Is it possible to embed optix-ir into an application, and if so, is there an example online to look at?
I have previously embeded ptx following Ingo’s examples, with bin2c, encoding the ptx as a char sting. Now I whish to migrate to optix-ir. For this I changed the nvcc flag from -ptx to --optix-ir. When compiling module I get
Program aborted due to an unhandled Error:
Invalid bitcode signature
from optixModuleCreate at runtime. Hints on how to move forward, and online examples would be appreciated.
Yes, that should just work, unless you did anything with strings, because there can be null characters inside the binary *.optixir.
So if you didn’t also adjust the optixModuleCreate function arguments throughout the code to not use things like ptxCode.c_str(), this ain’t working.
For faster compile turnaround times in my OptiX examples, I’m not embedding OptiX module input files but simply store them into an application specific folder relative to the executable and load them as binary from there. This code is not using strings to handle either PTX or OptiX IR input code! https://github.com/NVIDIA/OptiX_Apps/blob/master/apps/MDL_renderer/src/Device.cpp#L721
The OptiX SDK 8.0.0 has some CMake macros using BIN2C as well. I don’t know if that is actually used, yet.
What is your display driver version?
There was an error in the optixModuleCreate function not adhering to the input code size argument correctly but that should have been fixed in current R535 drivers (535.92 and newer).
Have you tested if the generated *.optixir files themselves work, like when reading them from file with the function readData() I’m using in that example code?
I gave that a short test by converting the raygeneration program of one of my examples with bin2c (from CUDA 12.2.2) and used the embedded code like this and everything kept working.
The default alignment is 1 which doesn’t need any padding for char data. Though if it post-added a null char at the end to make that array data a C string, which wouldn’t hurt for the PTX input case but isn’t required due to the explicit size argument in optixModuleCreate, it’s definitely incorrect for binary data.
