I am running Jetson MMAPI argus samples to control a camera connected to my Jetson Xavier. Everything works fine and I get the images. However for some application I need to access the Jetson and run my app, through a remote access. I am connecting using remote-access providers like MobaXterm or VNC, based on a ssh connection.
When I run my camera app through remote, the interface_cast<EGLstream::IFrameConsumer>(m_consumers[i]); fails to get the interface. My camera app is pretty basic and similar to sample application 13_multi_camera in the MMAPI library. This failure only happens in the remote access.
Is there any clue on how to deal with it? The remote access is pretty essential for me.
Thank you.
Well, I wish, but the exact same error happens with the ssh as well.
Forgot to mention that I have some Qt gui as well in the code, however the Qt parts works fine with no trouble, only EGLstream is the issue.
Is there any specific settings needed to be considered for ssh connection?
(with both ssh -X user@<remote_system> and ssh user@<remote_system> the error happens.
$ DISPLAY=:0 xrandr
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
and the output of the 13_argus_multi_camera sample:
~/multimedia/usr/src/jetson_multimedia_api/samples/13_argus_multi_camera$ ./argus_multi_camera -n 2 -c 10
[INFO] (NvEglRenderer.cpp:110) Setting Screen width 640 height 480
Argus Version: 0.98.3 (multi-process)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. main.cpp, threadExecute:326 Failed to get IFrameConsumer interface
Error generated. /home/multimedia/usr/src/jetson_multimedia_api/argus/samples/utils/Thread.cpp, threadFunction:132 (propagating)
Error generated. main.cpp, execute:456 Failed to submit capture request
Yes, in that moment there was no monitor attached, I just ran through ssh. However even if I connect the monitor and then run through ssh, the output of ./argus_multi_camera is the same.
We don’t see the error on Xavier NX developer kit. Please try to replicate it on Xavier NX developer kit and share us the steps. So that we can replicate it and check.
I don’t know what was exactly happening, but it seems that EGL was using localhost:0 for display, while MobaXterm was using localhost:10.
Anyway by installing and using x11vnc package and making a vnc session in MobaXterm with the dedicated port using x11vnc, I could connect with the display with no issue.
Thank you.
