Efficient Coding in main()
The following code performs scaning. Can anybody tell me what further modifications can be done in the host code main(), without bothering about the improvements in the Kernel?
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <float.h>
// includes, project
//#include <cutil_inline.h>
#include<cuda.h>
#include<cuda_runtime.h>
#ifndef _SCAN_BEST_KERNEL_H_
#define _SCAN_BEST_KERNEL_H_
#define NUM_BANKS 16
#define LOG_NUM_BANKS 4
// Define this to more rigorously avoid bank conflicts, even at the lower (root) levels of the tree
//#define ZERO_BANK_CONFLICTS
#ifdef ZERO_BANK_CONFLICTS
#define CONFLICT_FREE_OFFSET(index) ((index) >> LOG_NUM_BANKS + (index) >> (2 * LOG_NUM_BANKS))
#else
#define CONFLICT_FREE_OFFSET(index) ((index) >> LOG_NUM_BANKS)
#endif
#ifdef CHECK_BANK_CONFLICTS
#define TEMP(index)   cutilBankChecker(temp, index)
#else
#define TEMP(index)   temp[index]
#endif
__global__ void scan_best(float *g_odata, float *g_idata, int n)
	// Dynamically allocated shared memory for scan kernels
	extern  __shared__  float temp[];
	int thid = threadIdx.x;
	int ai = thid;
	int bi = thid + (n/2);
	// compute spacing to avoid bank conflicts
	int bankOffsetA = CONFLICT_FREE_OFFSET(ai);
	int bankOffsetB = CONFLICT_FREE_OFFSET(bi);
	// Cache the computational window in shared memory
	TEMP(ai + bankOffsetA) = g_idata[ai];
	TEMP(bi + bankOffsetB) = g_idata[bi];
	int offset = 1;
	// build the sum in place up the tree
	for (int d = n/2; d > 0; d >>= 1)
		__syncthreads();
		if (thid < d)
			int ai = offset*(2*thid+1)-1;
			int bi = offset*(2*thid+2)-1;
			ai += CONFLICT_FREE_OFFSET(ai);
			bi += CONFLICT_FREE_OFFSET(bi);
			TEMP(bi) += TEMP(ai);
		offset *= 2;
	// scan back down the tree
	// clear the last element
	if (thid == 0)
		int index = n - 1;
		index += CONFLICT_FREE_OFFSET(index);
		TEMP(index) = 0;
	// traverse down the tree building the scan in place
	for (int d = 1; d < n; d *= 2)
		offset /= 2;
		__syncthreads();
		if (thid < d)
			float t  = TEMP(ai);
			TEMP(ai) = TEMP(bi);
			TEMP(bi) += t;
	__syncthreads();
	// write results to global memory
	g_odata[ai] = TEMP(ai + bankOffsetA);
	g_odata[bi] = TEMP(bi + bankOffsetB);
#endif // #ifndef _SCAN_BEST_KERNEL_H_
//WHAT IMPROVEMENT CAN BE DONE HERE ONWARD?
int  main()
int n; //Number of data elements
cudaEvent_t start,stop;
cudaEventCreate(&start);
cudaEventCreate(&stop);
n=8;
size_t size=sizeof(int)*n;
float *g_odata, *g_idata, *m_odata, *m_idata;
m_idata=(float*)malloc(size);
m_odata=(float*)malloc(size);
cudaMalloc((void**)&g_idata,size);
cudaMalloc((void**)&g_odata,size);
// g-->global memory, m--> main memory
//allocate pointer in main memory
//allocate pointer in device memory
for(i=0; i<7; i++)
scanf("%f", &m_idata[i]);
cudaMemcpy(g_idata,m_idata,size,cudaMemcpyHostToDevice);
//copy the data m_idata from main memory into g_idata in device using cudaMemcpy
//Kernel Configuration: specifying the number of threads per block Nt and number of blocks per grid Nb
cudaEventRecord(start,0);
scan_best<<< 1, 10 >>>(g_odata, g_idata, n);//Call the kernel
cudaThreadSynchronize();
cudaEventRecord(stop,0);
cudaEventSynchronize(stop);
float elapsedTime;
cudaEventElapsedTime(&elapsedTime,start,stop);
printf("Processing time=%f(ms)\n",elapsedTime);
//copy the data g_odata from device global memory into m_odata in main memory using cudaMemcpy
cudaMemcpy(m_odata,g_odata,size,cudaMemcpyDeviceToHost);
// print m_odata
for(int i=0;i<n;i++)
	printf("\n%f",m_odata[i]);
cudaFree(g_idata);
cudaFree(g_odata);
free(m_idata);
free(m_odata);
cudaEventDestroy(start);
cudaEventDestroy(stop);
From an efficiency point of view, learn to type faster, I guess. The scanf loop will surely be the slowest part of that entire code, both on the host and the device.
Thanks for the quick reply :)
Well, then how do I enter the data in my input array. In this case one solution for eliminating for loop could be:
m_idata[0]=0;
m_idata[1]=1;
m_idata[2]=2;
m_idata[3]=3;
m_idata[4]=4;
m_idata[5]=5;
m_idata[6]=6;
m_idata[7]=7;
But what if I have 1 million elements or probably 1 billion :)
That is a completely different question to what you originally asked. You post a code which read 7 floats from stdin and then launches a kernel with 10 threads and you expect a serious answer about computational efficiency for millions of data points?
If you are working with really large datasets, then switch to an optimised binary file format like HDF5, which provides high performance out of core access to large datasets. 1 billion data points is impossible on any current GPU (the Telsa C1060/S1070 only has 4Gb per device), so you will need to devise a scheme to partition your dataset into segments and process them separately.
Thanks once again Avidday!!!
Well, for the particular code that I have posted, is the loop unrolling best strategy as follows?:
m_idata[0]=0;
m_idata[1]=1;
m_idata[2]=2;
m_idata[3]=3;
m_idata[4]=4;
m_idata[5]=5;
m_idata[6]=6;
m_idata[7]=7;
or there can be any other way for this small set of data?
For 7 values, who cares? You won’t be able to measure the difference in execution time. If it were in a loop which is called millions of times, that might be different. You could write that main program in python using scipy and there would be no appreciable difference run time.
If there is a serious question in here somewhere, just ask it…
