I am running Proxmox 8.2.4 (ubuntu 22.04 base kernel) and trying to install a 3090 via Oculink. I have tried multiple ways to install the nividia-driver, but I can’t seem to get the driver to load. Now, I fully understand this might just be a Oculink compatibility thing, but I am stuck and not sure where to go next.
nvidia-bug-report.log.gz (93.3 KB)
modprobe nvidia -vv
modprobe: INFO: ../libkmod/libkmod.c:367 kmod_set_log_fn() custom logging function 0x56e24624bd70 registered
install modprobe -i nvidia-current $CMDLINE_OPTS
modprobe: INFO: ../libkmod/libkmod.c:367 kmod_set_log_fn() custom logging function 0x5ca3a11c3d70 registered
insmod /lib/modules/6.8.12-1-pve/updates/dkms/nvidia-current.ko
modprobe: INFO: ../libkmod/libkmod-module.c:949 kmod_module_insert_module() Failed to insert module '/lib/modules/6.8.12-1-pve/updates/dkms/nvidia-current.ko': Key was rejected by service
modprobe: ERROR: could not insert 'nvidia_current': Key was rejected by service
modprobe: INFO: ../libkmod/libkmod.c:334 kmod_unref() context 0x5ca3a1da4440 released
modprobe: ERROR: ../libkmod/libkmod-module.c:1047 command_do() Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
modprobe: ERROR: could not insert 'nvidia': Invalid argument
modprobe: INFO: ../libkmod/libkmod.c:334 kmod_unref() context 0x56e2468b8460 released
lspci -k | grep -A 2 -E "(VGA|3D)"
pcilib: Error reading /sys/bus/pci/devices/0000:00:08.3/label: Operation not permitted
01:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd GA102 [GeForce RTX 3090]
Kernel modules: nvidia
c6:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix3 (rev c4)
Subsystem: Device 1f4c:b016
Kernel driver in use: amdgpu
