May I have installed libraries that could potentially interfere with EGL libraries?
I have used the 4.1.8.0 DriveInstall but my vibrante installation is not a fresh install anymore.
Do you have some hints? some trails to explore? some tests to check?
Could you please flash your DPX2 system with the 4.1.8.0 DriveInstall?
If your system(DPX2 AutoChauffeur) PDK version is Beta 3.0 and Aurix FW version is 2.02.04, the command should be run on DPX2. Thanks.
I used a wrong libEGL.so, indeed I used the one inside the /usr/lib/aarch64-linux-gnu folder instead of the one in /usr/lib folder. This happened because I set my LD_LIBRARY_PATH as follow:
