eMMC on NANO and Xavier NX
I am working with the NANO, but the 16GB eMMC is quite insufficient. Is it possible for me to replace the eMMC with a 32GB one ?
Also, in the upcoming Xavier NX, will this be possible ?
Hi, eMMC is mounted on board, do you mean manually replace it by soldering? You can use module with SD slot if necessary.
There is no SD card slot in the production module. The footprint is there but no socket. Can I solder a slot and connect an SD card ? If so, can you share the SD card socket part number ?
P/N is Molex, 503398-1892.
