoo.appstore (protectionLevel=50 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.INSTALL_PACKAGES to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.DELETE_PACKAGES to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.CLEAR_APP_USER_DATA to package com.qihoo.appstore (protectionLevel=2 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.ACCESS_CACHE_FILESYSTEM to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.CHANGE_CONFIGURATION to package com.qihoo.appstore (protectionLevel=50 flags=0xc83e44)
W/PackageManager( 677): Not granting permission com.android.launcher.permission.WRITE_SETTINGS to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.DEVICE_POWER to package com.qihoo.appstore (protectionLevel=2 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.BATTERY_STATS to package com.qihoo.appstore (protectionLevel=50 flags=0xc83e44)
W/PackageManager( 677): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.qihoo.appstore (protectionLevel=18 flags=0xc83e44)
