硬件上MCU的外围电路与参考板电路一致,并从 Log in | NVIDIA Developer 中下载了对应的工程文件。按照readme步骤操作后,最后的烧录总是会报错,如下图。
SILICON LABS目前的回复并没有碰到过如此问题,请问NV是否遇到过如此问题,或者能提出些建议,谢谢。
Did not meet such issue. What is your hardware connection during flashing?
复制的P3737 carrier board里MCU的电路。
I mean the connection of your adapter ( USB debug adapter) to MCU.
这个是官方提供的烧录器。
Can you repro this on Orin devkit? Not sure what the cause is. Maybe you can check if same settings can work with devkit first.
我手里有AGX orin的开发套件,并且将两个单片机互换并且烧录程序,结果AGX orin开发套件也无法完成上电。AGX orin开发套件中的MCU的上电程序与 Log in | NVIDIA Developer是一致的吗?
So Orin devkit can be flashed with your setting before? That looks like your custom design or phy chip issue.
可是开发套件中MCU的上电程序不应该跟 Log in | NVIDIA Developer中的一样吗?为什么Orin开发套件烧录后上电就不可以了呢?
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
