I am manually running an ELF file like this:
ciphor@ciphor-desktop:~/standalone$ ./unit_sambhu.elf
This works fine, and I can see the following output:
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 376000
NVMEDIA_ENC: bBlitMode is set to TRUE
I am able to capture video using GStreamer when running the file manually, but I want this ELF file to run automatically after every boot on my Jetson system, using systemd
Here’s the current systemd
unit file I’m using:
[Unit]
Description=/etc/rc.local Compatibility
ConditionPathExists=/etc/rc.local
[Service]
Type=forking
ExecStart=/etc/rc.local start
User=root
TimeoutSec=0
StandardOutput=tty
RemainAfterExit=yes
SysVStartPriority=99
[Install]
WantedBy=multi-user.target
In the /etc/rc.local
file, I have written the following:
#!/bin/bash
./home/ciphor/standalone/unit_sambhu.elf &
exit 0
I have started the service, but after rebooting the system, I check the status and see the following:
rc-local.service - /etc/rc.local Compatibility
Loaded: loaded (/etc/systemd/system/rc-local.service; enabled; vendor preset: enabled)
Drop-In: /usr/lib/systemd/system/rc-local.service.d
└─debian.conf
Active: active (running) since Fri 2024-09-06 16:42:17 IST; 1h 28min ago
Main PID: 1029 (unit_sambhu.elf)
Tasks: 13 (limit: 74727)
Memory: 145.7M
CGroup: /system.slice/rc-local.service
└─1029 ./home/ciphor/standalone/unit_sambhu.elf
The log also shows:
Sep 06 16:42:17 ciphor-desktop systemd[1]: Started /etc/rc.local Compatibility.
Sep 06 16:42:18 ciphor-desktop rc.local[1029]: Opening in BLOCKING MODE
Sep 06 16:42:18 ciphor-desktop rc.local[1029]: NvMMLiteOpen : Block : BlockType = 4
Sep 06 16:42:18 ciphor-desktop rc.local[1029]: ===== NVMEDIA: NVENC =====
Sep 06 16:42:18 ciphor-desktop rc.local[1029]: NvMMLiteBlockCreate : Block : BlockType = 4
Sep 06 16:42:19 ciphor-desktop rc.local[1029]: H264: Profile = 66, Level = 0
Sep 06 16:42:19 ciphor-desktop rc.local[1029]: NVMEDIA: Need to set EMC bandwidth : 376000
Sep 06 16:42:19 ciphor-desktop rc.local[1029]: NVMEDIA_ENC: bBlitMode is set to TRUE
However, the GStreamer pipeline does not capture video after boot, and the renderer output shows a black screen.
Is there any setting I am missing here?
after system boot up the output of Jtop command
