I want to benchmark the EGL_IMG_context_priority
extension on the Nvidia Linux driver (Tesla T4, Driver Version: 545.29.02). I wrote a program that creates threads with high-priority contexts, rendering at 30 FPS. I also created another program with threads running low-priority contexts, also drawing at 30 FPS.
During benchmarking, I noticed that both programs run at the same FPS, and context priority doesn’t seem to affect performance.
Am I missing something in the implementation or testing process? Any insights would be appreciated. The sample code is attached.
opengl_priority_benchmarking.zip (4.9 KB)
sudo apt update
sudo apt install g++
sudo apt install libegl1-mesa-dev
g++ test.cpp -lEGL -lGL -o test
#include <EGL/egl.h>
#include <EGL/eglext.h>
#include <GLES3/gl32.h>
#include <iostream>
#include <cstring>
#include <unistd.h>
#include <vector>
#include <thread>
#include <chrono>
#include <atomic>
#include <mutex>
#include <sstream>
#define EGL_CONTEXT_PRIORITY_HIGH_IMG 0x3101
#define EGL_CONTEXT_PRIORITY_MEDIUM_IMG 0x3102
#define EGL_CONTEXT_PRIORITY_LOW_IMG 0x3103
thread_local GLuint programObject = 0;
thread_local GLint texture_location = -1;
EGLDisplay display_;
EGLConfig config;
thread_local EGLSurface surface_;
const int width = 900;
const int height = 1600;
std::atomic<bool> running(true);
std::vector<std::atomic<double>> averageFps(500); // Atomic FPS storage for each thread
std::mutex fpsMutex; // Mutex to protect access to averageFps
void printOpenGLInfo(int threadId)
const GLubyte* vendor = glGetString(GL_VENDOR);
const GLubyte* renderer = glGetString(GL_RENDERER);
const GLubyte* version = glGetString(GL_VERSION);
const GLubyte* glslVersion = glGetString(GL_SHADING_LANGUAGE_VERSION);
//std::cout << "Vendor: " << vendor << ", for thread: " << threadId << std::endl;
//std::cout << "Renderer: " << renderer << std::endl;
//std::cout << "OpenGL Version: " << version << std::endl;
//std::cout << "GLSL Version: " << glslVersion << std::endl;
<< " (Thread ID: " << std::this_thread::get_id() << ")"
<< std::endl;
GLuint LoadShader(GLenum type, const GLbyte *shaderSrc)
GLuint shader;
GLint compiled;
shader = glCreateShader(type);
if(shader == 0)
return 0;
GLchar* shSrc = (GLchar*)shaderSrc;
glShaderSource(shader, 1, &shSrc, NULL);
glCompileShader(shader);
glGetShaderiv(shader, GL_COMPILE_STATUS, &compiled);
if(!compiled)
GLint infoLen = 0;
glGetShaderiv(shader, GL_INFO_LOG_LENGTH, &infoLen);
if(infoLen > 1)
char* infoLog = (char*)malloc(sizeof(char) * infoLen);
glGetShaderInfoLog(shader, infoLen, NULL, infoLog);
printf("Error compiling shader:\n%s\n", infoLog);
free(infoLog);
glDeleteShader(shader);
return 0;
return shader;
// Draw a simple triangle
#if 0
int Init(int threadId)
printOpenGLInfo(threadId);
GLbyte vShaderStr[] =
"#version 320 es\n"
"layout(location = 0) in vec4 vPosition;\n"
"void main() {\n"
" gl_Position = vPosition;\n"
"}\n";
GLbyte fShaderStr[] =
"#version 320 es\n"
"precision mediump float;\n"
"out vec4 FragColor;\n"
"void main() {\n"
" FragColor = vec4(0.0, 1.0, 0.0, 1.0);\n" // Green color
"}\n";
GLuint vertexShader;
GLuint fragmentShader;
GLint linked;
vertexShader = LoadShader(GL_VERTEX_SHADER, vShaderStr);
fragmentShader = LoadShader(GL_FRAGMENT_SHADER, fShaderStr);
programObject = glCreateProgram();
if (programObject == 0) {
return 0;
glAttachShader(programObject, vertexShader);
glAttachShader(programObject, fragmentShader);
glBindAttribLocation(programObject, 0, "vPosition");
glLinkProgram(programObject);
glGetProgramiv(programObject, GL_LINK_STATUS, &linked);
if (!linked)
GLint infoLen = 0;
glGetProgramiv(programObject, GL_INFO_LOG_LENGTH, &infoLen);
if(infoLen > 1)
glGetProgramInfoLog(programObject, infoLen, NULL, infoLog);
printf("Error linking program:\n%s\n", infoLog);
free(infoLog);
glDeleteProgram(programObject);
return false;
texture_location = glGetUniformLocation(programObject, "tex");
GLuint vbo, ibo;
glGenBuffers(1, &vbo);
glBindBuffer(GL_ARRAY_BUFFER, vbo);
GLfloat vertexData[] = {
0.0f, 0.5f, 0.0f, // Vertex 1 (X, Y)
-0.5f, -0.5f, 0.0f, // Vertex 2 (X, Y)
0.5f, -0.5f, 0.0f // Vertex 3 (X, Y)
glBufferData(GL_ARRAY_BUFFER, sizeof(vertexData), vertexData, GL_STATIC_DRAW);
glEnableVertexAttribArray(0);
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, 3 * sizeof(GLfloat), (char*)0 + 0 * sizeof(GLfloat));
glClearColor(0.0f, 0.0f, 0.0f, 1.0f);
return true;
void Draw()
glClear(GL_COLOR_BUFFER_BIT);
glUseProgram(programObject);
glDrawArrays(GL_TRIANGLES, 0, 3);
eglSwapBuffers(display_, surface_);
// check for errors
GLenum error = glGetError();
if(error != GL_NO_ERROR) {
std::cout << error << std::endl;
#endif
// Draw a fullscreen quad with texture
// Print OpenGL information
// Vertex Shader source code
"#version 320 es\n"
"layout(location = 0) in vec4 vposition;\n"
"layout(location = 1) in vec2 vtexcoord;\n"
"out vec2 ftexcoord;\n"
"void main() {\n"
" ftexcoord = vtexcoord;\n"
" gl_Position = vposition;\n"
"}\n";
// Fragment Shader source code
"#version 320 es\n"
"precision highp float;\n"
"uniform sampler2D tex;\n"
"in vec2 ftexcoord;\n"
"layout(location = 0) out vec4 FragColor;\n"
"void main() {\n"
" FragColor = texture(tex, ftexcoord);\n"
"}\n";
GLuint vertexShader, fragmentShader;
GLint linked;
// Load and compile vertex and fragment shaders
// Create and link the shader program
return 0;
// Bind the attributes
glBindAttribLocation(programObject, 1, "vTexcoord");
// Check program link status
if (!linked)
GLint infoLen = 0;
if (infoLen > 1)
char *infoLog = (char *)malloc(sizeof(char) * infoLen);
free(infoLog);
return false;
// Get the location of the texture uniform
GLuint vbo, ibo;
// Generate and bind the vertex buffer object (VBO)
// Data for a fullscreen quad with texture coordinates
// X, Y, Z, U, V
1.0f, 1.0f, 0.0f, 1.0f, 1.0f, // vertex 0
-1.0f, 1.0f, 0.0f, 0.0f, 1.0f, // vertex 1
1.0f, -1.0f, 0.0f, 1.0f, 0.0f, // vertex 2
-1.0f, -1.0f, 0.0f, 0.0f, 0.0f // vertex 3
// Fill the VBO with data
// Set up vertex attribute pointers
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, 5 * sizeof(GLfloat), (char *)0);
glEnableVertexAttribArray(1);
glVertexAttribPointer(1, 2, GL_FLOAT, GL_FALSE, 5 * sizeof(GLfloat), (char *)0 + 3 * sizeof(GLfloat));
// Generate and bind the index buffer object (IBO)
glGenBuffers(1, &ibo);
glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, ibo);
GLuint indexData[] = {
0, 1, 2, 2, 1, 3 // two triangles
// Fill the IBO with data
glBufferData(GL_ELEMENT_ARRAY_BUFFER, sizeof(indexData), indexData, GL_STATIC_DRAW);
// Clear color
return true;
void Draw(int threadId)
GLuint texture;
// Generate and bind a new texture
glGenTextures(1, &texture);
glBindTexture(GL_TEXTURE_2D, texture);
// Create some image data (simple pattern)
#if 0
std::vector<GLubyte> image(4 * width * height);
for (int j = 0; j < height; ++j) {
for (int i = 0; i < width; ++i) {
size_t index = j * width + i;
image[4 * index + 0] = 0xFF * (j / 10 % 2) * (i / 10 % 2); // R
image[4 * index + 1] = 0xFF * (j / 13 % 2) * (i / 13 % 2); // G
image[4 * index + 2] = 0xFF * (j / 17 % 2) * (i / 17 % 2); // B
image[4 * index + 3] = 0xFF; // A
#else
std::vector<GLubyte> image(4 * width * height, 0xFF);
#endif
// Set texture parameters
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
// Set the texture content
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, width, height, 0, GL_RGBA, GL_UNSIGNED_BYTE, image.data());
// Clear the color buffer
// Use the shader program
// Bind texture to texture unit 0
glActiveTexture(GL_TEXTURE0);
// Set texture uniform (the texture is bound to texture unit 0)
glUniform1i(texture_location, 0);
// Draw the quad
glDrawElements(GL_TRIANGLES, 6, GL_UNSIGNED_INT, 0);
// Unbind the texture
glBindTexture(GL_TEXTURE_2D, 0);
// Swap buffers
// Clean up by deleting the texture (optional)
glDeleteTextures(1, &texture);
void DrawThread(int threadId, EGLint priority, int fps)
static const EGLint pbufAttribs[] = {
EGL_WIDTH, width,
EGL_HEIGHT, height,
EGL_NONE
surface_ = eglCreatePbufferSurface(display_, config, pbufAttribs);
if (surface_ == EGL_NO_SURFACE) {
std::cout << "eglCreatePbufferSurface failed" << std::endl;
return;
// Set context priority
static const EGLint contextAttribs[] = {
EGL_CONTEXT_CLIENT_VERSION, 3,
EGL_CONTEXT_PRIORITY_LEVEL_IMG, priority,
EGL_NONE
EGLContext context_;
context_ = eglCreateContext(display_, config, EGL_NO_CONTEXT, contextAttribs);
if (context_ == EGL_NO_CONTEXT) {
std::cout << "eglCreateContext failed for thread " << threadId << std::endl;
return;
#if 1
// Check the priority of the context
EGLint contextPriority;
eglQueryContext(display_, context_, EGL_CONTEXT_PRIORITY_LEVEL_IMG, &contextPriority);
std::cout << "Priority level : 0x" << std::hex << contextPriority << ", for thread " << threadId << std::endl;
#endif
if (!eglMakeCurrent(display_, surface_, surface_, context_)) {
EGLint error = eglGetError();
std::cout << "eglMakeCurrent failed for thread " << threadId << std::endl;
std::cout << "EGL Error: 0x" << std::hex << error << std::endl;
return;
if (!Init(threadId)) {
std::cout << "Initialization failed for thread " << threadId << std::endl;
return;
auto startTime = std::chrono::high_resolution_clock::now();
int localFrameCount = 0;
while (running) {
// Measure time before Draw()
auto drawStart = std::chrono::high_resolution_clock::now();
Draw(threadId);
localFrameCount++;
// Measure time after Draw()
auto drawEnd = std::chrono::high_resolution_clock::now();
// Calculate time taken by Draw() in milliseconds
std::chrono::duration<double, std::milli> drawTime = drawEnd - drawStart;
double drawTimeMs = drawTime.count();
//std::cout << "Draw Time: " << drawTimeMs <<" for thread " << threadId << std::endl;
// Calculate remaining time to sleep
double targetFrameTime = 1000.0 / fps;
double sleepTime = targetFrameTime - drawTimeMs;
if (sleepTime > 0) {
std::this_thread::sleep_for(std::chrono::duration<double, std::milli>(sleepTime));
// Calculate FPS every second
auto currentTime = std::chrono::high_resolution_clock::now();
std::chrono::duration<double> elapsed = currentTime - startTime;
if (elapsed.count() >= 1.0) {
double threadFps = localFrameCount / elapsed.count();
std::lock_guard<std::mutex> lock(fpsMutex);
averageFps[threadId] = threadFps;
//std::cout << "\nThread " << threadId << " - Average FPS: " << threadFps << std::endl;
startTime = currentTime;
eglMakeCurrent(display_, EGL_NO_SURFACE, EGL_NO_SURFACE, EGL_NO_CONTEXT);
if (context_ != EGL_NO_CONTEXT)
eglDestroyContext(display_, context_);
void calculateAverageFps(int threadCount) {
std::cout << "calculateAverageFps called" << std::endl;
while (true) {
std::this_thread::sleep_for(std::chrono::seconds(1));
// Calculate average FPS from all threads
double totalFps = 0.0;
//std::stringstream fpsString;
for (int i = 0; i < threadCount; ++i) {
totalFps += averageFps[i];
//fpsString << averageFps[i];
//if (i < threadCount - 1) {
// fpsString << ", ";
// Print the comma-separated string of FPS values
//std::cout << "\nFPS values: " << fpsString.str() << std::endl;
double avgFps = totalFps / threadCount;
std::cout << "Average FPS across " << threadCount << " threads: " << avgFps << std::endl << std::endl;
void initOpengl()
PFNEGLQUERYDEVICESEXTPROC eglQueryDevicesEXT = (PFNEGLQUERYDEVICESEXTPROC)eglGetProcAddress("eglQueryDevicesEXT");
PFNEGLQUERYDEVICEATTRIBEXTPROC eglQueryDeviceAttribEXT = (PFNEGLQUERYDEVICEATTRIBEXTPROC)eglGetProcAddress("eglQueryDeviceAttribEXT");
PFNEGLQUERYDEVICESTRINGEXTPROC eglQueryDeviceStringEXT = (PFNEGLQUERYDEVICESTRINGEXTPROC)eglGetProcAddress("eglQueryDeviceStringEXT");
PFNEGLGETPLATFORMDISPLAYEXTPROC eglGetPlatformDisplayEXT = (PFNEGLGETPLATFORMDISPLAYEXTPROC)eglGetProcAddress("eglGetPlatformDisplayEXT");
if (!eglQueryDevicesEXT || !eglQueryDeviceAttribEXT || !eglQueryDeviceStringEXT || !eglGetPlatformDisplayEXT) {
std::cout << "Failed to load required EGL extensions." << std::endl;
return;
EGLint numDevices;
eglQueryDevicesEXT(0, nullptr, &numDevices);
std::vector<EGLDeviceEXT> devices(numDevices);
eglQueryDevicesEXT(numDevices, devices.data(), &numDevices);
#if 0
std::cout << "\n\n";
std::cout << "Number of EGL Devices: " << numDevices << std::endl;
for (int i = 0; i < numDevices; ++i) {
const char* vendor = eglQueryDeviceStringEXT(devices[i], EGL_VENDOR);
const char* version = eglQueryDeviceStringEXT(devices[i], EGL_VERSION);
std::cout << "Device " << i << ":" << std::endl;
if (vendor) {
std::cout << " Vendor: " << vendor << std::endl;
if (version) {
std::cout << " Version: " << version << std::endl;
#endif
display_ = eglGetPlatformDisplayEXT(EGL_PLATFORM_DEVICE_EXT, devices[0], nullptr);
if(display_ == EGL_NO_DISPLAY) {
std::cout << "EGL Display open failed\n";
return;
#if 0
const char* extensions = eglQueryString(display_, EGL_EXTENSIONS);
std::cout << "EGL_EXTENSIONS: " << extensions << "\n";
if (extensions && strstr(extensions, "EGL_IMG_context_priority")) {
std::cout << "EGL_IMG_context_priority extension - SUPPORTED\n";
} else {
std::cout << "EGL_IMG_context_priority extension - NOT SUPPORTED\n";
#endif
if (!eglInitialize(display_, nullptr, nullptr)) {
std::cout << "EGL Initialize failed\n";
return;
static const EGLint configAttribs[] = {
EGL_SURFACE_TYPE, EGL_PBUFFER_BIT,
EGL_RENDERABLE_TYPE, EGL_OPENGL_ES3_BIT,
EGL_NONE
int n;
if (!eglChooseConfig(display_, configAttribs, &config, 1, &n) || n == 0) {
std::cout << "eglChooseConfig failed" << std::endl;
return;
int main(int argc, char** argv)
if (argc != 4) {
std::cout << "Usage: " << argv[0] << " <threadCount> <priority> <fps>" << std::endl;
return -1;
int threadCount = std::stoi(argv[1]);
EGLint priority = std::stoi(argv[2]);
if (priority == 0)
priority = EGL_CONTEXT_PRIORITY_HIGH_IMG;
else if (priority == 1)
priority = EGL_CONTEXT_PRIORITY_MEDIUM_IMG;
else if (priority == 2)
priority = EGL_CONTEXT_PRIORITY_LOW_IMG;
else {
std::cerr << "Invalid priority. Use '0 for high', '1 for medium', or '2 for low'." << std::endl;
return -1;
int fps = std::stoi(argv[3]);
// Initialize EGL
initOpengl();
std::vector<std::thread> threads;
threads.emplace_back(DrawThread, i, priority, fps);
std::this_thread::sleep_for(std::chrono::milliseconds(100));
std::this_thread::sleep_for(std::chrono::milliseconds(1000));
std::thread avgFpsThread(calculateAverageFps, threadCount);
for (auto& thread : threads) {
if (thread.joinable()) {
thread.join();
avgFpsThread.join();
//std::this_thread::sleep_for(std::chrono::seconds(6));
//running = false;
std::cout << "Main thread exiting." << std::endl;
return 0;
