While looking for some confirmation about the embedded metadata capture support on Jetson Nano, I found a couple of contradictory entries. Since the referral for the technical documentation of the Nano is typically the TX1, I have attached the corresponding entry asking for the specific case of the Jetson TX1 (which I assume would apply as well for Nano’s VI block).
The developer is asking for a way to disable / bypass metadata support and, as part of the responses from one of the forum moderators, it is stated that:
“Nano VI HW didn’t support the embedded data the VI ignore this package.”
https://forums.developer.nvidia.com/t/how-to-disable-embedded-metadata-support/141631 -
On this other entry, the specific concern is about the TX1 embedded metadata support, it is stated that:
“a. Embedded data support for TX1 and TX2 is valid through libargus, NOT for the direct V4L2 path.”
“b. V4L2 does not have interface and that needs an extension for embedded data.”
“c. For the kernel driver implementation, that should be a massive effort for TX1 since TX1’s VI HW cannot extract metadata with the same tegra channel.”
https://forums.developer.nvidia.com/t/embedded-metadata-ebd-for-mipi-csi2-on-tx1/58364/5
I would like to confirm that:
- Is embedded metadata capture possible on Nano’s MIPI CSI2 port? It seems like it should by using Argus.
- If supported, would this be just as a header to the frame (beginning of the frame), footer or both?
Diego Chaverri
RidgeRun
