• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 4070
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only) 535.216.01
Is there any Python application as reference that perform emotion classification using the model from deepstream_tao_apps?
In addition, the C application uses the “cvcore_libs”. Is it possible to use this library on Python?
@Fiona.Chen, thank you for reply.
In the application that I’m developing, I have already implemented the detection and the the landmarks. In a probe, I can access the landmarks data, that have a shape of 68x2. But, according to documentation, the input for the emotion model is 1x136x1. Do you have any tips on how to reshape the output of the landmarks Sgie to match the input of the emotion model? Can I do it using pyds or PyBindings?
Here is the code snippet for accessing the landmarks:
while l_user_meta:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
except StopIteration:
break
if user_meta and user_meta.base_meta.meta_type==pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META:
try:
tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
break
frame_outputs =
layer_1 = pyds.get_nvds_LayerInfo(tensor_meta, 0)
layer_2 = pyds.get_nvds_LayerInfo(tensor_meta, 1)
layer_3 = pyds.get_nvds_LayerInfo(tensor_meta, 2)
layer_2_data =
# Convert NvDsInferLayerInfo buffer to numpy array
ptr = ctypes.cast(pyds.get_ptr(layer_2.buffer), ctypes.POINTER(ctypes.c_float))
layer_2_data = np.ctypeslib.as_array(ptr, shape=([80,2]))
We just provide cvcore interfaces. You may need to develop the python binding by yourself.
