Already using the TX2 module in an application, but now need have customers who do not WiFi components anywhere in the solution. TX2i module does not have the WiFi chipset, correct? Problem is that if I move to the TX2i the cost is higher and will also need to redo some firmware. Is there instructions on how to remove the WiFi component (Broadcom BCM4354(Cypress CYW4354) Chip) from the TX2 module? Is there a way to get the TX2 without the WiFi component?
Is it acceptable to try software solution to disable the wifi from software?
Changing the component in the module is not allowed.
