"Empty header line found in CSV file" in CisualProfiler?
Im using CUDA2.2 ( toolkit, SDK and Drivers on windows XP 32bit machine.
Im getting the below error (after 4th run), when I run the CUDA Visual Profiler 2.2.
“Empty header line found in CSV file”
  • What is the reson for this?
  • Do I need to set any environmental variables for running Visual Profiler?
  • Anyone able to run successfully?
I’m seeing the exact same problem. I would definitely appreciate any suggestions anyone has…
Same problem.
Any idea?
Environment:
Ubuntu 9.04
Driver 180.xxx
Toolkit 2.2
SDK 2.2
Hi, I had the same mistake, using profiler Ver: 3.0.23
I avoided the cutil function that prevents the premature closing of the window
and it works.
cutilExit(argc, argv);
Hola, Tenia el mismo problema con la vesión 3.0.23 del profiler,
Le quite la funcion que evita que se cierre la ventana
y se soluciono.
:teehee:
Jacobo S
and it works.
y se soluciono.
:teehee:
Jacobo S
Making sure the program hits cudaThreadExit() when it terminates is a good idea.
