Hi, nice to meet you.
TK-1 In the manual, it is set to 3840x2160(60Hz).
but I proceeded because I needed to drive it with 3840x2400(60hz).
When the pixel clock is 572MHz, it operates, but it is not a normal operation.
ㄴ The flickering phenomenon will come out constantly.
When the pixel clock is less than 490MHz(51Hz), it operates normally.
I checked the normal operation from 3840x2160 (60 Hz) to 600Mhz
There is no problem with speed, but I am curious how the effect of resolution is applied.
I would appreciate it if you let me know.
