emc clock is 0 on my custom carry board (tx2)
Who can tell me what caused this?
/sys/kernel/debug/tegra_bwmgr# cat bwmgr_clients_info
Total BW requested : 0 (Khz)
Total ISO_BW requested : 0 (Khz)
Effective floor request : 480000 (Khz)
Effective NON_ISO_CAP : 0 (Khz)
Effective ISO_CAP : 0 (Khz)
Total BW + ISO_BW : 0 (Khz)
Total BW+ISO_BW after applying efficieny numbers: 0 (Khz)
Total ISO_BW after applying efficiency : 0 (Khz)
EMC calculated rate : 0 (Khz)
EMC requested(rounded) rate : 0 (Khz)
EMC current rate : 0 (Khz)
dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (tek@tek) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #47 SMP PREEMPT Mon Dec 9 17:03:26 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f6776000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29424(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975092K/8220672K available (15166K kernel code, 2916K rwdata, 6556K rodata, 8576K init, 607K bss, 180044K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095c0000 ( 6592 KB)
[ 0.000000] .init : 0xffffff80095c0000 - 0xffffff8009e20000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f9008 ( 2917 KB)
[ 0.000000] .bss : 0xffffff800a0f9008 - 0xffffff800a190e3c ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000007] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009975] Console: colour dummy device 80x25
[ 0.014715] console [tty0] enabled
[ 0.018285] bootconsole [uart8250] disabled
[ 0.022682] kmemleak: Kernel memory leak detector disabled
[ 0.022710] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022730] pid_max: default: 32768 minimum: 301
[ 0.023126] Security Framework initialized
[ 0.023322] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023337] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024495] ftrace: allocating 46820 entries in 183 pages
[ 0.224625] sched-energy: Sched-energy-costs installed from DT
[ 0.224679] ASID allocator initialised with 65536 entries
[ 0.266428] tegra-id: chipid=21817.
[ 0.266465] tegra-id: opt_subrevision=1.
[ 0.266500] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.266524] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.266546] DTB Build time: Dec 5 2019 17:46:45
[ 0.316883] CPU1: Booted secondary processor [4e0f0030]
[ 0.350627] CPU2: Booted secondary processor [4e0f0030]
[ 0.382405] CPU3: Booted secondary processor [411fd073]
[ 0.414452] CPU4: Booted secondary processor [411fd073]
[ 0.446427] CPU5: Booted secondary processor [411fd073]
[ 0.446522] Brought up 6 CPUs
[ 0.446581] SMP: Total of 6 processors activated.
[ 0.446595] CPU features: detected feature: 32-bit EL0 Support
[ 0.448008] CPU: All CPU(s) started at EL2
[ 0.448082] alternatives: patching kernel code
[ 0.461201] devtmpfs: initialized
[ 0.503072] Initilizing CustomIPI irq domain
[ 0.503624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.503668] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.505748] pinctrl core: initialized pinctrl subsystem
[ 0.506474] OS set in device tree is not L4T.
[ 0.506879] regulator-dummy: no parameters
[ 0.507157] Initializing plugin-manager
[ 0.507276] Plugin module not found
[ 0.507325] Plugin-manager status disabled
[ 0.511669] NET: Registered protocol family 16
[ 0.513932] pstore: using zlib compression
[ 0.514896] console [pstore-1] enabled
[ 0.514916] pstore: Registered ramoops as persistent store backend
[ 0.514936] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.533201] cpuidle: using governor menu
[ 0.537395] bpmp: waiting for handshake
[ 0.537433] bpmp: handshake completed
[ 0.537470] bpmp: synchronizing channels
[ 0.537528] bpmp: channels synchronized
[ 0.537544] bpmp: mail init ok
[ 0.540757] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.540797] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.540820] arm-smmu 12000000.iommu: stage 1 translation
[ 0.540839] arm-smmu 12000000.iommu: stage 2 translation
[ 0.540859] arm-smmu 12000000.iommu: nested translation
[ 0.540881] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.540910] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.540937] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.540959] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.540977] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.544784] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.544861] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.550815] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.554854] Registering BPMP clocks…
[ 0.555092] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.556528] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.559226] tegra_powergate_init: DONE
[ 0.559356] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.559494] DTB Build time: Dec 5 2019 17:46:45
[ 0.567521] Tegra reboot handler registered.
[ 0.571467] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.571714] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.571777] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.571857] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.571892] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.572381] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.572447] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.573334] iommu: Adding device 3460000.sdhci to group 0
[ 0.573676] __mc_override_sid(): override sid=23 oid=26 ord=1 at offset=318
[ 0.573685] __mc_override_sid(): override sid=23 oid=30 ord=1 at offset=338
[ 0.575039] iommu: Adding device 3400000.sdhci to group 1
[ 0.575324] __mc_override_sid(): override sid=26 oid=23 ord=1 at offset=300
[ 0.575333] __mc_override_sid(): override sid=26 oid=27 ord=1 at offset=320
[ 0.577884] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.577974] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.578281] __mc_override_sid(): override sid=29 oid=5 ord=1 at offset=f8
[ 0.578289] __mc_override_sid(): override sid=29 oid=11 ord=1 at offset=1e8
[ 0.578969] iommu: Adding device 3160000.i2c to group 3
[ 0.579748] iommu: Adding device c240000.i2c to group 4
[ 0.580347] iommu: Adding device 3180000.i2c to group 5
[ 0.580883] iommu: Adding device 3190000.i2c to group 6
[ 0.581719] iommu: Adding device 31b0000.i2c to group 7
[ 0.582259] iommu: Adding device 31c0000.i2c to group 8
[ 0.582921] iommu: Adding device c250000.i2c to group 9
[ 0.583473] iommu: Adding device 31e0000.i2c to group 10
[ 0.586157] iommu: Adding device 3210000.spi to group 11
[ 0.586760] iommu: Adding device c260000.spi to group 12
[ 0.587298] iommu: Adding device 3240000.spi to group 13
[ 0.588563] iommu: Adding device 3100000.serial to group 14
[ 0.589078] iommu: Adding device 3110000.serial to group 15
[ 0.589619] iommu: Adding device c280000.serial to group 16
[ 0.590204] iommu: Adding device 3130000.serial to group 17
[ 0.592298] iommu: Adding device 2490000.ether_qos to group 18
[ 0.592381] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.592624] __mc_override_sid(): override sid=20 oid=50 ord=1 at offset=470
[ 0.592631] __mc_override_sid(): override sid=20 oid=51 ord=1 at offset=478
[ 0.593505] iommu: Adding device b000000.rtcpu to group 19
[ 0.596609] iommu: Adding device 13e10000.host1x to group 20
[ 0.597370] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.598024] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.598587] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.599342] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.599966] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.600641] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.601310] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.601882] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.602835] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.603973] iommu: Adding device 15700000.vi to group 30
[ 0.604074] __mc_override_sid(): override sid=4 oid=33 ord=1 at offset=390
[ 0.604564] iommu: Adding device 15600000.isp to group 31
[ 0.604640] __mc_override_sid(): override sid=5 oid=12 ord=1 at offset=220
[ 0.604647] __mc_override_sid(): override sid=5 oid=13 ord=1 at offset=230
[ 0.604655] __mc_override_sid(): override sid=5 oid=14 ord=1 at offset=238
[ 0.605363] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.605719] __mc_override_sid(): override sid=9 oid=54 ord=1 at offset=490
[ 0.605726] __mc_override_sid(): override sid=9 oid=69 ord=1 at offset=508
[ 0.606214] iommu: Adding device 15340000.vic to group 33
[ 0.606792] iommu: Adding device 154c0000.nvenc to group 34
[ 0.607200] iommu: Adding device 15480000.nvdec to group 35
[ 0.607800] iommu: Adding device 15380000.nvjpg to group 36
[ 0.608195] iommu: Adding device 15500000.tsec to group 37
[ 0.608659] iommu: Adding device 15100000.tsecb to group 38
[ 0.609766] iommu: Adding device 15810000.se to group 39
[ 0.610131] iommu: Adding device 15820000.se to group 40
[ 0.610486] iommu: Adding device 15830000.se to group 41
[ 0.611058] iommu: Adding device 15840000.se to group 42
[ 0.612467] iommu: Adding device smmu_test to group 43
[ 0.613648] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
[ 0.613710] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
[ 0.613760] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
[ 0.613826] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
[ 0.613916] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[ 0.613968] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.614030] mc-err: mcerr ops are set to t18x
[ 0.614516] mc-err: Set intmask: 0xf3140
[ 0.614528] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.616526] iommu: Adding device 3530000.xhci to group 44
[ 0.616610] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.616903] __mc_override_sid(): override sid=27 oid=15 ord=1 at offset=250
[ 0.616911] __mc_override_sid(): override sid=27 oid=16 ord=1 at offset=258
[ 0.618060] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.618109] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.619328] iommu: Adding device 17000000.gp10b to group 45
[ 0.621232] tegra-reset 5000000.clock: registered 193 resets.
[ 0.624607] iommu: Adding device d000000.bpmp to group 46
[ 0.625191] bpmp: ping status is 0
[ 0.625519] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.626854] random: fast init done
[ 0.633929] bpmp d000000.bpmp: probe ok
[ 0.639227] iommu: Adding device 2600000.dma to group 47
[ 0.641488] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.641605] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.641681] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.641781] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.642259] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.649885] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.650306] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.653260] iommu: Adding device 10003000.pcie-controller to group 48
[ 0.653456] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.653743] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 0.653753] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 0.654278] iommu: Adding device sound to group 49
[ 0.654991] iommu: Adding device 3510000.hda to group 50
[ 0.655246] __mc_override_sid(): override sid=18 oid=2 ord=1 at offset=a8
[ 0.655255] __mc_override_sid(): override sid=18 oid=9 ord=1 at offset=1a8
[ 0.657361] clk_bpmp_init: dbgapb: num = 196 flags = 3 parents = 4
[ 0.657557] clk_bpmp_init: pllp_grtcab: num = 29 flags = 0 parents = 1
[ 0.657751] clk_bpmp_init: pllp_grtcba: num = 28 flags = 0 parents = 1
[ 0.657943] clk_bpmp_init: pll_p_out0: num = 269 flags = 2 parents = 1
[ 0.658139] clk_bpmp_init: pll_p: num = 516 flags = 2 parents = 1
[ 0.658334] clk_bpmp_init: pll_ref: num = 610 flags = 4 parents = 0
[ 0.659096] clk_bpmp_init: clk_32k: num = 608 flags = 4 parents = 0
[ 0.659462] clk_bpmp_init: clk_m: num = 609 flags = 4 parents = 0
[ 0.673322] iommu: Adding device c1a0000.aon to group 51
[ 0.674420] vdd-ac-bat: 5000 mV
[ 0.678117] vdd-1v8-ap: 1800 mV
[ 0.714709] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.721494] clk_bpmp_init: fuse: num = 0 flags = 0 parents = 1
[ 0.723188] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.723959] SCSI subsystem initialized
[ 0.724435] libata version 3.00 loaded.
[ 0.724809] usbcore: registered new interface driver usbfs
[ 0.724908] usbcore: registered new interface driver hub
[ 0.725122] usbcore: registered new device driver usb
[ 0.726178] clk_bpmp_init: i2c1: num = 47 flags = 3 parents = 4
[ 0.726350] clk_bpmp_init: pllp_grttb: num = 23 flags = 0 parents = 1
[ 0.726510] clk_bpmp_init: pllp_grtcbb: num = 27 flags = 0 parents = 1
[ 0.728137] clk_bpmp_set_rate: i2c1(47): 81600000
[ 0.731009] GPIO line 241 (touch-rails) hogged as output/high
[ 0.731342] GPIO line 242 (touch-rails) hogged as output/high
[ 0.731744] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.732994] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.733391] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.734868] gpiochip_setup_dev: registered GPIOs 208 to 223 on device: gpiochip4 (tca9539)
[ 0.735515] clk_bpmp_init: i2c2: num = 218 flags = 3 parents = 6
[ 0.735740] clk_bpmp_init: pllp_aon: num = 37 flags = 0 parents = 1
[ 0.735952] clk_bpmp_init: pll_c: num = 513 flags = 2 parents = 1
[ 0.736335] clk_bpmp_init: pll_aon: num = 532 flags = 2 parents = 1
[ 0.736694] clk_bpmp_init: osc: num = 612 flags = 4 parents = 0
[ 0.738241] clk_bpmp_set_rate: i2c2(218): 81600000
[ 0.739540] clk_bpmp_init: i2c3: num = 75 flags = 3 parents = 4
[ 0.739704] clk_bpmp_init: pllp_grtba: num = 32 flags = 0 parents = 1
[ 0.739865] clk_bpmp_init: pllp_grtla: num = 26 flags = 0 parents = 1
[ 0.740021] clk_bpmp_init: pllp_grtlb: num = 25 flags = 0 parents = 1
[ 0.740179] clk_bpmp_init: pllp_grtcaa: num = 30 flags = 0 parents = 1
[ 0.741360] clk_bpmp_set_rate: i2c3(75): 81600000
[ 0.742429] clk_bpmp_init: i2c4: num = 86 flags = 3 parents = 4
[ 0.743525] clk_bpmp_set_rate: i2c4(86): 20400000
[ 0.744413] clk_bpmp_init: i2c6: num = 125 flags = 3 parents = 4
[ 0.745495] clk_bpmp_set_rate: i2c6(125): 20400000
[ 0.746439] clk_bpmp_init: i2c7: num = 182 flags = 3 parents = 4
[ 0.747733] clk_bpmp_set_rate: i2c7(182): 81600000
[ 0.748727] clk_bpmp_init: i2c8: num = 219 flags = 3 parents = 6
[ 0.749862] clk_bpmp_set_rate: i2c8(219): 81600000
[ 0.750955] clk_bpmp_init: i2c9: num = 183 flags = 3 parents = 4
[ 0.752168] clk_bpmp_set_rate: i2c9(183): 81600000
[ 0.756582] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.762957] vddio-ddr: at 1125 mV
[ 0.766482] avdd_dsi_csi: 1200 mV
[ 0.770467] vdd-1v8: 1800 mV
[ 0.774471] vdd-3v3-sys: 3300 mV
[ 0.775678] spmic-ldo0: at 1800 mV
[ 0.776708] spmic-ldo1: at 800 mV
[ 0.782500] vddio-3v3: 3300 mV
[ 0.783705] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.788898] vdd-rtc: at 800 mV
[ 0.789927] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.796898] spmic-ldo6: at 1500 mV
[ 0.804896] vdd-pex-1v00: 1000 mV
[ 0.806116] dvdd-pex: 1000 mV
[ 0.807135] GPIO line 205 (spmic_gpio_input) hogged as input
[ 0.807463] GPIO line 206 (spmic_gpio_input) hogged as input
[ 0.808195] gpiochip_setup_dev: registered GPIOs 200 to 207 on device: gpiochip5 (max77620-gpio)
[ 0.811970] max77620 4-003c: max77620 probe successful
[ 0.813165] media: Linux media interface: v0.10
[ 0.813272] Linux video capture interface: v2.00
[ 0.815721] clk_bpmp_init: mipi_cal: num = 116 flags = 0 parents = 1
[ 0.816108] clk_bpmp_init: uart_fst_mipi_cal: num = 126 flags = 3 parents = 4
[ 0.816280] clk_bpmp_init: pllp_display: num = 33 flags = 0 parents = 1
[ 0.821770] pps_core: LinuxPPS API ver. 1 registered
[ 0.821868] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.821950] PTP clock support registered
[ 0.823607] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.823692] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.833580] tegra_fiq_debugger_init: found FIQ source (IRQ 385)
[ 0.839114] Advanced Linux Sound Architecture Driver Initialized.
[ 0.839880] Bluetooth: Core ver 2.22
[ 0.840004] NET: Registered protocol family 31
[ 0.840037] Bluetooth: HCI device and connection manager initialized
[ 0.840080] Bluetooth: HCI socket layer initialized
[ 0.840114] Bluetooth: L2CAP socket layer initialized
[ 0.840175] Bluetooth: SCO socket layer initialized
[ 0.841885] en-vdd-sd: 3300 mV
[ 0.842765] en-vdd-cam: 1800 mV
[ 0.848927] vdd-hdmi: 3300 mV
[ 0.850264] vdd-usb0-5v: 5000 mV
[ 0.850672] vdd-usb1-5v: 5000 mV
[ 0.856897] en-vdd-ts-1v8: 1800 mV
[ 0.864897] en-vdd-ts-hv-3v3: 3300 mV
[ 0.865327] en-vdd-disp-3v3: 3300 mV
[ 0.866099] en-mdm-pwr-3v7: 3700 mV
[ 0.866910] en-vdd-cam-hv-2v8: 2800 mV
[ 0.867677] en-vdd-cam-1v2: 1200 mV
[ 0.868433] vdd-fan: 5000 mV
[ 0.868946] vdd-3v3: 3300 mV
[ 0.869311] en-vdd-vcm-2v8: 2800 mV
[ 0.869686] vdd-usb2-5v: 5000 mV
[ 0.870049] vdd-sys-bl: 3300 mV
[ 0.871063] usb-hub-en1: 3300 mV
[ 0.871844] en-vdd-sys: 1200 mV
[ 0.872798] usb-hub-reset: 3300 mV
[ 0.873717] usb-hub-en2: 3300 mV
[ 0.880465] clk_bpmp_init: emc: num = 58 flags = 6 parents = 0
[ 0.881037] clk_bpmp_set_rate: emc(58): 0
[ 0.881589] tek.xing bwmgr_init, round_rate = 0,bwmgr.emc_max_rate = 0,line = 824
[ 0.881981] tek.xing bwmgr_init, round_rate = 0,bwmgr.emc_max_rate = 0,line = 834
[ 0.882031] tek.xing bwmgr_init, round_rate = 0,bwmgr.emc_max_rate = 0,line = 841
[ 0.882067] tek.xing bwmgr_init, round_rate = 0,bwmgr.emc_max_rate = 0,line = 851
[ 0.882262] emc bwmgr registration successful for pmqos client
[ 0.882683] camchar: rtcpu character device driver loaded
[ 0.884198] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.887399] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.889773] clocksource: Switched to clocksource arch_sys_counter
[ 0.943670] VFS: Disk quotas dquot_6.6.0
[ 0.944034] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.944871] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.946985] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.947031] nvmap_page_pool_init: Total RAM pages: 2010157
[ 0.947063] nvmap_page_pool_init: nvmap page pool size: 251269 pages (981 MB)
[ 0.947316] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.951883] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.968354] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.968692] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.969243] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.969399] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.969601] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.969944] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.970233] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.970283] tek.xing init_chip_specific
[ 0.970326] tek.xing init_chip_specific , cid = 0x18
[ 0.970638] AFIR is not constant read client, don’t program init LA value
[ 0.970643] AFIW is not constant read client, don’t program init LA value
[ 0.970652] AONW is not constant read client, don’t program init LA value
[ 0.970656] AONDMAR is not constant read client, don’t program init LA value
[ 0.970660] AONDMAW is not constant read client, don’t program init LA value
[ 0.970664] APEDMAR is not constant read client, don’t program init LA value
[ 0.970668] APEDMAW is not constant read client, don’t program init LA value
[ 0.970676] APEW is not constant read client, don’t program init LA value
[ 0.970679] AXISR is not constant read client, don’t program init LA value
[ 0.970684] AXISW is not constant read client, don’t program init LA value
[ 0.970692] BPMPW is not constant read client, don’t program init LA value
[ 0.970696] BPMPDMAR is not constant read client, don’t program init LA value
[ 0.970699] BPMPDMAW is not constant read client, don’t program init LA value
[ 0.970703] EQOSR is not constant read client, don’t program init LA value
[ 0.970706] EQOSW is not constant read client, don’t program init LA value
[ 0.970714] ETRW is not constant read client, don’t program init LA value
[ 0.970718] GPUSRD is not constant read client, don’t program init LA value
[ 0.970723] GPUSWR is not constant read client, don’t program init LA value
[ 0.970727] GPUSRD2 is not constant read client, don’t program init LA value
[ 0.970730] GPUSWR2 is not constant read client, don’t program init LA value
[ 0.970738] HDAW is not constant read client, don’t program init LA value
[ 0.970742] HOST1X_DMAR is not constant read client, don’t program init LA value
[ 0.970745] ISP_RA is not constant read client, don’t program init LA value
[ 0.970749] ISP_WA is not constant read client, don’t program init LA value
[ 0.970761] ISP_WB is not constant read client, don’t program init LA value
[ 0.970768] MPCOREW is not constant read client, don’t program init LA value
[ 0.970772] NVDECR is not constant read client, don’t program init LA value
[ 0.970775] NVDECW is not constant read client, don’t program init LA value
[ 0.970780] NVDISPLAYR is not constant read client, don’t program init LA value
[ 0.970784] NVENCSRD is not constant read client, don’t program init LA value
[ 0.970787] NVENCSWR is not constant read client, don’t program init LA value
[ 0.970790] NVJPGSRD is not constant read client, don’t program init LA value
[ 0.970794] NVJPGSWR is not constant read client, don’t program init LA value
[ 0.970849] SATAR is not constant read client, don’t program init LA value
[ 0.970852] SATAW is not constant read client, don’t program init LA value
[ 0.970861] SCEW is not constant read client, don’t program init LA value
[ 0.970865] SCEDMAR is not constant read client, don’t program init LA value
[ 0.970869] SCEDMAW is not constant read client, don’t program init LA value
[ 0.970873] SDMMCR is not constant read client, don’t program init LA value
[ 0.970877] SDMMCW is not constant read client, don’t program init LA value
[ 0.970880] SDMMCRA is not constant read client, don’t program init LA value
[ 0.970883] SDMMCWA is not constant read client, don’t program init LA value
[ 0.970887] SDMMCRAA is not constant read client, don’t program init LA value
[ 0.970890] SDMMCWAA is not constant read client, don’t program init LA value
[ 0.970893] SDMMCRAB is not constant read client, don’t program init LA value
[ 0.970897] SDMMCWAB is not constant read client, don’t program init LA value
[ 0.970901] SESRD is not constant read client, don’t program init LA value
[ 0.970904] SESWR is not constant read client, don’t program init LA value
[ 0.970907] TSECSRD is not constant read client, don’t program init LA value
[ 0.970910] TSECSWR is not constant read client, don’t program init LA value
[ 0.970913] TSECBSRD is not constant read client, don’t program init LA value
[ 0.970917] TSECBSWR is not constant read client, don’t program init LA value
[ 0.970921] UFSHCR is not constant read client, don’t program init LA value
[ 0.970924] UFSHCW is not constant read client, don’t program init LA value
[ 0.970927] VI_W is not constant read client, don’t program init LA value
[ 0.970931] VICSRD is not constant read client, don’t program init LA value
[ 0.970934] VICSWR is not constant read client, don’t program init LA value
[ 0.970937] XUSB_DEVR is not constant read client, don’t program init LA value
[ 0.970940] XUSB_DEVW is not constant read client, don’t program init LA value
[ 0.970944] XUSB_HOSTR is not constant read client, don’t program init LA value
[ 0.970947] XUSB_HOSTW is not constant read client, don’t program init LA value
[ 0.971124] la/ptsa driver initialized.
[ 0.971175] tek.xing pre_t19x_iso_plat_init max_emc_clk 0, max_emc_clk = 0
[ 0.971201] pre_t19x_iso_plat_init(): iso emc max clk=0KHz
[ 0.971233] pre_t19x_iso_plat_init(): max_iso_bw=0KB
[ 0.972569] NET: Registered protocol family 2
[ 0.975118] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.976151] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.977393] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.977627] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.977929] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.979070] NET: Registered protocol family 1
[ 0.980604] RPC: Registered named UNIX socket transport module.
[ 0.980643] RPC: Registered udp transport module.
[ 0.980667] RPC: Registered tcp transport module.
[ 0.980689] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.980745] PCI: CLS 0 bytes, default 64
[ 0.981190] Trying to unpack rootfs image as initramfs…
[ 1.002363] clk_bpmp_init: host1x: num = 57 flags = 3 parents = 4
[ 1.002549] clk_bpmp_init: pllrefe_out_gated: num = 261 flags = 0 parents = 1
[ 1.002730] clk_bpmp_init: pll_refe_out: num = 108 flags = 2 parents = 1
[ 1.002904] clk_bpmp_init: pll_refe: num = 520 flags = 2 parents = 1
[ 1.003081] clk_bpmp_init: pllrefe_iddq: num = 308 flags = 0 parents = 1
[ 1.003253] clk_bpmp_init: pll_refe_ref: num = 295 flags = 2 parents = 1
[ 1.003420] clk_bpmp_init: pll_u: num = 533 flags = 0 parents = 1
[ 1.004388] clk_bpmp_init: pll_c2: num = 521 flags = 2 parents = 1
[ 1.005271] clk_bpmp_set_rate: host1x(57): 102000000
[ 1.006430] clk_bpmp_init: actmon: num = 201 flags = 3 parents = 4
[ 1.007014] clk_bpmp_set_rate: actmon(201): 19200000
[ 1.017086] host1x 13e10000.host1x: initialized
[ 1.020384] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.027268] audit: initializing netlink subsys (disabled)
[ 1.027425] audit: type=2000 audit(0.836:1): initialized
[ 1.028562] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.042217] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.045222] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.047053] 9p: Installing v9fs 9p2000 file system support
[ 1.055316] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.055675] io scheduler noop registered
[ 1.056353] io scheduler cfq registered (default)
[ 1.060974] clk_bpmp_init: ape: num = 105 flags = 3 parents = 5
[ 1.061149] clk_bpmp_init: pll_a_out0: num = 246 flags = 2 parents = 1
[ 1.061315] clk_bpmp_init: pll_a: num = 271 flags = 2 parents = 1
[ 1.061474] clk_bpmp_init: pll_a_vco: num = 517 flags = 2 parents = 1
[ 1.062367] clk_bpmp_init: pll_a_out1: num = 288 flags = 2 parents = 1
[ 1.062534] clk_bpmp_init: pll_a1: num = 525 flags = 2 parents = 1
[ 1.063088] clk_bpmp_init: pllp_audio: num = 36 flags = 0 parents = 1
[ 1.063684] clk_bpmp_init: apb2ape: num = 104 flags = 0 parents = 1
[ 1.065924] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.160246] iommu: Adding device aconnect@2a41000:adsp_audio to group 52
[ 1.220123] iommu: Adding device 2993000.adsp to group 53
[ 1.222000] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.226026] clk_bpmp_init: usb2_trk: num = 135 flags = 0 parents = 1
[ 1.226207] clk_bpmp_init: usb2_hsic_trk: num = 241 flags = 2 parents = 1
[ 1.229365] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.236170] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.236789] clk_bpmp_init: pwm1: num = 187 flags = 3 parents = 4
[ 1.237363] clk_bpmp_set_rate: pwm1(187): 1010526
[ 1.238614] clk_bpmp_set_rate: pwm1(187): 102000000
[ 1.239391] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.239633] clk_bpmp_init: pwm2: num = 188 flags = 3 parents = 4
[ 1.240045] clk_bpmp_set_rate: pwm2(188): 1010526
[ 1.241030] clk_bpmp_set_rate: pwm2(188): 102000000
[ 1.241681] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.241979] clk_bpmp_init: pwm3: num = 189 flags = 3 parents = 4
[ 1.242403] clk_bpmp_set_rate: pwm3(189): 1010526
[ 1.243412] clk_bpmp_set_rate: pwm3(189): 102000000
[ 1.244096] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.244327] clk_bpmp_init: pwm4: num = 225 flags = 3 parents = 6
[ 1.245651] clk_bpmp_init: tach: num = 166 flags = 3 parents = 4
[ 1.246219] clk_bpmp_set_rate: tach(166): 1010526
[ 1.248533] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.248847] clk_bpmp_init: afi: num = 4 flags = 3 parents = 5
[ 1.249156] clk_bpmp_init: pllp_uphy: num = 38 flags = 0 parents = 1
[ 1.249820] clk_bpmp_init: pcie: num = 3 flags = 0 parents = 1
[ 1.249980] clk_bpmp_init: pll_e: num = 512 flags = 0 parents = 1
[ 1.250569] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.251352] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.251669] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.251981] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.252069] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.252111] pre_t19x_iso_plat_register(): iso bandwidth 4687500KB is not available, client tegra_camera_ctrl
[ 1.252142] misc tegra_camera_ctrl: tegra_camera_isomgr_register: unable to register to isomgr
[ 1.252169] misc tegra_camera_ctrl: tegra_camera_probe: failed to register CAMERA as isomgr client
[ 1.252221] tegra_camera_platform: probe of tegra-camera-platform failed with error -12
[ 1.258026] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.258503] clk_bpmp_init: tsec: num = 81 flags = 6 parents = 0
[ 1.259202] clk_bpmp_set_rate: tsec(81): 716800000
[ 1.260847] tsec 15500000.tsec: initialized
[ 1.261201] clk_bpmp_init: tsecb: num = 137 flags = 6 parents = 0
[ 1.261699] clk_bpmp_set_rate: tsecb(137): 716800000
[ 1.263081] tsec 15100000.tsecb: initialized
[ 1.269479] clk_bpmp_init: nvdec: num = 129 flags = 6 parents = 0
[ 1.269927] clk_bpmp_set_rate: nvdec(129): 1203200000
[ 1.271497] nvdec 15480000.nvdec: initialized
[ 1.279188] clk_bpmp_init: vic: num = 127 flags = 6 parents = 0
[ 1.279856] clk_bpmp_set_rate: vic(127): 1024000000
[ 1.283325] falcon 15340000.vic: initialized
[ 1.284305] clk_bpmp_init: nvenc: num = 131 flags = 6 parents = 0
[ 1.284866] clk_bpmp_set_rate: nvenc(131): 1164800000
[ 1.286261] falcon 154c0000.nvenc: initialized
[ 1.287147] clk_bpmp_init: nvjpg: num = 130 flags = 6 parents = 0
[ 1.287611] clk_bpmp_set_rate: nvjpg(130): 857600000
[ 1.288817] falcon 15380000.nvjpg: initialized
[ 1.292621] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.294920] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.297160] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.299401] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.301663] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.303964] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.307294] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.311090] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.317282] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.317355] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.317465] tegradccommon 15200000.dc_common: dma mapping done
[ 1.320068] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.320331] generic_infoframe_type: 0x87
[ 1.320777] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.320923] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[ 1.321704] clk_bpmp_init: nvdisplay_p1: num = 159 flags = 3 parents = 6
[ 1.322079] clk_bpmp_init: pll_d_out1: num = 267 flags = 2 parents = 1
[ 1.322446] clk_bpmp_init: pll_d: num = 518 flags = 2 parents = 1
[ 1.323511] clk_bpmp_init: pll_d2: num = 519 flags = 2 parents = 1
[ 1.323844] clk_bpmp_init: pll_d3: num = 528 flags = 2 parents = 1
[ 1.324400] clk_bpmp_init: ahub: num = 87 flags = 3 parents = 12
[ 1.324579] clk_bpmp_init: spdif_in: num = 44 flags = 3 parents = 3
[ 1.324946] clk_bpmp_init: i2s1: num = 79 flags = 3 parents = 6
[ 1.325147] clk_bpmp_init: i2s1_sync_clk: num = 247 flags = 1 parents = 8
[ 1.325317] clk_bpmp_init: spdifin_sync_input: num = 623 flags = 6 parents = 0
[ 1.325683] clk_bpmp_init: i2s1_sync_input: num = 617 flags = 6 parents = 0
[ 1.326003] clk_bpmp_init: i2s2_sync_input: num = 618 flags = 6 parents = 0
[ 1.326317] clk_bpmp_init: i2s3_sync_input: num = 619 flags = 6 parents = 0
[ 1.326657] clk_bpmp_init: i2s4_sync_input: num = 620 flags = 6 parents = 0
[ 1.327027] clk_bpmp_init: i2s5_sync_input: num = 621 flags = 6 parents = 0
[ 1.327381] clk_bpmp_init: i2s6_sync_input: num = 622 flags = 6 parents = 0
[ 1.327887] clk_bpmp_init: i2s2: num = 42 flags = 3 parents = 6
[ 1.328063] clk_bpmp_init: i2s2_sync_clk: num = 248 flags = 1 parents = 8
[ 1.328420] clk_bpmp_init: i2s3: num = 43 flags = 3 parents = 6
[ 1.328585] clk_bpmp_init: i2s3_sync_clk: num = 249 flags = 1 parents = 8
[ 1.328922] clk_bpmp_init: i2s4: num = 84 flags = 3 parents = 6
[ 1.329083] clk_bpmp_init: i2s4_sync_clk: num = 250 flags = 1 parents = 8
[ 1.329432] clk_bpmp_init: i2s5: num = 85 flags = 3 parents = 6
[ 1.329596] clk_bpmp_init: i2s5_sync_clk: num = 251 flags = 1 parents = 8
[ 1.329988] clk_bpmp_init: i2s6: num = 154 flags = 3 parents = 6
[ 1.330153] clk_bpmp_init: i2s6_sync_clk: num = 252 flags = 1 parents = 8
[ 1.330838] clk_bpmp_init: nvdisplayhub: num = 158 flags = 3 parents = 6
[ 1.331058] clk_bpmp_init: pll_disphub: num = 527 flags = 2 parents = 1
[ 1.331420] clk_bpmp_init: nafll_disp: num = 576 flags = 2 parents = 1
[ 1.332131] clk_bpmp_init: nvdisplay_disp: num = 156 flags = 1 parents = 7
[ 1.332304] clk_bpmp_init: nvdisplay_p0: num = 155 flags = 3 parents = 6
[ 1.332704] clk_bpmp_init: nvdisplay_p2: num = 160 flags = 3 parents = 6
[ 1.333083] clk_bpmp_init: sor_safe: num = 39 flags = 0 parents = 1
[ 1.333253] clk_bpmp_init: pll_p_div17: num = 286 flags = 2 parents = 1
[ 1.333708] clk_bpmp_init: dflldisp_div: num = 284 flags = 2 parents = 1
[ 1.334141] clk_bpmp_init: plldisphub_div: num = 285 flags = 2 parents = 1
[ 1.335351] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.338092] clk_bpmp_init: nvdisplay_dsc: num = 157 flags = 2 parents = 1
[ 1.338521] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.339740] clk_bpmp_init: kfuse: num = 293 flags = 2 parents = 1
[ 1.340059] kfuse 3830000.kfuse: initialized
[ 1.341025] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.341063] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.343219] clk_bpmp_init: dpaux1: num = 95 flags = 0 parents = 1
[ 1.343289] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.345975] clk_bpmp_init: sor1_out: num = 297 flags = 1 parents = 3
[ 1.346121] clk_bpmp_init: sor1_pad_clkout: num = 616 flags = 6 parents = 0
[ 1.346617] clk_bpmp_init: sor1: num = 93 flags = 3 parents = 5
[ 1.349895] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.349956] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.351055] clk_bpmp_init: hda: num = 102 flags = 3 parents = 5
[ 1.351765] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.352061] clk_bpmp_init: hda2codec_2x: num = 88 flags = 3 parents = 5
[ 1.352647] clk_bpmp_init: hda2hdmicodec: num = 98 flags = 0 parents = 1
[ 1.355150] clk_bpmp_init: uarta: num = 55 flags = 3 parents = 5
[ 1.355333] clk_bpmp_init: pllc4_out: num = 110 flags = 0 parents = 1
[ 1.355522] clk_bpmp_init: pll_c4_out_mux: num = 279 flags = 1 parents = 3
[ 1.355753] clk_bpmp_init: pll_c4_out1: num = 277 flags = 2 parents = 1
[ 1.355938] clk_bpmp_init: pll_c4_vco: num = 524 flags = 2 parents = 1
[ 1.356547] clk_bpmp_init: pll_c4_out2: num = 278 flags = 2 parents = 1
[ 1.356939] clk_bpmp_init: pll_c4_vco_div2: num = 535 flags = 2 parents = 1
[ 1.357791] tegradc 15210000.nvdisplay: probed
[ 1.358334] console [ttyS0] disabled
[ 1.358520] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.689038] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.098119] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.506727] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.508771] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.509841] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.509855] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.509862] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.509901] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.509909] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.509983] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[ 2.510169] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.510453] iommu: Adding device 0000:00:03.0 to group 54
[ 2.510483] arm-smmu: forcing sodev map for 0000:00:03.0
[ 2.510644] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.510651] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.511051] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.511402] pci 0000:01:00.0: [8086:1531] type 00 class 0x020000
[ 2.511472] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x007fffff]
[ 2.511532] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.511565] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.511961] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.512306] iommu: Adding device 0000:01:00.0 to group 55
[ 2.512313] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.512350] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.512356] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.521934] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.522020] pci 0000:00:03.0: BAR 14: assigned [mem 0x40400000-0x40ffffff]
[ 2.522027] pci 0000:00:03.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.522046] pci 0000:01:00.0: BAR 0: assigned [mem 0x40800000-0x40ffffff]
[ 2.522064] pci 0000:01:00.0: BAR 3: assigned [mem 0x40400000-0x40403fff]
[ 2.522081] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.522105] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 2.522113] pci 0000:00:03.0: bridge window [io 0x1000-0x1fff]
[ 2.522126] pci 0000:00:03.0: bridge window [mem 0x40400000-0x40ffffff]
[ 2.522811] clk_bpmp_set_rate: afi(4): 102000000
[ 2.523459] clk_bpmp_set_rate: emc(58): 0
[ 2.524377] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[ 2.524383] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.524396] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[ 2.524652] aer 0000:00:03.0:pcie002: service driver aer loaded
[ 3.806386] console [ttyS0] enabled
[ 3.807401] Console: switching to colour frame buffer device 80x30
[ 3.812987] clk_bpmp_init: uartb: num = 56 flags = 3 parents = 4
[ 3.814423] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.818094] clk_bpmp_init: uartc: num = 215 flags = 3 parents = 6
[ 3.819313] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.822100] serial-tegra 3130000.serial: RX in PIO mode
[ 3.822389] clk_bpmp_init: uartd: num = 77 flags = 3 parents = 4
[ 3.822567] clk_bpmp_init: pllp_grtta: num = 24 flags = 0 parents = 1
[ 3.823865] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.827899] [drm] Initialized
[ 3.852828] tegradc 15210000.nvdisplay: fb registered
[ 3.858996] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.863250] brd: module loaded
[ 3.870726] loop: module loaded
[ 3.874167] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.880489] tegra_profiler: auth: init
[ 3.885639] nct1008_nct72 7-004c: starting parse dt
[ 3.886343] THERMAL EST: found 3 subdevs
[ 3.886348] THERMAL EST num_resources: 0
[ 3.886353] [THERMAL EST subdev 0]
[ 3.886364] [THERMAL EST subdev 1]
[ 3.886369] [THERMAL EST subdev 2]
[ 3.887386] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.887390] THERMAL EST: thz register success.
[ 3.887748] THERMAL EST: end of probe, return err: 0
[ 3.889193] hisi_sas: driver version v1.6
[ 3.891421] clk_bpmp_init: sata: num = 99 flags = 3 parents = 3
[ 3.891945] clk_bpmp_init: sata_oob: num = 100 flags = 3 parents = 2
[ 3.894211] clk_bpmp_set_rate: sata(99): 102000000
[ 3.894713] clk_bpmp_set_rate: sata_oob(100): 204000000
[ 3.896143] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.896158] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.897913] scsi host0: tegra_ahci
[ 3.903266] scsi host1: tegra_ahci
[ 3.903568] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.903574] ata2: DUMMY
[ 3.906029] clk_bpmp_init: spi1: num = 49 flags = 3 parents = 4
[ 3.908317] clk_bpmp_init: spi2: num = 222 flags = 3 parents = 6
[ 3.910716] clk_bpmp_init: spi4: num = 74 flags = 3 parents = 4
[ 3.915164] libphy: Fixed MDIO Bus: probed
[ 3.915672] tun: Universal TUN/TAP device driver, 1.6
[ 3.915676] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.916719] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 3.916722] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 3.916776] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.916778] igb: Copyright © 2007-2014 Intel Corporation.
[ 3.917402] igb 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.974357] igb 0000:01:00.0 (unnamed net_device) (uninitialized): igb: eth%d NIC Link is Down
[ 3.978133] pps pps0: new PPS source ptp0
[ 3.978142] igb 0000:01:00.0: added PHC on eth0
[ 3.978147] igb 0000:01:00.0: Intel® Gigabit Ethernet Network Connection
[ 3.978156] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 6c:61:74:75:6c:65
[ 3.978165] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[ 3.978171] igb 0000:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 3.978536] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.978539] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 3.978704] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.978708] Copyright© 1999 - 2017 Intel Corporation.
[ 3.982250] eqos 2490000.ether_qos: no PHY interrupt found
[ 3.982617] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 3.983023] clk_bpmp_init: axi_cbb: num = 149 flags = 6 parents = 0
[ 3.983547] clk_bpmp_init: eqos_axi_clk: num = 167 flags = 0 parents = 1
[ 3.983721] clk_bpmp_init: pllrefe_out1_div5: num = 298 flags = 2 parents = 1
[ 3.983893] clk_bpmp_init: pll_refe_out1: num = 262 flags = 2 parents = 1
[ 3.984606] clk_bpmp_init: eqos_rx: num = 168 flags = 0 parents = 1
[ 3.984776] clk_bpmp_init: eqos_rx_input: num = 613 flags = 6 parents = 0
[ 3.985250] clk_bpmp_init: eqos_ptp_ref_clk: num = 239 flags = 2 parents = 1
[ 3.985769] clk_bpmp_init: eqos_tx_clk: num = 240 flags = 2 parents = 1
[ 3.988809] clk_bpmp_set_rate: eqos_ptp_ref_clk(239): 125000000
[ 3.989559] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 da 2f
[ 3.990175] libphy: dwc_phy: probed
[ 3.991059] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.992338] pre_t19x_iso_plat_register(): iso bandwidth 81920KB is not available, client eqos
[ 3.996467] PPP generic driver version 2.4.2
[ 3.997409] PPP BSD Compression module registered
[ 3.997414] PPP Deflate Compression module registered
[ 3.997515] PPP MPPE Compression module registered
[ 3.997521] NET: Registered protocol family 24
[ 3.997691] usbcore: registered new interface driver r8152
[ 3.997947] usbcore: registered new interface driver asix
[ 3.998084] usbcore: registered new interface driver ax88179_178a
[ 3.998220] usbcore: registered new interface driver cdc_ether
[ 3.998348] usbcore: registered new interface driver net1080
[ 3.998543] usbcore: registered new interface driver cdc_subset
[ 3.998668] usbcore: registered new interface driver zaurus
[ 3.998825] usbcore: registered new interface driver cdc_ncm
[ 3.999298] VFIO - User Level meta-driver version: 0.3
[ 4.002248] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.002303] ehci-pci: EHCI PCI platform driver
[ 4.002436] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.002449] ohci-pci: OHCI PCI platform driver
[ 4.002576] ohci-platform: OHCI generic platform driver
[ 4.007754] clk_bpmp_init: xusb_host: num = 113 flags = 0 parents = 1
[ 4.007933] clk_bpmp_init: xusb: num = 111 flags = 3 parents = 4
[ 4.008101] clk_bpmp_init: pllp_xusb: num = 16 flags = 0 parents = 1
[ 4.008715] clk_bpmp_init: xusb_falcon: num = 244 flags = 3 parents = 4
[ 4.009177] clk_bpmp_init: xusb_ss: num = 114 flags = 0 parents = 1
[ 4.009535] clk_bpmp_init: xusb_core_ss: num = 242 flags = 3 parents = 4
[ 4.009706] clk_bpmp_init: pll_u_480M: num = 275 flags = 2 parents = 1
[ 4.010715] clk_bpmp_init: xusb_fs: num = 245 flags = 3 parents = 5
[ 4.010880] clk_bpmp_init: pll_u_48M: num = 274 flags = 2 parents = 1
[ 4.012382] tegra-xusb 3530000.xhci: No USB port has OTG_CAP
[ 4.014757] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.014763] tegra-xusb 3530000.xhci: Falling back to user helper
[ 4.015917] usbcore: registered new interface driver uas
[ 4.016059] usbcore: registered new interface driver usb-storage
[ 4.016376] usbcore: registered new interface driver usbserial
[ 4.021516] mousedev: PS/2 mouse device common for all mice
[ 4.021768] usbcore: registered new interface driver xpad
[ 4.157080] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.159716] Wake73 for irq=42
[ 4.161205] rtc rtc1: alarm rtc device
[ 4.161227] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.161274] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.161779] i2c /dev entries driver
[ 4.164671] tek.xing adv7180_probe
[ 4.164680] adv7180 2-0020: chip found @ 0x20 (3180000.i2c)
[ 4.164773] adv7180 2-0020: adv7180_parse_dt
[ 4.164788] adv7180 2-0020: mclk in DT extperiph1
[ 4.164796] adv7180 2-0020: adv7180_power_get: power on pw = 0
[ 4.164816] adv7180 2-0020: camera_common_parse_ports: port 0 num of lanes 1
[ 4.164845] adv7180 2-0020: parsing for mode0 props
[ 4.164919] adv7180 2-0020: adv7281_probe: name adv7281_a
[ 4.164926] adv7180 2-0020: camera_common_create_debugfs adv7281_a
[ 4.164949] adv7180 2-0020: tegracam sensor driver:adv7281_v2.0.6
[ 4.164954] adv7180 2-0020: adv7180_probe
[ 4.165046] adv7180 2-0020: adv7180_fill_string_ctrl
[ 4.165049] adv7180 2-0020: adv7180_fill_string_ctrl
[ 4.165053] adv7180 2-0020: adv7180_fill_string_ctrl
[ 4.168887] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 4.176753] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.177686] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.180137] parse_throttle_dt_data: Num cap clks = 4
[ 4.180142] parse_throttle_dt_data: clk=mcpu type=1
[ 4.180146] parse_throttle_dt_data: clk=bcpu type=2
[ 4.180167] parse_throttle_dt_data: clk=gpu type=4
[ 4.180169] parse_throttle_dt_data: clk=emc type=3
[ 4.182175] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.183308] FAN dev name: pwm-fan
[ 4.183408] FAN:gpio request success.
[ 4.183421] FAN: can’t find tach_gpio
[ 4.183480] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.183864] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.183870] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.184965] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.184972] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.184978] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.184985] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.184990] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.184995] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.185000] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.185005] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.185056] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.185062] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.188127] device-mapper: uevent: version 1.0.3
[ 4.189277] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.192139] clk_bpmp_set_rate: emc(58): 0
[ 4.192904] clk_bpmp_set_rate: emc(58): 0
[ 4.197465] clk_bpmp_set_rate: emc(58): 0
[ 4.208616] clk_bpmp_set_rate: emc(58): 0
[ 4.209072] cpufreq: platform driver Initialization: pass
[ 4.214902] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.215135] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.220171] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.221881] sdhci: Secure Digital Host Controller Interface driver
[ 4.221886] sdhci: Copyright© Pierre Ossman
[ 4.221889] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.223869] clk_bpmp_init: pll_c4_out0: num = 276 flags = 2 parents = 1
[ 4.224530] clk_bpmp_init: sdmmc4: num = 54 flags = 3 parents = 7
[ 4.225007] clk_bpmp_init: sdmmc_legacy_tm: num = 128 flags = 3 parents = 4
[ 4.225390] clk_bpmp_set_rate: sdmmc_legacy_tm(128): 12000000
[ 4.225828] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.226775] clk_bpmp_set_rate: emc(58): 0
[ 4.227320] clk_bpmp_set_rate: sdmmc4(54): 3175098
[ 4.228776] CMDQ: cmdq_platfm_init successful
[ 4.230957] CQE: CMD_TIMING bit set for R1B DCMD
[ 4.233924] clk_bpmp_init: sdmmc3: num = 76 flags = 3 parents = 5
[ 4.235936] clk_bpmp_set_rate: sdmmc_legacy_tm(128): 12000000
[ 4.236321] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.237437] clk_bpmp_set_rate: sdmmc3(76): 3175098
[ 4.241083] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.241165] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 4.241705] clk_bpmp_init: sdmmc1: num = 52 flags = 3 parents = 5
[ 4.242197] clk_bpmp_set_rate: sdmmc_legacy_tm(128): 12000000
[ 4.242483] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.243363] clk_bpmp_set_rate: sdmmc1(52): 3175098
[ 4.245045] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 256
[ 4.251564] clk_bpmp_init: se: num = 103 flags = 6 parents = 0
[ 4.252444] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.253493] clk_bpmp_set_rate: se(103): 601600000
[ 4.254517] tegra-se-nvhost 15810000.se: initialized
[ 4.255095] clk_bpmp_set_rate: emc(58): 0
[ 4.258831] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.259927] clk_bpmp_set_rate: se(103): 601600000
[ 4.260531] tegra-se-nvhost 15820000.se: initialized
[ 4.264526] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.265511] clk_bpmp_set_rate: se(103): 601600000
[ 4.266179] tegra-se-nvhost 15830000.se: initialized
[ 4.269678] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.270643] clk_bpmp_set_rate: se(103): 601600000
[ 4.271236] tegra-se-nvhost 15840000.se: initialized
[ 4.274982] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.275725] hidraw: raw HID events driver © Jiri Kosina
[ 4.277905] usbcore: registered new interface driver usbhid
[ 4.277907] usbhid: USB HID core driver
[ 4.280471] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 4.280514] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 4.280685] ina3221x: probe of 0-0042 failed with error -121
[ 4.280976] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 4.281010] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 4.281106] ina3221x: probe of 0-0043 failed with error -121
[ 4.282534] clk_bpmp_init: sce_apb: num = 230 flags = 3 parents = 4
[ 4.282667] clk_bpmp_init: pllp_boot: num = 34 flags = 0 parents = 1
[ 4.283263] clk_bpmp_init: sce_cpu_nic: num = 228 flags = 6 parents = 0
[ 4.285781] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.285900] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.287406] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.288896] clk_bpmp_set_rate: sce_apb(230): 102000000
[ 4.289330] clk_bpmp_set_rate: sce_cpu_nic(228): 473600000
[ 4.291275] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.291730] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.293593] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.294126] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.298007] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 4.298130] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.298742] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.298936] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.299020] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.299092] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.299349] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.300216] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 4.300220] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.301035] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.307364] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.308465] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.309067] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.309510] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.310780] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.310784] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.310786] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.310863] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.310865] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.310867] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.310940] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.310941] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.310942] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.311007] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311009] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.311011] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.311086] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311088] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.311089] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.311182] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311187] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.311189] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.311257] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311262] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.311264] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.311342] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311347] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.311348] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.311411] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.311416] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.311417] tegra18-bridge 213000
hello tek.xing,
may I know which JetPack release you’re working with.
also, did you working with a customize board?
thanks
i’m working with JetPack_4.2_Linux_P3310.
yes,it’s customize for us.
ps, there is no this iusse on nvidia’s carry board,it’s occur on my carry board only, but, i don’t know the reason.
The problem is very urgent.
and also, there is no emc folder under the below path:
root@tek-desktop:~# l /sys/kernel/debug/bpmp/debug/emc/
ls: cannot access ‘/sys/kernel/debug/bpmp/debug/emc/’: No such file or directory
hello tek.xing,
since it’s a customize board, suggest you access Jetson TX2 Platform Adaptation and Bring-Up Guide to review board configurations.
please also refer to documentation, Memory Power Management, you’ll need to check your boot configuration table.
thanks
ok,i’ll check it later.
now, i want to know what can cause this iusse occur, then i’ll check code or configuration follow it.
when i called clk_set_rate(emc_master_clk, 40800000) to set the rate,it was failed.
hello tek.xing,
please also share the failure messages about your clk_set_rate() error reports.
thanks
Hi tek.xing,
Has this issue been resolved? Any result can be shared?
