Hi guys,
Is there any example like /usr/src/jetson_multimedia_api/argus/samples/openglBox for Argus as producer and GL consumer that use EGL window instead of x11?
Thanks so much.
The samples are all in
There is no sample exactly fitting your use-case. Please check the existing sample and try to do implementation.
