Effects_demo.exe getSupportedDevices failed with NVAFX_STATUS_FAILED on RTX 3090
Hello NVIDIA team and community,
I’m currently evaluating the NVIDIA Maxine AFX SDK (version 2.1.0.9) on a Windows 10 machine. I’ve successfully compiled the effects_demo sample from the SDK, but when I run it, it fails during GPU device enumeration with the following error:
text
[E] Denoiser Version 1 getSupportedDevices failed .
[INFO] Could not get number of supported devices with error: NVAFX_STATUS_FAILED
This happens regardless of the effect I try (e.g., denoiser or dereverb_denoiser).
System details:
  • GPU: NVIDIA GeForce RTX 3090 (Ampere architecture)
  • NVIDIA Driver: 610.62 (WDDM mode)
  • CUDA Runtime: 12.8 (installed as standalone runtime only; no development tools)
  • TensorRT: 10.7.0.23 (Windows ZIP package)
  • Maxine AFX SDK: 2.1.0.9
  • Visual Studio: 2019 Community (MSVC 14.29)
  • OS: Windows 10 Pro 64‑bit (build 19045)
What I’ve already tried:
  1. Set environment variables:
    • AFX_SDK_ROOT (pointing to the SDK root)
    • CUDA_PATH (pointing to CUDA 12.8 installation)
    • CUDA_VISIBLE_DEVICES=0
    • TENSORRT_ROOT (pointing to TensorRT 10.7.0 directory)
    • Added %CUDA_PATH%\bin and %TENSORRT_ROOT%\lib to PATH
  2. Copied all required DLLs into the same folder as effects_demo.exe:
    • All CUDA 12.8 *64*.dll files from C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\bin
    • All TensorRT 10.7.0 DLLs from TensorRT-10.7.0.23\lib
    • Also copied NVAudioEffects.dll and nvafxdenoiser.dll (and its dependencies)
  3. Verified CUDA installation with deviceQuery.exe – it successfully detects the RTX 3090 and reports Result = PASS.
  4. Checked that the model files are present:
    • nvafxdenoiser/models/ampere/ contains the expected model files.
  5. Tried switching the configuration to dereverb_denoiser – same error occurs.
Additional diagnostics:
  • Output of nvidia-smi shows the GPU is recognised and driver version is correct.
  • dumpbin /dependents nvafxdenoiser.dll lists all dependencies, and I’ve confirmed they are present.
  • The config.txt used is:
    text
    effect denoiser
    model ./features/nvafxdenoiser
    input_wav D:/input.wav
    output_wav D:/output.wav
    real_time 0
    intensity_ratio 1.0
    input_sample_rate 48000
    output_sample_rate 48000
    enable_vad 0
Question:
What could be causing NvAFX_GetSupportedDevices to return NVAFX_STATUS_FAILED even though deviceQuery passes successfully?
  • Is there a specific version of TensorRT that is strictly required for Maxine SDK 2.1.0.9?
  • Does the SDK require any additional CUDA components (e.g., cuDNN, NVML) that I might have missed?
  • Could the issue be related to the WDDM driver mode vs. TCC mode? Or any other environment settings I should check?
Any help would be greatly appreciated. I can provide full logs or any other diagnostic output if needed.
Thank you!
