Eigen JacobiSVD compile error
I’ve got an error, regarding calling JacobiSVD in my cuda function.
This is the part of the code that causing the error.
Eigen::JacobiSVDEigen::Matrix3d svd( cov_e, Eigen::ComputeThinU | Eigen::ComputeThinV);
And this is the error message.
CUDA_voxel_building.cu(43): error: calling a host function(“Eigen::JacobiSVD<Eigen::Matrix<double, (int)3, (int)3, (int)0, (int)3, (int)3> , (int)2> ::JacobiSVD”) from a global function(“kernel”) is not allowed
I’ve used the following command to compile it.
nvcc -std=c++11 -D_MWAITXINTRIN_H_INCLUDED -D__STRICT_ANSI__ -ptx CUDA_voxel_building.cu
I’m using cuda 8.0 with eigen3 on ubuntu 16.04.
Anyone knows a solution?
The cross-post on Stack Overflow has the answer: You can’t call a host function in device code. Solution: Call it from the host instead.
