try nulling the pointer before calling eglGetProcAddress - i believe it doesn’t do anything in the extension doesn’t exist, therefore a null pointer will remain null
You’re right - we tested on latest code, not what you would have in your device -
The actual situation is this:
In older versions of the Tegra Android driver, querying for a non-existent entry-point will always return what appears to be a valid function pointer. Although this is controversial (and unhelpful) it is allowed by the egl spec.
In recent versions of the Tegra Android driver if an entry-point doesn’t exist eglGetProcAddress will return 0.
To help resolve your problem it would be helpful if you can provide source fragments showing how you query entry-points (and which strings you query exactly), so we can review and investigate further.
Well, since I do not want to burden you with my nonsense, it suffices to say, that i put DEBUG(“%u”, eglGetProcAddress(“BullShit”)) anywhere in the code, including the draw() routine as well as the init() section.
Of course I tried with other strings including the “mapbufferOES” stuff and empty “” Strings.
Which, by the way, did not work. That was also the initial reason why I investigated the getproc… routine in the first place.
If you cold point me in the right direction on how to use the map buffer stuff properly I would be very grateful.
