EGLStream(CUDA) -> cv::cuda::GpuMat using Argus & nppi
Thank you for the reply,
I also trying to check the image is wrapped well in opencv container by: cuEglFrame → cv::cuda::gpuMat → cv::Mat -->imwrite
it seems the data is fine because cuEglFrame → cuda kernal (in jetson multimedia api → histogram) is working,
but any opencv function gives error. ex)imwrite, or sometimes download from gpuMat to cpu Mat…
I saw your comment as below, so I was wondering if you successfully done with opencv related stuff in your test.
I then tried to gpuMat.download(cpuMat) and cv::imwrite(cpuMat) , it throws unspecified launch failure as well.
For example I used these posts to wrap the data to opencv Mats.
cudaMemcpy2D:
