Hi everyone,
I’m encountering an issue with the EMC frequency on my Jetson AGX Orin (JetPack 6.2, Ubuntu 22.04). Despite setting the device to maximum performance mode, the EMC frequency remains stuck at 204 MHz, even under sustained high memory usage.
I’ve already set:
- nvpmodel to MAXN:
sudo nvpmodel -m 0
- Applied jetson_clocks:
sudo jetson_clocks
- Monitored the system using tegrastats and Tegra Power GUI
What I observe:
- EMC frequency stays at 204 MHz, even during heavy memory usage
- EMC load goes up to 185%, indicating clear memory bandwidth saturation
- The system is thermally throttling
Is it expected for the EMC frequency to remain this low under thermal throttling?
Is there any supported way to force or unlock higher EMC frequencies?
Thanks for your support.
