I used the function void HandleEGLImage(void *pEGLImage) in NvCudaProc.cpp to do CUDA operations on frames captured by CSI cameras, and found that the overhead time of this function is increasing slowly. It is about 1.5 ms at the beginning, then increases to 4.5 ms after 15 minutes, and 12ms after 40 minutes. After an hour test, it is so long that the camera start to drop frames. Is this what you expected? How to fix it? is it ok to move registering and unresgitering out of the loop? Thanks.
Before starting the test, I have run sudo /usr/bin/jetson_clocks to have maximum performance. Below is the modified function. I commented out the function for CUDA operations to measure the overhead time.
Performs CUDA Operations on egl image.
@param image : EGL image
static void
Handle_EGLImage(EGLImageKHR image)
CUresult status;
CUeglFrame eglFrame;
CUgraphicsResource pResource = NULL;cudaFree(0);
status = cuGraphicsEGLRegisterImage(&pResource, image,
CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
if (status != CUDA_SUCCESS)
printf(“cuGraphicsEGLRegisterImage failed: %d, cuda process stop\n”,
status);
return;
}status = cuGraphicsResourceGetMappedEglFrame(&eglFrame, pResource, 0, 0);
printf(“cuGraphicsSubResourceGetMappedArray failed\n”);
}status = cuCtxSynchronize();
printf(“cuCtxSynchronize failed\n”);
}if (eglFrame.frameType == CU_EGL_FRAME_TYPE_PITCH)
//Rect label in plan Y, you can replace this with any cuda algorithms.
printf(“cuCtxSynchronize failed after memcpy\n”);
}status = cuGraphicsUnregisterResource(pResource);
printf(“cuGraphicsEGLUnRegisterResource failed: %d\n”, status);
