Emotionet output video file not saving in directory
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version6.4
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only)**12.4
the code is running totally fine and im seeing the logs of face detection in the output, but i’m not able to see the output file which should be a video file with bounding boxes around the face and detected emotions.
im using this method to start this in docker container:
the command which is being used to run this app:
root@EISPROD1:/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_tao_apps/apps/tao_others/deepstream-emotion-app# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/nvidia/deepstream/deepstream/lib/cvcore_libs
./deepstream-emotion-app 2 /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/sample_faciallandmarks_config.txt file:///opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/footage.mp4 ./landmarks
the config file:
source-list:
list: file:///opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/footage.mp4
output:
1:file ouput 2:fake output 3:eglsink output
type: 1
0: H264 encoder 1:H265 encoder
enc: 0
bitrate: 2000000
##The file name without suffix
filename: test
output-file-path: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/
streammux:
width: 1280
height: 720
batched-push-timeout: 40000
primary-gie:
type: 0
config-file-path: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_tao_apps/configs/nvinfer/facial_tao/config_infer_prima>
unique-id: 1
secondary-gie:
type: 0
config-file-path: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_tao_apps/configs/nvinfer/facial_tao/faciallandmark_sg>
unique-id: 2
video-template:
customlib-name: ./emotion_impl/libnvds_emotion_impl.so
customlib-props: config-file:/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/sample_emotion_model_>
model-config:
config-file-path: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_tao_apps/configs/nvinfer/facial_tao/sample_faciallandm>
here is the output of the running app:
Now playing: file:///opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/footage.mp4
0:00:08.343803408 13139 0x55d5816ae440 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/FacialLandmarks/model.etlt_b32_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 4
0 INPUT kFLOAT input_face_images 1x80x80 min: 1x1x80x80 opt: 32x1x80x80 Max: 32x1x80x80
1 OUTPUT kFLOAT conv_keypoints_m80 80x80x80 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT softargmax 80x2 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT softargmax:1 80 min: 0 opt: 0 Max: 0
0:00:08.604769331 13139 0x55d5816ae440 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/FacialLandmarks/model.etlt_b32_gpu0_int8.engine
0:00:08.802625680 13139 0x55d5816ae440 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 2]: Load new model:…/…/…/configs/nvinfer/facial_tao/faciallandmark_sgie_config.txt sucessfully
0:00:08.802897301 13139 0x55d5816ae440 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1243> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:16.530861016 13139 0x55d5816ae440 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/FaceDetect/model.etlt_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x416x736
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x26x46
2 OUTPUT kFLOAT output_cov/Sigmoid 1x26x46
0:00:16.773786997 13139 0x55d5816ae440 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/FaceDetect/model.etlt_b1_gpu0_int8.engine
0:00:16.777376710 13139 0x55d5816ae440 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:…/…/…/configs/nvinfer/facial_tao/config_infer_primary_facenet.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Running…
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
###Decodebin pick nvidia decoder plugin.
Deserializing engine from: /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/Emotionet/model.etlt_b32_gpu0_fp16.engineThe logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. Uses of the global logger, returned by nvinfer1::getLogger(), will return the existing value.
Loaded engine size: 2 MiB
Deserialization required 6569 microseconds.
[MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +2, now: CPU 0, GPU 209 (MiB)
Total per-runner device persistent memory is 0
Total per-runner host persistent memory is 50160
Allocated activation device memory of size 106496
[MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +0, now: CPU 0, GPU 209 (MiB)
CUDA lazy loading is enabled.
Frame Number = 0 Face Count = 2
Frame Number = 1 Face Count = 2
Frame Number = 2 Face Count = 2
Frame Number = 3 Face Count = 2
Frame Number = 4 Face Count = 2
Frame Number = 5 Face Count = 2
Frame Number = 6 Face Count = 2
Frame Number = 7 Face Count = 2
Frame Number = 8 Face Count = 2
Frame Number = 9 Face Count = 2
Frame Number = 10 Face Count = 2
Frame Number = 11 Face Count = 2
Frame Number = 12 Face Count = 2
Frame Number = 13 Face Count = 2
Frame Number = 14 Face Count = 2
Frame Number = 15 Face Count = 2
Frame Number = 16 Face Count = 2
Frame Number = 17 Face Count = 2
Frame Number = 18 Face Count = 2
Frame Number = 19 Face Count = 2
Frame Number = 20 Face Count = 2
Frame Number = 21 Face Count = 2
Frame Number = 22 Face Count = 2
Frame Number = 23 Face Count = 2
Frame Number = 24 Face Count = 2
Frame Number = 25 Face Count = 2
Frame Number = 26 Face Count = 2
Frame Number = 27 Face Count = 2
Frame Number = 28 Face Count = 2
Frame Number = 29 Face Count = 2
Frame Number = 30 Face Count = 2
Frame Number = 31 Face Count = 2
Frame Number = 32 Face Count = 2
Frame Number = 33 Face Count = 2
Frame Number = 34 Face Count = 2
Frame Number = 35 Face Count = 2
Frame Number = 36 Face Count = 2
Frame Number = 37 Face Count = 2
Frame Number = 38 Face Count = 2
Frame Number = 39 Face Count = 2
Frame Number = 40 Face Count = 2
Frame Number = 41 Face Count = 2
Frame Number = 42 Face Count = 2
Frame Number = 43 Face Count = 2
Frame Number = 44 Face Count = 2
Frame Number = 45 Face Count = 2
Frame Number = 46 Face Count = 2
Frame Number = 47 Face Count = 2
Frame Number = 48 Face Count = 2
Frame Number = 49 Face Count = 2
Frame Number = 50 Face Count = 2
Frame Number = 51 Face Count = 2
Frame Number = 52 Face Count = 2
Frame Number = 53 Face Count = 2
Frame Number = 54 Face Count = 2
Frame Number = 55 Face Count = 2
Frame Number = 56 Face Count = 2
Frame Number = 57 Face Count = 2
Frame Number = 58 Face Count = 2
Frame Number = 59 Face Count = 2
Frame Number = 60 Face Count = 2
Frame Number = 61 Face Count = 2
Frame Number = 62 Face Count = 2
Frame Number = 63 Face Count = 2
Frame Number = 64 Face Count = 2
Frame Number = 65 Face Count = 2
Frame Number = 66 Face Count = 2
Frame Number = 67 Face Count = 2
Frame Number = 68 Face Count = 2
Frame Number = 69 Face Count = 2
Frame Number = 70 Face Count = 2
Frame Number = 71 Face Count = 2
Frame Number = 72 Face Count = 2
Frame Number = 73 Face Count = 2
Frame Number = 74 Face Count = 2
Frame Number = 75 Face Count = 2
Frame Number = 76 Face Count = 2
Frame Number = 77 Face Count = 2
Frame Number = 78 Face Count = 2
Frame Number = 79 Face Count = 2
Frame Number = 80 Face Count = 2
Frame Number = 81 Face Count = 2
Frame Number = 82 Face Count = 2
Frame Number = 83 Face Count = 2
Frame Number = 84 Face Count = 2
Frame Number = 85 Face Count = 2
Frame Number = 86 Face Count = 2
Frame Number = 87 Face Count = 2
Frame Number = 88 Face Count = 2
Frame Number = 89 Face Count = 2
Frame Number = 90 Face Count = 2
Frame Number = 91 Face Count = 2
Frame Number = 92 Face Count = 2
Frame Number = 93 Face Count = 2
Frame Number = 94 Face Count = 2
Frame Number = 95 Face Count = 2
Frame Number = 96 Face Count = 2
Frame Number = 97 Face Count = 2
Frame Number = 98 Face Count = 2
Frame Number = 99 Face Count = 2
Frame Number = 100 Face Count = 2
Frame Number = 101 Face Count = 2
Frame Number = 102 Face Count = 2
Frame Number = 103 Face Count = 2
Frame Number = 104 Face Count = 2
Frame Number = 105 Face Count = 2
Frame Number = 106 Face Count = 2
Frame Number = 107 Face Count = 2
Frame Number = 108 Face Count = 2
Frame Number = 109 Face Count = 2
Frame Number = 110 Face Count = 2
Frame Number = 111 Face Count = 2
Frame Number = 112 Face Count = 2
Frame Number = 113 Face Count = 2
Frame Number = 114 Face Count = 2
Frame Number = 115 Face Count = 2
Frame Number = 116 Face Count = 2
Frame Number = 117 Face Count = 2
Frame Number = 118 Face Count = 2
Frame Number = 119 Face Count = 2
Frame Number = 120 Face Count = 2
Frame Number = 121 Face Count = 2
Frame Number = 122 Face Count = 2
Frame Number = 123 Face Count = 2
Frame Number = 124 Face Count = 2
Frame Number = 125 Face Count = 2
Frame Number = 126 Face Count = 2
Frame Number = 127 Face Count = 2
Frame Number = 128 Face Count = 2
Frame Number = 129 Face Count = 2
Frame Number = 130 Face Count = 2
Frame Number = 131 Face Count = 2
Frame Number = 132 Face Count = 2
Frame Number = 133 Face Count = 2
Frame Number = 134 Face Count = 2
Frame Number = 135 Face Count = 2
Frame Number = 136 Face Count = 2
Frame Number = 137 Face Count = 2
Frame Number = 138 Face Count = 2
Frame Number = 139 Face Count = 2
Frame Number = 140 Face Count = 2
Frame Number = 141 Face Count = 2
Frame Number = 142 Face Count = 2
Frame Number = 143 Face Count = 2
Frame Number = 144 Face Count = 2
Frame Number = 145 Face Count = 2
Frame Number = 146 Face Count = 2
Frame Number = 147 Face Count = 2
Frame Number = 148 Face Count = 2
Frame Number = 149 Face Count = 2
Frame Number = 150 Face Count = 2
Frame Number = 151 Face Count = 2
Frame Number = 152 Face Count = 2
Frame Number = 153 Face Count = 2
Frame Number = 154 Face Count = 2
Frame Number = 155 Face Count = 2
Frame Number = 156 Face Count = 2
Frame Number = 157 Face Count = 2
Frame Number = 158 Face Count = 2
Frame Number = 159 Face Count = 2
Frame Number = 160 Face Count = 2
Frame Number = 161 Face Count = 2
Frame Number = 162 Face Count = 2
Frame Number = 163 Face Count = 2
Frame Number = 164 Face Count = 2
Frame Number = 165 Face Count = 2
Frame Number = 166 Face Count = 2
Frame Number = 167 Face Count = 2
Frame Number = 168 Face Count = 2
Frame Number = 169 Face Count = 2
Frame Number = 170 Face Count = 2
Frame Number = 171 Face Count = 2
Frame Number = 172 Face Count = 2
Frame Number = 173 Face Count = 2
Frame Number = 174 Face Count = 2
Frame Number = 175 Face Count = 2
Frame Number = 176 Face Count = 2
Frame Number = 177 Face Count = 2
Frame Number = 178 Face Count = 2
Frame Number = 179 Face Count = 2
Frame Number = 180 Face Count = 2
Frame Number = 181 Face Count = 2
Frame Number = 182 Face Count = 2
Frame Number = 183 Face Count = 2
Frame Number = 184 Face Count = 2
Frame Number = 185 Face Count = 2
Frame Number = 186 Face Count = 2
Frame Number = 187 Face Count = 2
Frame Number = 188 Face Count = 2
Frame Number = 189 Face Count = 2
Frame Number = 190 Face Count = 2
Frame Number = 191 Face Count = 2
Frame Number = 192 Face Count = 2
Frame Number = 193 Face Count = 2
Frame Number = 194 Face Count = 2
Frame Number = 195 Face Count = 2
Frame Number = 196 Face Count = 2
Frame Number = 197 Face Count = 2
Frame Number = 198 Face Count = 2
Frame Number = 199 Face Count = 2
Frame Number = 200 Face Count = 2
Frame Number = 201 Face Count = 2
Frame Number = 202 Face Count = 2
Frame Number = 203 Face Count = 2
Frame Number = 204 Face Count = 2
Frame Number = 205 Face Count = 2
Frame Number = 206 Face Count = 2
Frame Number = 207 Face Count = 2
Frame Number = 208 Face Count = 2
Frame Number = 209 Face Count = 2
Frame Number = 210 Face Count = 2
Frame Number = 211 Face Count = 2
Frame Number = 212 Face Count = 2
Frame Number = 213 Face Count = 2
Frame Number = 214 Face Count = 2
Frame Number = 215 Face Count = 2
Frame Number = 216 Face Count = 2
Frame Number = 217 Face Count = 2
Frame Number = 218 Face Count = 2
Frame Number = 219 Face Count = 2
Frame Number = 220 Face Count = 2
Frame Number = 221 Face Count = 2
Frame Number = 222 Face Count = 2
Frame Number = 223 Face Count = 2
Frame Number = 224 Face Count = 2
Frame Number = 225 Face Count = 2
Frame Number = 226 Face Count = 2
Frame Number = 227 Face Count = 2
Frame Number = 228 Face Count = 2
Frame Number = 229 Face Count = 2
Frame Number = 230 Face Count = 2
Frame Number = 231 Face Count = 2
Frame Number = 232 Face Count = 2
Frame Number = 233 Face Count = 2
Frame Number = 234 Face Count = 2
Frame Number = 235 Face Count = 2
Frame Number = 236 Face Count = 2
Frame Number = 237 Face Count = 2
Frame Number = 238 Face Count = 2
Frame Number = 239 Face Count = 2
Frame Number = 240 Face Count = 2
Frame Number = 241 Face Count = 2
Frame Number = 242 Face Count = 2
Frame Number = 243 Face Count = 2
Frame Number = 244 Face Count = 2
Frame Number = 245 Face Count = 2
Frame Number = 246 Face Count = 2
Frame Number = 247 Face Count = 2
Frame Number = 248 Face Count = 2
Frame Number = 249 Face Count = 2
Frame Number = 250 Face Count = 2
Frame Number = 251 Face Count = 2
Frame Number = 252 Face Count = 2
Frame Number = 253 Face Count = 2
Frame Number = 254 Face Count = 2
Frame Number = 255 Face Count = 2
Frame Number = 256 Face Count = 2
Frame Number = 257 Face Count = 2
Frame Number = 258 Face Count = 2
Frame Number = 259 Face Count = 2
Frame Number = 260 Face Count = 2
Frame Number = 261 Face Count = 2
Frame Number = 262 Face Count = 2
Frame Number = 263 Face Count = 2
Frame Number = 264 Face Count = 2
Frame Number = 265 Face Count = 2
Frame Number = 266 Face Count = 2
Frame Number = 267 Face Count = 2
Frame Number = 268 Face Count = 2
Frame Number = 269 Face Count = 2
Frame Number = 270 Face Count = 2
Frame Number = 271 Face Count = 2
Frame Number = 272 Face Count = 2
Frame Number = 273 Face Count = 2
Frame Number = 274 Face Count = 2
Frame Number = 275 Face Count = 2
Frame Number = 276 Face Count = 2
Frame Number = 277 Face Count = 2
Frame Number = 278 Face Count = 2
Frame Number = 279 Face Count = 2
Frame Number = 280 Face Count = 2
Frame Number = 281 Face Count = 2
Frame Number = 282 Face Count = 2
Frame Number = 283 Face Count = 2
Frame Number = 284 Face Count = 2
Frame Number = 285 Face Count = 2
Frame Number = 286 Face Count = 2
Frame Number = 287 Face Count = 2
Frame Number = 288 Face Count = 2
Frame Number = 289 Face Count = 2
Frame Number = 290 Face Count = 2
Frame Number = 291 Face Count = 2
Frame Number = 292 Face Count = 2
Frame Number = 293 Face Count = 2
Frame Number = 294 Face Count = 2
Frame Number = 295 Face Count = 2
Frame Number = 296 Face Count = 2
Frame Number = 297 Face Count = 2
Frame Number = 298 Face Count = 2
Frame Number = 299 Face Count = 2
Frame Number = 300 Face Count = 2
Frame Number = 301 Face Count = 2
Frame Number = 302 Face Count = 2
Frame Number = 303 Face Count = 2
Frame Number = 304 Face Count = 2
Frame Number = 305 Face Count = 2
Frame Number = 306 Face Count = 2
Frame Number = 307 Face Count = 2
Frame Number = 308 Face Count = 2
Frame Number = 309 Face Count = 2
Frame Number = 310 Face Count = 2
Frame Number = 311 Face Count = 2
Frame Number = 312 Face Count = 2
Frame Number = 313 Face Count = 2
Frame Number = 314 Face Count = 2
Frame Number = 315 Face Count = 2
Frame Number = 316 Face Count = 2
Frame Number = 317 Face Count = 2
Frame Number = 318 Face Count = 2
Frame Number = 319 Face Count = 2
Frame Number = 320 Face Count = 2
Frame Number = 321 Face Count = 2
Frame Number = 322 Face Count = 2
Frame Number = 323 Face Count = 2
Frame Number = 324 Face Count = 2
Frame Number = 325 Face Count = 2
Frame Number = 326 Face Count = 2
Frame Number = 327 Face Count = 2
Frame Number = 328 Face Count = 2
Frame Number = 329 Face Count = 2
Frame Number = 330 Face Count = 2
Frame Number = 331 Face Count = 2
Frame Number = 332 Face Count = 2
Frame Number = 333 Face Count = 2
Frame Number = 334 Face Count = 2
Frame Number = 335 Face Count = 2
Frame Number = 336 Face Count = 2
Frame Number = 337 Face Count = 2
Frame Number = 338 Face Count = 2
Frame Number = 339 Face Count = 2
Frame Number = 340 Face Count = 2
Frame Number = 341 Face Count = 2
Frame Number = 342 Face Count = 2
Frame Number = 343 Face Count = 2
Frame Number = 344 Face Count = 2
Frame Number = 345 Face Count = 2
Frame Number = 346 Face Count = 2
Frame Number = 347 Face Count = 2
Frame Number = 348 Face Count = 2
Frame Number = 349 Face Count = 2
Frame Number = 350 Face Count = 2
Frame Number = 351 Face Count = 2
Frame Number = 352 Face Count = 2
Frame Number = 353 Face Count = 2
Frame Number = 354 Face Count = 2
Frame Number = 355 Face Count = 2
Frame Number = 356 Face Count = 2
Frame Number = 357 Face Count = 2
Frame Number = 358 Face Count = 2
Frame Number = 359 Face Count = 2
Frame Number = 360 Face Count = 2
Frame Number = 361 Face Count = 2
Frame Number = 362 Face Count = 2
Frame Number = 363 Face Count = 2
Frame Number = 364 Face Count = 2
Frame Number = 365 Face Count = 2
Frame Number = 366 Face Count = 2
Frame Number = 367 Face Count = 2
Frame Number = 368 Face Count = 2
Frame Number = 369 Face Count = 2
Frame Number = 370 Face Count = 2
Frame Number = 371 Face Count = 2
Frame Number = 372 Face Count = 2
Frame Number = 373 Face Count = 2
Frame Number = 374 Face Count = 2
Frame Number = 375 Face Count = 2
Frame Number = 376 Face Count = 2
Frame Number = 377 Face Count = 2
Frame Number = 378 Face Count = 2
Frame Number = 379 Face Count = 2
Frame Number = 380 Face Count = 2
Frame Number = 381 Face Count = 2
Frame Number = 382 Face Count = 2
Frame Number = 383 Face Count = 2
Frame Number = 384 Face Count = 2
Frame Number = 385 Face Count = 2
Frame Number = 386 Face Count = 2
Frame Number = 387 Face Count = 2
Frame Number = 388 Face Count = 2
Frame Number = 389 Face Count = 2
Frame Number = 390 Face Count = 2
Frame Number = 391 Face Count = 2
Frame Number = 392 Face Count = 2
Frame Number = 393 Face Count = 2
Frame Number = 394 Face Count = 2
Frame Number = 395 Face Count = 2
Frame Number = 396 Face Count = 2
Frame Number = 397 Face Count = 2
Frame Number = 398 Face Count = 2
Frame Number = 399 Face Count = 2
Frame Number = 400 Face Count = 2
Frame Number = 401 Face Count = 2
Frame Number = 402 Face Count = 2
Frame Number = 403 Face Count = 2
Frame Number = 404 Face Count = 2
Frame Number = 405 Face Count = 2
Frame Number = 406 Face Count = 2
Frame Number = 407 Face Count = 2
Frame Number = 408 Face Count = 2
Frame Number = 409 Face Count = 2
Frame Number = 410 Face Count = 2
Frame Number = 411 Face Count = 2
Frame Number = 412 Face Count = 2
Frame Number = 413 Face Count = 2
Frame Number = 414 Face Count = 2
Frame Number = 415 Face Count = 2
Frame Number = 416 Face Count = 2
Frame Number = 417 Face Count = 2
Frame Number = 418 Face Count = 2
Frame Number = 419 Face Count = 2
Frame Number = 420 Face Count = 2
Frame Number = 421 Face Count = 2
Frame Number = 422 Face Count = 2
Frame Number = 423 Face Count = 2
Frame Number = 424 Face Count = 2
Frame Number = 425 Face Count = 2
Frame Number = 426 Face Count = 2
Frame Number = 427 Face Count = 2
Frame Number = 428 Face Count = 2
Frame Number = 429 Face Count = 2
Frame Number = 430 Face Count = 2
Frame Number = 431 Face Count = 2
Frame Number = 432 Face Count = 2
Frame Number = 433 Face Count = 2
Frame Number = 434 Face Count = 2
Frame Number = 435 Face Count = 2
Frame Number = 436 Face Count = 2
Frame Number = 437 Face Count = 2
Frame Number = 438 Face Count = 2
Frame Number = 439 Face Count = 2
Frame Number = 440 Face Count = 2
Frame Number = 441 Face Count = 2
Frame Number = 442 Face Count = 2
Frame Number = 443 Face Count = 2
Frame Number = 444 Face Count = 2
Frame Number = 445 Face Count = 2
Frame Number = 446 Face Count = 2
Frame Number = 447 Face Count = 2
Frame Number = 448 Face Count = 2
Frame Number = 449 Face Count = 2
Frame Number = 450 Face Count = 2
Frame Number = 451 Face Count = 2
Frame Number = 452 Face Count = 2
Frame Number = 453 Face Count = 2
Frame Number = 454 Face Count = 2
Frame Number = 455 Face Count = 2
Frame Number = 456 Face Count = 2
Frame Number = 457 Face Count = 2
Frame Number = 458 Face Count = 2
Frame Number = 459 Face Count = 2
Frame Number = 460 Face Count = 2
Frame Number = 461 Face Count = 2
Frame Number = 462 Face Count = 2
Frame Number = 463 Face Count = 2
Frame Number = 464 Face Count = 2
Frame Number = 465 Face Count = 2
Frame Number = 466 Face Count = 2
Frame Number = 467 Face Count = 2
Frame Number = 468 Face Count = 2
Frame Number = 469 Face Count = 2
Frame Number = 470 Face Count = 2
Frame Number = 471 Face Count = 2
Frame Number = 472 Face Count = 2
Frame Number = 473 Face Count = 2
Frame Number = 474 Face Count = 2
Frame Number = 475 Face Count = 2
Frame Number = 476 Face Count = 2
Frame Number = 477 Face Count = 2
Frame Number = 478 Face Count = 2
Frame Number = 479 Face Count = 2
Frame Number = 480 Face Count = 2
Frame Number = 481 Face Count = 2
Frame Number = 482 Face Count = 2
Frame Number = 483 Face Count = 2
Frame Number = 484 Face Count = 2
Frame Number = 485 Face Count = 2
Frame Number = 486 Face Count = 2
Frame Number = 487 Face Count = 2
Frame Number = 488 Face Count = 2
Frame Number = 489 Face Count = 2
Frame Number = 490 Face Count = 2
Frame Number = 491 Face Count = 2
Frame Number = 492 Face Count = 2
Frame Number = 493 Face Count = 2
Frame Number = 494 Face Count = 2
Frame Number = 495 Face Count = 2
Frame Number = 496 Face Count = 2
Frame Number = 497 Face Count = 2
Frame Number = 498 Face Count = 2
Frame Number = 499 Face Count = 2
Frame Number = 500 Face Count = 2
Frame Number = 501 Face Count = 2
Frame Number = 502 Face Count = 2
Frame Number = 503 Face Count = 2
Frame Number = 504 Face Count = 2
Frame Number = 505 Face Count = 2
Frame Number = 506 Face Count = 2
Frame Number = 507 Face Count = 2
Frame Number = 508 Face Count = 2
Frame Number = 509 Face Count = 2
Frame Number = 510 Face Count = 2
Frame Number = 511 Face Count = 2
Frame Number = 512 Face Count = 2
Frame Number = 513 Face Count = 2
Frame Number = 514 Face Count = 2
Frame Number = 515 Face Count = 2
Frame Number = 516 Face Count = 2
Frame Number = 517 Face Count = 2
Frame Number = 518 Face Count = 2
Frame Number = 519 Face Count = 2
Frame Number = 520 Face Count = 2
Frame Number = 521 Face Count = 2
Frame Number = 522 Face Count = 2
Frame Number = 523 Face Count = 2
Frame Number = 524 Face Count = 2
Frame Number = 525 Face Count = 2
Frame Number = 526 Face Count = 2
Frame Number = 527 Face Count = 2
Frame Number = 528 Face Count = 2
Frame Number = 529 Face Count = 2
Frame Number = 530 Face Count = 2
Frame Number = 531 Face Count = 2
Frame Number = 532 Face Count = 2
Frame Number = 533 Face Count = 2
Frame Number = 534 Face Count = 2
Frame Number = 535 Face Count = 2
Frame Number = 536 Face Count = 2
Frame Number = 537 Face Count = 2
Frame Number = 538 Face Count = 2
Frame Number = 539 Face Count = 2
Frame Number = 540 Face Count = 2
Frame Number = 541 Face Count = 2
Frame Number = 542 Face Count = 2
Frame Number = 543 Face Count = 2
Frame Number = 544 Face Count = 2
Frame Number = 545 Face Count = 2
Frame Number = 546 Face Count = 2
Frame Number = 547 Face Count = 2
Frame Number = 548 Face Count = 2
Frame Number = 549 Face Count = 2
Frame Number = 550 Face Count = 2
Frame Number = 551 Face Count = 2
Frame Number = 552 Face Count = 2
Frame Number = 553 Face Count = 2
Frame Number = 554 Face Count = 2
Frame Number = 555 Face Count = 2
Frame Number = 556 Face Count = 2
Frame Number = 557 Face Count = 2
Frame Number = 558 Face Count = 2
Frame Number = 559 Face Count = 2
Frame Number = 560 Face Count = 2
Frame Number = 561 Face Count = 2
Frame Number = 562 Face Count = 2
Frame Number = 563 Face Count = 2
Frame Number = 564 Face Count = 2
Frame Number = 565 Face Count = 2
Frame Number = 566 Face Count = 2
Frame Number = 567 Face Count = 2
Frame Number = 568 Face Count = 2
Frame Number = 569 Face Count = 2
Frame Number = 570 Face Count = 2
Frame Number = 571 Face Count = 2
Frame Number = 572 Face Count = 2
Frame Number = 573 Face Count = 2
Frame Number = 574 Face Count = 2
Frame Number = 575 Face Count = 2
Frame Number = 576 Face Count = 2
Frame Number = 577 Face Count = 2
Frame Number = 578 Face Count = 2
Frame Number = 579 Face Count = 2
Frame Number = 580 Face Count = 2
Frame Number = 581 Face Count = 2
Frame Number = 582 Face Count = 2
Frame Number = 583 Face Count = 2
Frame Number = 584 Face Count = 2
Frame Number = 585 Face Count = 2
Frame Number = 586 Face Count = 2
Frame Number = 587 Face Count = 2
Frame Number = 588 Face Count = 2
Frame Number = 589 Face Count = 2
Frame Number = 590 Face Count = 2
Frame Number = 591 Face Count = 2
Frame Number = 592 Face Count = 2
Frame Number = 593 Face Count = 2
Frame Number = 594 Face Count = 2
Frame Number = 595 Face Count = 2
Frame Number = 596 Face Count = 2
Frame Number = 597 Face Count = 2
Frame Number = 598 Face Count = 2
Frame Number = 599 Face Count = 2
Frame Number = 600 Face Count = 2
Frame Number = 601 Face Count = 2
Frame Number = 602 Face Count = 2
Frame Number = 603 Face Count = 2
Frame Number = 604 Face Count = 2
Frame Number = 605 Face Count = 2
Frame Number = 606 Face Count = 2
Frame Number = 607 Face Count = 2
Frame Number = 608 Face Count = 2
Frame Number = 609 Face Count = 2
Frame Number = 610 Face Count = 2
Frame Number = 611 Face Count = 2
Frame Number = 612 Face Count = 2
Frame Number = 613 Face Count = 2
Frame Number = 614 Face Count = 2
Frame Number = 615 Face Count = 2
Frame Number = 616 Face Count = 2
Frame Number = 617 Face Count = 2
Frame Number = 618 Face Count = 2
Frame Number = 619 Face Count = 2
Frame Number = 620 Face Count = 2
Frame Number = 621 Face Count = 2
Frame Number = 622 Face Count = 2
Frame Number = 623 Face Count = 2
Frame Number = 624 Face Count = 2
Frame Number = 625 Face Count = 2
Frame Number = 626 Face Count = 2
Frame Number = 627 Face Count = 2
Frame Number = 628 Face Count = 2
Frame Number = 629 Face Count = 2
Frame Number = 630 Face Count = 2
Frame Number = 631 Face Count = 2
Frame Number = 632 Face Count = 2
Frame Number = 633 Face Count = 2
Frame Number = 634 Face Count = 2
Frame Number = 635 Face Count = 2
Frame Number = 636 Face Count = 2
Frame Number = 637 Face Count = 2
Frame Number = 638 Face Count = 2
Frame Number = 639 Face Count = 2
Frame Number = 640 Face Count = 2
Frame Number = 641 Face Count = 2
Frame Number = 642 Face Count = 2
Frame Number = 643 Face Count = 2
Frame Number = 644 Face Count = 2
Frame Number = 645 Face Count = 2
Frame Number = 646 Face Count = 2
Frame Number = 647 Face Count = 2
Frame Number = 648 Face Count = 2
Frame Number = 649 Face Count = 2
Frame Number = 650 Face Count = 2
Frame Number = 651 Face Count = 2
Frame Number = 652 Face Count = 2
Frame Number = 653 Face Count = 2
Frame Number = 654 Face Count = 2
Frame Number = 655 Face Count = 2
Frame Number = 656 Face Count = 2
Frame Number = 657 Face Count = 2
Frame Number = 658 Face Count = 2
Frame Number = 659 Face Count = 2
Frame Number = 660 Face Count = 2
Frame Number = 661 Face Count = 2
Frame Number = 662 Face Count = 2
Frame Number = 663 Face Count = 2
Frame Number = 664 Face Count = 2
Frame Number = 665 Face Count = 2
Frame Number = 666 Face Count = 2
Frame Number = 667 Face Count = 2
Frame Number = 668 Face Count = 2
Frame Number = 669 Face Count = 2
Frame Number = 670 Face Count = 2
Frame Number = 671 Face Count = 2
Frame Number = 672 Face Count = 2
Frame Number = 673 Face Count = 2
Frame Number = 674 Face Count = 2
Frame Number = 675 Face Count = 2
Frame Number = 676 Face Count = 2
Frame Number = 677 Face Count = 2
Frame Number = 678 Face Count = 2
Frame Number = 679 Face Count = 2
Frame Number = 680 Face Count = 2
Frame Number = 681 Face Count = 2
Frame Number = 682 Face Count = 2
Frame Number = 683 Face Count = 2
Frame Number = 684 Face Count = 2
Frame Number = 685 Face Count = 2
Frame Number = 686 Face Count = 2
Frame Number = 687 Face Count = 2
Frame Number = 688 Face Count = 2
Frame Number = 689 Face Count = 2
Frame Number = 690 Face Count = 2
Frame Number = 691 Face Count = 2
Frame Number = 692 Face Count = 2
Frame Number = 693 Face Count = 2
Frame Number = 694 Face Count = 2
Frame Number = 695 Face Count = 2
Frame Number = 696 Face Count = 2
Frame Number = 697 Face Count = 2
Frame Number = 698 Face Count = 2
Frame Number = 699 Face Count = 2
Frame Number = 700 Face Count = 2
Frame Number = 701 Face Count = 2
Frame Number = 702 Face Count = 2
Frame Number = 703 Face Count = 2
Frame Number = 704 Face Count = 2
Frame Number = 705 Face Count = 2
Frame Number = 706 Face Count = 2
Frame Number = 707 Face Count = 2
Frame Number = 708 Face Count = 2
Frame Number = 709 Face Count = 2
Frame Number = 710 Face Count = 2
Frame Number = 711 Face Count = 2
Frame Number = 712 Face Count = 2
Frame Number = 713 Face Count = 2
Frame Number = 714 Face Count = 2
Frame Number = 715 Face Count = 2
Frame Number = 716 Face Count = 2
Frame Number = 717 Face Count = 2
Frame Number = 718 Face Count = 2
Frame Number = 719 Face Count = 2
Frame Number = 720 Face Count = 2
Frame Number = 721 Face Count = 2
Frame Number = 722 Face Count = 2
Frame Number = 723 Face Count = 2
Frame Number = 724 Face Count = 2
Frame Number = 725 Face Count = 2
Frame Number = 726 Face Count = 2
Frame Number = 727 Face Count = 2
Frame Number = 728 Face Count = 2
Frame Number = 729 Face Count = 2
Frame Number = 730 Face Count = 2
Frame Number = 731 Face Count = 2
Frame Number = 732 Face Count = 2
Frame Number = 733 Face Count = 2
Frame Number = 734 Face Count = 2
Frame Number = 735 Face Count = 2
Frame Number = 736 Face Count = 2
Frame Number = 737 Face Count = 2
Frame Number = 738 Face Count = 2
Frame Number = 739 Face Count = 2
Frame Number = 740 Face Count = 2
Frame Number = 741 Face Count = 2
Frame Number = 742 Face Count = 2
Frame Number = 743 Face Count = 2
Frame Number = 744 Face Count = 2
Frame Number = 745 Face Count = 2
Frame Number = 746 Face Count = 2
Frame Number = 747 Face Count = 2
Frame Number = 748 Face Count = 2
Frame Number = 749 Face Count = 2
Frame Number = 750 Face Count = 2
Frame Number = 751 Face Count = 2
Frame Number = 752 Face Count = 2
Frame Number = 753 Face Count = 2
Frame Number = 754 Face Count = 2
Frame Number = 755 Face Count = 2
Frame Number = 756 Face Count = 2
Frame Number = 757 Face Count = 2
Frame Number = 758 Face Count = 2
Frame Number = 759 Face Count = 2
Frame Number = 760 Face Count = 2
Frame Number = 761 Face Count = 2
Frame Number = 762 Face Count = 2
Frame Number = 763 Face Count = 2
Frame Number = 764 Face Count = 2
Frame Number = 765 Face Count = 2
Frame Number = 766 Face Count = 2
Frame Number = 767 Face Count = 2
Frame Number = 768 Face Count = 2
Frame Number = 769 Face Count = 2
Frame Number = 770 Face Count = 2
Frame Number = 771 Face Count = 2
Frame Number = 772 Face Count = 2
Frame Number = 773 Face Count = 2
Frame Number = 774 Face Count = 2
Frame Number = 775 Face Count = 2
Frame Number = 776 Face Count = 2
Frame Number = 777 Face Count = 2
Frame Number = 778 Face Count = 2
Frame Number = 779 Face Count = 2
Frame Number = 780 Face Count = 2
Frame Number = 781 Face Count = 2
Frame Number = 782 Face Count = 2
Frame Number = 783 Face Count = 2
Frame Number = 784 Face Count = 2
Frame Number = 785 Face Count = 2
Frame Number = 786 Face Count = 2
Frame Number = 787 Face Count = 2
Frame Number = 788 Face Count = 2
Frame Number = 789 Face Count = 2
Frame Number = 790 Face Count = 2
Frame Number = 791 Face Count = 2
Frame Number = 792 Face Count = 2
Frame Number = 793 Face Count = 2
Frame Number = 794 Face Count = 2
Frame Number = 795 Face Count = 2
Frame Number = 796 Face Count = 2
Frame Number = 797 Face Count = 2
Frame Number = 798 Face Count = 2
Frame Number = 799 Face Count = 2
Frame Number = 800 Face Count = 2
Frame Number = 801 Face Count = 2
Frame Number = 802 Face Count = 2
Frame Number = 803 Face Count = 2
Frame Number = 804 Face Count = 2
Frame Number = 805 Face Count = 2
Frame Number = 806 Face Count = 2
Frame Number = 807 Face Count = 2
Frame Number = 808 Face Count = 2
Frame Number = 809 Face Count = 2
Frame Number = 810 Face Count = 2
Frame Number = 811 Face Count = 2
Frame Number = 812 Face Count = 2
Frame Number = 813 Face Count = 2
Frame Number = 814 Face Count = 2
Frame Number = 815 Face Count = 2
Frame Number = 816 Face Count = 2
Frame Number = 817 Face Count = 2
Frame Number = 818 Face Count = 2
Frame Number = 819 Face Count = 2
Frame Number = 820 Face Count = 2
Frame Number = 821 Face Count = 2
Frame Number = 822 Face Count = 2
Frame Number = 823 Face Count = 2
Frame Number = 824 Face Count = 2
Frame Number = 825 Face Count = 2
Frame Number = 826 Face Count = 2
Frame Number = 827 Face Count = 2
Frame Number = 828 Face Count = 2
Frame Number = 829 Face Count = 2
Frame Number = 830 Face Count = 2
Frame Number = 831 Face Count = 2
Frame Number = 832 Face Count = 2
Frame Number = 833 Face Count = 2
Frame Number = 834 Face Count = 2
Frame Number = 835 Face Count = 2
Frame Number = 836 Face Count = 2
Frame Number = 837 Face Count = 2
Frame Number = 838 Face Count = 2
Frame Number = 839 Face Count = 2
Frame Number = 840 Face Count = 2
Frame Number = 841 Face Count = 2
Frame Number = 842 Face Count = 2
Frame Number = 843 Face Count = 2
Frame Number = 844 Face Count = 2
Frame Number = 845 Face Count = 2
Frame Number = 846 Face Count = 2
Frame Number = 847 Face Count = 2
Frame Number = 848 Face Count = 2
Frame Number = 849 Face Count = 2
Frame Number = 850 Face Count = 2
Frame Number = 851 Face Count = 2
Frame Number = 852 Face Count = 2
Frame Number = 853 Face Count = 2
Frame Number = 854 Face Count = 2
Frame Number = 855 Face Count = 2
Frame Number = 856 Face Count = 2
Frame Number = 857 Face Count = 2
Frame Number = 858 Face Count = 2
Frame Number = 859 Face Count = 2
Frame Number = 860 Face Count = 2
Frame Number = 861 Face Count = 2
Frame Number = 862 Face Count = 2
Frame Number = 863 Face Count = 2
Frame Number = 864 Face Count = 2
Frame Number = 865 Face Count = 2
Frame Number = 866 Face Count = 2
Frame Number = 867 Face Count = 2
Frame Number = 868 Face Count = 2
Frame Number = 869 Face Count = 2
Frame Number = 870 Face Count = 2
Frame Number = 871 Face Count = 2
Frame Number = 872 Face Count = 2
Frame Number = 873 Face Count = 2
Frame Number = 874 Face Count = 2
Frame Number = 875 Face Count = 2
Frame Number = 876 Face Count = 2
Frame Number = 877 Face Count = 2
Frame Number = 878 Face Count = 2
Frame Number = 879 Face Count = 2
Frame Number = 880 Face Count = 2
Frame Number = 881 Face Count = 2
Frame Number = 882 Face Count = 2
Frame Number = 883 Face Count = 2
Frame Number = 884 Face Count = 2
Frame Number = 885 Face Count = 2
Frame Number = 886 Face Count = 2
Frame Number = 887 Face Count = 2
Frame Number = 888 Face Count = 2
nvstreammux: Successfully handled EOS for source_id=0
Frame Number = 889 Face Count = 2
End of stream
Returned, stopping playback
Average fps 203.634416
Totally 1780 faces are inferred
Deleting pipeline
even though i have tested in before and i was able to see the output of the file in .mp4 format but now im not able to view the video file with metadata anywhere in the directory, even though there is no restrictions of file permissions.
Kindly help me here why im not able to save the video file, im in very bad situation kindly help soon.
waiting for your response please help me.
i fixed the issue with just simple error in the executing command, the only change i made was replacing 2 to 1only.
export the correct command was this below:
./deepstream-emotion-app 1 /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/sample_faciallandmarks_config.txt file:///opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/notebooks/footage.mp4 ./test
this was the main change:
correct: ./deepstream-emotion-app 1 from incorrect: ./deepstream-emotion-app 2
