Hi Mat,
Thank you for replay. My code is :
MODULE EQFORCCOLL
USE CUDAFOR
REAL,DEVICE,ALLOCATABLE :: ZB_D(:,:),G11_D(:,:),G22_D(:,:),G12_D(:,:),JA_D(:,:),&
DJAKSI_D(:,:),DJAETA_D(:,:),DXKSI_D(:,:),DXETA_D(:,:),DYKSI_D(:,:),DYETA_D(:,:),&
G22JAKSI_D(:,:,:),G22JAETA_D(:,:),G11JAKSI_D(:,:),G11JAETA_D(:,:,:),&
DXKSIKSI_D(:,:),DYKSIKSI_D(:,:),DXETAKSI_D(:,:),DYETAKSI_D(:,:),DXETAETA_D(:,:),DYETAETA_D(:,:)
CONTAINS
ATTRIBUTES(GLOBAL) SUBROUTINE EQUIL_FORCE_S_COLLIDE(F,U,H,UKAR,EX,EY,&
VIS,DT,G,MKH,KHZM,JLL,KKV,&
MT,MINV,TSTEP,XDIM,YDIM,TSX,TSY,&
SR2,SR3,SR5,SR7)
IMPLICIT NONE
INTEGER,PARAMETER :: E(0:8,2) = RESHAPE([0, 1, 1, 0,-1,-1,-1, 0, 1, 0, 0, 1, 1, 1, 0,-1,-1,-1],[9,2])
INTEGER :: I, J, K, K1,P, X, Y, ID, RDKDE, NT, TN, CHUNK,NTHREADS,TID
INTEGER,VALUE :: XDIM,YDIM,TSTEP
INTEGER1 :: JLL(:,:,:)
INTEGER2 :: STATUS
REAL :: DKSI,DETA,FORCEX,FORCEY,&
CT,Z0,KZ,TAU,OM,TETA,TAUT
REAL :: H(:,:),U(:,:,:),UKAR(:,:,:),ZB(:,:),KHZM(:,:)
REAL :: F(:,:,:),FEQ(0:8),FORCEL(0:8),S(0:8)
REAL :: FEQ1,FEQ2,FEQ3,FEQ4,FEQ5,FEQ6,FEQ7,FEQ8
REAL :: G11(:,:),G22(:,:),G12(:,:),JA(:,:),&
G22JAKSI(:,:,:),G22JAETA(:,:),G11JAKSI(:,:),G11JAETA(:,:,:),&
DXKSI(:,:),DXETA(:,:),DYKSI(:,:),DYETA(:,:),&
DJAKSI(:,:),DJAETA(:,:),&
DXKSIKSI(:,:),DYKSIKSI(:,:),DXETAKSI(:,:),DYETAKSI(:,:),&
DXETAETA(:,:),DYETAETA(:,:),VIS(:,:),VISE(:,:)
REAL :: HINT,HINTS,HINTSS,U1INT,U2INT,U1INTS,U2INTS,UKAR1INT,UKAR2INT
REAL :: G22INT,G12INT,G11INT,JAINT,DXKSIINT,DXETAINT,DYKSIINT,DYETAINT,&
DXKSIKSIINT,DYKSIKSIINT,DXETAKSIINT,DYETAKSIINT,DXETAETAINT,DYETAETAINT,&
DJAKSIINT,DJAETAINT,KGINT,TXXINT,TYYINT,TXYINT,HUKSIINT,HUETAINT,HVKSIINT,HVETAINT
REAL :: MT(9,9),MMF(1:9),MINV(9,9),DF(1:9),DDF(1:9),C(0:8),SD(1:9),PR,CR,SP
REAL,VALUE :: SR2,SR3,SR5,SR7,MKH,G,EX,EY,DT,KKV,TSX,TSY
REAL :: TIME1, TIME2, TIMETOT
COMMON/GRIDPARAM/DKSI,DETA,RDKDE
X=(BLOCKIDX%X-1)*BLOCKDIM%X+THREADIDX%X
Y=(BLOCKIDX%Y-1)*BLOCKDIM%Y+THREADIDX%Y
FORCEL=0.0
TETA=0.5
DO I=0,8
! PRORACUN HIDRAULICKIH KOMPONENTI STRUJANJA NA POLOVINI LINKA
IF (I.EQ.0) THEN
J=0
ELSE
J=JLL(I,X,Y)
ENDIF
HINT = (H(X,Y)+H(X+E(J,1),Y+E(J,2)))*0.5
HINTS = (H(X,Y)**2.+H(X+E(J,1),Y+E(J,2))**2.)*0.5
HINTSS = (H(X,Y)**0.333+H(X+E(J,1),Y+E(J,2))**0.333)*0.5
U1INT = (U(1,X,Y)+U(1,X+E(J,1),Y+E(J,2)))*0.5
U2INT = (U(2,X,Y)+U(2,X+E(J,1),Y+E(J,2)))*0.5
UKAR1INT = (UKAR(1,X,Y)+UKAR(1,X+E(J,1),Y+E(J,2)))*0.5
UKAR2INT = (UKAR(2,X,Y)+UKAR(2,X+E(J,1),Y+E(J,2)))*0.5
U1INTS = (U(1,X,Y)**2.+U(1,X+E(J,1),Y+E(J,2))**2.)*0.5
U2INTS = (U(2,X,Y)**2.+U(2,X+E(J,1),Y+E(J,2))**2.)*0.5
G22INT = (G22_D(X,Y)+G22_D(X+E(J,1),Y+E(J,2)))*0.5
G12INT = (G12_D(X,Y)+G12_D(X+E(J,1),Y+E(J,2)))*0.5
G11INT = (G11_D(X,Y)+G11_D(X+E(J,1),Y+E(J,2)))*0.5
JAINT = (JA_D(X,Y)+JA_D(X+E(J,1),Y+E(J,2)))*0.5
DXKSIINT = (DXKSI_D(X,Y)+DXKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DXETAINT = (DXETA_D(X,Y)+DXETA_D(X+E(J,1),Y+E(J,2)))*0.5
DYKSIINT = (DYKSI_D(X,Y)+DYKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DYETAINT = (DYETA_D(X,Y)+DYETA_D(X+E(J,1),Y+E(J,2)))*0.5
DXKSIKSIINT = (DXKSIKSI_D(X,Y)+DXKSIKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DYKSIKSIINT = (DYKSIKSI_D(X,Y)+DYKSIKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DXETAKSIINT = (DXETAKSI_D(X,Y)+DXETAKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DYETAKSIINT = (DYETAKSI_D(X,Y)+DYETAKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DXETAETAINT = (DXETAETA_D(X,Y)+DXETAETA_D(X+E(J,1),Y+E(J,2)))*0.5
DYETAETAINT = (DYETAETA_D(X,Y)+DYETAETA_D(X+E(J,1),Y+E(J,2)))*0.5
DJAKSIINT = (DJAKSI_D(X,Y)+DJAKSI_D(X+E(J,1),Y+E(J,2)))*0.5
DJAETAINT = (DJAETA_D(X,Y)+DJAETA_D(X+E(J,1),Y+E(J,2)))*0.5
! PRORACUN CLANA SILE U X I Y PRAVCU *
CT = G*MKH**2. / HINTSS
KZ = KHZM(X,Y)
FORCEX=-((CT + KZ) * U1INTJAINT**2.)&
SQRT(U1INTSG11INT+2.U1INTU2INTG12INT+U2INTS*G22INT)&
+(JAINT/1000.)(DYETAINTTSX-DXETAINT*TSY)&
-JAINTHINTUKAR2INT*(DXETAKSIINTU1INT+DXETAETAINTU2INT)&
+JAINTHINTUKAR1INT*(DYETAKSIINTU1INT+DYETAETAINTU2INT)
FORCEY=-((CT + KZ) * U2INTJAINT**2.)&
+(JAINT/1000.)(-DYKSIINTTSX+DXKSIINT*TSY)&
+JAINTHINTUKAR2INT*(DXKSIKSIINTU1INT+DXETAKSIINTU2INT)&
-JAINTHINTUKAR1INT*(DYKSIKSIINTU1INT+DYETAKSIINTU2INT)
! PRORACUN CLANA EKVILIBRIJUMA, SILE I CLANA S ZA SVE LINKOVE I= 0 - 8 *
IF (I.EQ.0) THEN
FEQ1= ( (G22_D(X,Y)GH(X,Y))/(4*(EXE(1,1))**2.)+&
(U(1,X,Y)JA_D(X,Y)**2.)/(3EXE(1,1))+&
(U(1,X,Y)**2.JA_D(X,Y)**2.)/(2.(EX*E(1,1))**2.) ) * H(X,Y)+&
( ( -JA_D(X,Y)**3.*U(1,X,Y)*H(X,Y)*VIS(X,Y)*G22JAKSI_D(2,X,Y))-&
( G22_D(X,Y)*H(X,Y)VIS(X,Y)/JA_D(X,Y)(-UKAR(1,X,Y)*DYETAKSI_D(X,Y)+&
UKAR(2,X,Y)*DXETAKSI_D(X,Y)))-&
( G12_D(X,Y)*H(X,Y)VIS(X,Y)/JA_D(X,Y)( UKAR(1,X,Y)DYETAETA_D(X,Y)-&
UKAR(2,X,Y)DXETAETA_D(X,Y))))&
/ (2.(EXE(1,1))**2.)
FEQ5= ( (G22_D(X,Y)GH(X,Y))/(4*(EXE(5,1))**2.)+&
(U(1,X,Y)JA_D(X,Y)**2.)/(3EXE(5,1))+&
(U(1,X,Y)**2.JA_D(X,Y)**2.)/(2.(EX*E(5,1))**2.) ) * H(X,Y)+&
( (-JA_D(X,Y)**3.*U(1,X,Y)*H(X,Y)*VIS(X,Y)*G22JAKSI_D(2,X,Y))-&
/ (2.(EXE(5,1))**2.)
FEQ3= ( (G11_D(X,Y)GH(X,Y))/(4.(EYE(3,2))**2.)+&
(U(2,X,Y)JA_D(X,Y)**2.)/(3.EYE(3,2))+&
(U(2,X,Y)**2.JA_D(X,Y)**2.)/(2.(EYE(3,2))**2.) ) * H(X,Y)+&
( (-JA_D(X,Y)**3.*U(2,X,Y)*H(X,Y)*VIS(X,Y)*G11JAETA_D(2,X,Y))-&
( G11_D(X,Y)*H(X,Y)VIS(X,Y)/JA_D(X,Y)( UKAR(1,X,Y)*DYETAKSI_D(X,Y)-&
( G12_D(X,Y)*H(X,Y)VIS(X,Y)/JA_D(X,Y)(-UKAR(1,X,Y)DYKSIKSI_D(X,Y)+&
UKAR(2,X,Y)DXKSIKSI_D(X,Y))) )&
/ (2.(EYE(3,2))**2.)
FEQ7= ( (G11_D(X,Y)GH(X,Y))/(4.(EYE(7,2))**2.)+&
(U(2,X,Y)JA_D(X,Y)**2.)/(3.EYE(7,2))+&
(U(2,X,Y)**2.JA_D(X,Y)**2.)/(2.(EYE(7,2))**2.) ) * H(X,Y)+&
/ (2.(EYE(7,2))**2.)
FEQ2= ( (U(1,X,Y)*JA_D(X,Y)**2.)/(12.EXE(2,1)) + (U(2,X,Y)*JA_D(X,Y)**2.)/(12.EYE(2,2)) +&
(U(1,X,Y)*U(2,X,Y)*JA_D(X,Y)**2.)/(4.EXE(2,1)EYE(2,2)) ) * H(X,Y)-&
( H(X,Y)VIS(X,Y)/JA_D(X,Y)(G11_D(X,Y)*(UKAR(2,X,Y)*DXETAETA_D(X,Y) - UKAR(1,X,Y)DYETAETA_D(X,Y))+&
G22_D(X,Y)(UKAR(1,X,Y)*DYKSIKSI_D(X,Y) - UKAR(2,X,Y)DXKSIKSI_D(X,Y))+&
JA_D(X,Y)**4.(UKAR(1,X,Y)G11JAETA_D(2,X,Y)+UKAR(2,X,Y)G22JAKSI_D(2,X,Y))) )/&
(4EXE(2,1)EYE(2,2))
FEQ4= ( (U(1,X,Y)*JA_D(X,Y)**2.)/(12.EXE(4,1)) + (U(2,X,Y)*JA_D(X,Y)**2.)/(12.EYE(4,2)) +&
(U(1,X,Y)*U(2,X,Y)*JA_D(X,Y)**2.)/(4.EXE(4,1)EYE(4,2)) ) * H(X,Y)-&
(4EXE(4,1)EYE(4,2))
FEQ6= ( (U(1,X,Y)*JA_D(X,Y)**2.)/(12.EXE(6,1)) + (U(2,X,Y)*JA_D(X,Y)**2.)/(12.EYE(6,2)) +&
(U(1,X,Y)*U(2,X,Y)*JA_D(X,Y)**2.)/(4.EXE(6,1)EYE(6,2)) ) * H(X,Y)-&
(4EXE(6,1)EYE(6,2))
FEQ8= ( (U(1,X,Y)*JA_D(X,Y)**2.)/(12.EXE(8,1)) + (U(2,X,Y)*JA_D(X,Y)**2.)/(12.EYE(8,2)) +&
(U(1,X,Y)*U(2,X,Y)*JA_D(X,Y)**2.)/(4.EXE(8,1)EYE(8,2)) ) * H(X,Y)-&
(4EXE(8,1)EYE(8,2))
FEQ(I) = JA_D(X,Y)**2.*H(X,Y)-(FEQ1+FEQ2+FEQ3+FEQ4+FEQ5+FEQ6+FEQ7+FEQ8)
FORCEL(I)=0.0
S(I)=0.0
MMF(I+1)=F(I,X,Y)-(JA_D(X,Y)**2.*H(X,Y)-(FEQ1+FEQ2+FEQ3+FEQ4+FEQ5+FEQ6+FEQ7+FEQ8))
ELSEIF (I.EQ.1 .OR. I.EQ.5) THEN
! PRAVCI I=1,5
MMF(I+1) = F(I,X,Y)-( (G22_D(X,Y)GH(X,Y))/(4*(EXE(I,1))**2.)+&
(U(1,X,Y)JA_D(X,Y)**2.)/(3EXE(I,1))+&
(U(1,X,Y)**2.JA_D(X,Y)**2.)/(2.(EX*E(I,1))**2.) ) * H(X,Y)+&
/ (2.(EXE(I,1))**2.)
FORCEL(I)=FORCEX/(EXE(I,1)6.)+(JAINTHINTU1INT*DJAKSIINT)/6.
S(I)=G/4.HINTS(G22_D(X+E(J,1),Y+E(J,2))-G22_D(X,Y))/((EXE(I,1))*2.)-&
G/2.HINTG22INT(ZB_D(X+E(J,1),Y+E(J,2))-ZB_D(X,Y))/((EXE(I,1))2.)&
-0.5*VIS(X,Y)*JAINT3.HINTU2INT*&
(G22JAETA_D(X+E(J,1),Y+E(J,2))-G22JAETA_D(X,Y))/((EX*E(I,1))**2.)
ELSEIF (I.EQ.3 .OR. I.EQ.7) THEN
! PRAVCI I=3,7
MMF(I+1) = F(I,X,Y)-( (G11_D(X,Y)GH(X,Y))/(4.(EYE(I,2))**2.)+&
(U(2,X,Y)JA_D(X,Y)**2.)/(3.EYE(I,2))+&
(U(2,X,Y)**2.JA_D(X,Y)**2.)/(2.(EYE(I,2))**2.) ) * H(X,Y)+&
/ (2.(EYE(I,2))**2.)
FORCEL(I)=FORCEY/(EYE(I,2)6.)+(JAINTHINTU2INT*DJAETAINT)/6.
S(I)=G/4.HINTS(G11_D(X+E(J,1),Y+E(J,2))-G11_D(X,Y))/((EYE(I,2))*2.)-&
G/2.HINTG11INT(ZB_D(X+E(J,1),Y+E(J,2))-ZB_D(X,Y))/((EYE(I,2))2.)&
-0.5*VIS(X,Y)*JAINT3.HINTU1INT*(G11JAKSI_D(X+E(J,1),Y+E(J,2))-G11JAKSI_D(X,Y))/((EY*E(I,2))**2.)
ELSEIF (I.EQ.2 .OR. I.EQ.4 .OR. I.EQ.6 .OR. I.EQ.8) THEN
! PRAVCI I=2,4,6,8
MMF(I+1) = F(I,X,Y)-( (U(1,X,Y)*JA_D(X,Y)**2.)/(12.EXE(I,1)) + (U(2,X,Y)*JA_D(X,Y)**2.)/(12.EYE(I,2)) +&
(U(1,X,Y)*U(2,X,Y)*JA_D(X,Y)**2.)/(4.EXE(I,1)EYE(I,2)) ) * H(X,Y)-&
(4EXE(I,1)EYE(I,2))
FORCEL(I)=FORCEX/(EXE(I,1)6.)+FORCEY/(EYE(I,2)6.)+(JAINTHINTU1INTDJAKSIINT+JAINTHINTU2INTDJAETAINT)/6.
S(I)=(G/4.HINTG12INT*( (ZB_D(X+E(J,1),Y+E(J,2))-ZB_D(X,Y)) + (H(X+E(J,1),Y+E(J,2))-H(X,Y))) )/(EX*E(I,1)EYE(I,2))
ENDIF
ENDDO
! PRAVAC I=0
!FEQ(0) = JA(X,Y)2.H(X,Y)-(FEQ(1)+FEQ(2)+FEQ(3)+FEQ(4)+&
! FEQ(5)+FEQ(6)+FEQ(7)+FEQ(8))
! PRORACUN VREMENA RELAKSACIJE TAU *
! IF (DKSI.EQ.DETA) THEN
OM=(TETA*G22_D(X,Y)+(1.-TETA)*G11_D(X,Y))/JA_D(X,Y)**2.
! ELSE
! OM=(G11(X,Y)/JA(X,Y)**2.)/(EY/EX)
! ENDIF
TAUT = VIS(X,Y)OM3.0/(DTEXEY)+0.5
! CLAN SUDARA *
! LBGK METOD
!DO K = 0, 8
!F(K,X,Y) = (1.0D0 - 1.0/TAUT) * F(K,X,Y) + (1.0/TAUT) * FEQ(K) + DT * FORCEL(K)+S(K)
!SK(X,Y) = (F(I,X,Y)*LOG(F(I,X,Y)/FEQ(I))) + SK(X,Y)
!ENDDO
! DO I = 0, 4
! FTUR(I,X,Y) = (1.0D0 - 1.0/TAUTUR) * FTUR(I,X,Y) + (1.0/TAUTUR) * FEQTUR(I) + DT * FORCETURB(I)
! ENDDO
! MRT METOD
SD(1)=1.0
SD(2)=SR2
SD(3)=SR3
SD(4)=1.0
SD(5)=SR5
SD(6)=1.0
SD(7)=SR7
SD(8)=1./TAUT
SD(9)=1./TAUT
! CALL MURRV (MT, MMF(:), DF)
! CALL MURRV (SD,DF,DDF)
! CALL MURRV (MINV,DDF,C)
!MMF(:)=F(:,X,Y)-FEQ(:)
!DF = MATMUL(MT,MMF)
!DDF = MATMUL(SD,DF)
!C = MATMUL(MINV,DDF)
call syncthreads()
DO I=1,9
PR=0.0
DO K=1,9
!PR=PR+(MT(I,K)MMF(K))
ENDDO
DDF(I)=PRSD(I)
ENDDO
DO I = 0, 8
CR=0.0
DO J=0, 8
!CR=CR+(MINV(I+1,J+1)*DDF(J+1))
!C(I)=CR
ENDDO
!F(I,X,Y) = F(I,X,Y) - CR + DT * FORCEL(I) + S(I)
ENDDO
!CALL CPU_TIME(time2)
!TIMETOT = TIMETOT + (TIME2-TIME1)
!WRITE(,)
!WRITE(,) ‘TIME=’,TIMETOT/60.0 ,‘minutes’
!WRITE(,)
!PAUSE
END SUBROUTINE EQUIL_FORCE_S_COLLIDE
END MODULE EQFORCCOLL
PROGRAM MAINLBGK
USE D2Q9CONST
USE UL
USE GEOM
USE CSTR
USE TRMTR
USE INIT
USE EQFORCCOLL
USE CUDAFOR
IMPLICIT NONE
! INCLUDE ‘LINK_FNL_SHARED.H’
INTEGER :: I,J,XDIM,YDIM,TSTEP,RDKDE
INTEGER :: TMAX,DIMQZ,IDWR,BROGR,DIMTEC
INTEGER :: ISTAT,errCode
INTEGER1,ALLOCATABLE :: IMAGE(:,:),OPBND(:,:),JLL(:,:,:)
INTEGER2,ALLOCATABLE :: DIMTP(:,:),IMAGES(:,:),ITZ(:,:),IM(:,:)
INTEGER,ALLOCATABLE :: GRAN(:,:),DIMTIZP(:,:),TEC(:)
REAL,ALLOCATABLE :: G11(:,:), G22(:,:),G12(:,:),JA(:,:),ZB(:,:),&
XCOR(:,:),YCOR(:,:),DJAKSI(:,:),DJAETA(:,:),&
G22KSI(:,:),G11ETA(:,:),G22JAKSI(:,:,:),G22JAETA(:,:),G11JAKSI(:,:),G11JAETA(:,:,:)
REAL,ALLOCATABLE :: DXKSIKSI(:,:),DYKSIKSI(:,:),DXETAKSI(:,:),DYETAKSI(:,:),&
REAL,ALLOCATABLE :: F(:,:,:),U(:,:,:),UKAR(:,:,:),H(:,:),&
VIS(:,:),VISE(:,:),KG(:,:),FTUR(:,:,:),KHZM(:,:),QZ(:,:)
REAL,ALLOCATABLE :: PROM1(:,:),PROM2(:,:),DZB(:,:)
REAL :: EX,EY,DT,KT,OM,KKV,HIN,MKH,KHZ,G,HP,DEL
REAL :: BCP,FP,INP,OUTP
REAL :: DKSI,DETA
REAL :: MT(9,9),MINV(9,9)
REAL :: TAUTUR,CKK,CV,CE
REAL :: TIME1, TIME2, TIMETOT, STOP_CLOCK, START_CLOCK
REAL :: TSX,TSY,SR2,SR3,SR5,SR7
! CUDA PARAMETRI
TYPE(DIM3) :: GRID,TBLOCK
REAL,ALLOCATABLE,DEVICE:: F_D(:,:,:),U_D(:,:,:),UKAR_D(:,:,:),H_D(:,:),VIS_D(:,:),VISE_D(:,:),KHZM_D(:,:)
REAL,DEVICE :: MT_D(9,9),MINV_D(9,9)
INTEGER1,DEVICE,ALLOCATABLE :: JLL_D(:,:,:)
CHARACTER100 PROJECT
COMMON/DIM/XDIM,YDIM
COMMON/TIMEPARAM/TMAX,DT
COMMON/FLOWPARAM/KKV,HIN,MKH,KHZ,G,HP
COMMON/CONPARAM/BCP,FP,INP,OUTP
COMMON/KTURBPARAM/TAUTUR,CKK,CV,CE
COMMON/RELAXPARAM/SR2,SR3,SR5,SR7
COMMON/TECPARAM/DIMTEC
COMMON/WINDPARAM/TSX,TSY
OPEN(11,FILE=‘PROJECT.INP’)
READ(11,“(A100)”) PROJECT
OPEN(1,FILE=PROJECT,ACTION=‘READ’)
OPEN(2,FILE=‘TIZLAZ.PLT’)
CALL GEOMETRIJA(XCOR,YCOR,G11,G12,G22,JA,ZB,DXKSI,DXETA,DYKSI,DYETA,&
DJAKSI,DJAETA,G22KSI,G11ETA,&
DXKSIKSI,DYKSIKSI,DXETAKSI,DYETAKSI,&
DXETAETA,DYETAETA,G22JAKSI,G22JAETA,G11JAKSI,G11JAETA)
ALLOCATE(F(0:8,XDIM,YDIM),FTUR(0:4,XDIM,YDIM))
ALLOCATE(U(1:2,XDIM,YDIM),UKAR(1:2,XDIM,YDIM),H(XDIM,YDIM),&
VIS(XDIM,YDIM),VISE(XDIM,YDIM),KG(XDIM,YDIM),&
PROM1(XDIM,YDIM),PROM2(XDIM,YDIM))
ALLOCATE(F_D(0:8,XDIM,YDIM),U_D(1:2,XDIM,YDIM),UKAR_D(1:2,XDIM,YDIM),H_D(XDIM,YDIM),&
VIS_D(XDIM,YDIM),VISE_D(XDIM,YDIM),KHZM_D(XDIM,YDIM),JLL_D(8,XDIM,YDIM))
ALLOCATE(ZB_D(XDIM,YDIM),G11_D(XDIM,YDIM),G22_D(XDIM,YDIM),G12_D(XDIM,YDIM),JA_D(XDIM,YDIM),&
DJAKSI_D(XDIM,YDIM),DJAETA_D(XDIM,YDIM),&
DXKSI_D(XDIM,YDIM),DXETA_D(XDIM,YDIM),DYKSI_D(XDIM,YDIM),DYETA_D(XDIM,YDIM),&
G22JAKSI_D(1:2,XDIM,YDIM),G22JAETA_D(XDIM,YDIM),G11JAKSI_D(XDIM,YDIM),G11JAETA_D(1:2,XDIM,YDIM),&
DXKSIKSI_D(XDIM,YDIM),DYKSIKSI_D(XDIM,YDIM),DXETAKSI_D(XDIM,YDIM),&
DYETAKSI_D(XDIM,YDIM),DXETAETA_D(XDIM,YDIM),DYETAETA_D(XDIM,YDIM))
CALL ULAZ(DIMTP,DIMTIZP,ITZ,GRAN,QZ,IM,VIS,TEC)
U=0.0
VISE=0.0
UKAR=0.0
F=0.0
FTUR=0.0
KG=0.0
KT=DT
CALL INITIAL(U,UKAR,H,HIN,G11,G22,DXKSI,DXETA,DYKSI,DYETA,JA,ZB,GRAN,QZ,KKV,VIS,XDIM,YDIM)
CALL CSTRIMAGE(H,IMAGE,IMAGES,OPBND,EX,EY,DT,GRAN,HP,ITZ,KHZ,KHZM,IM,JLL,XDIM,YDIM)
CALL TRANSMATRIX(EX,EY,DT,MT,MINV,JA,H)
CALL EQUILIBRIUM_INIT(F,H,U,EX,EY,G11,G22,G12,JA,G,G22JAKSI,G11JAETA,VIS,VISE,KG,FTUR,UKAR,&
DXKSIKSI,DYKSIKSI,DXETAKSI,DYETAKSI,DXETAETA,DYETAETA,DT)
CALL CPU_TIME(TIME1)
TBLOCK=DIM3(16,16,1)
GRID=DIM3(CEILING(REAL(XDIM)/TBLOCK%X),CEILING(REAL(YDIM)/TBLOCK%Y),1)
VIS_D =VIS
VISE_D =VISE
KHZM_D =KHZM
JLL_D =JLL
MT_D =MT
MINV_D =MINV
G11_D =G11
G22_D =G22
G12_D =G12
JA_D =JA
DJAKSI_D =DJAKSI
DJAETA_D =DJAETA
DXKSI_D =DXKSI
DXETA_D =DXETA
DYKSI_D =DYKSI
DYETA_D =DYETA
G22JAKSI_D =G22JAKSI
G22JAETA_D =G22JAETA
G11JAKSI_D =G11JAKSI
G11JAETA_D =G11JAETA
DXKSIKSI_D =DXKSIKSI
DYKSIKSI_D =DYKSIKSI
DXETAKSI_D =DXETAKSI
DYETAKSI_D =DYETAKSI
DXETAETA_D =DXETAETA
DYETAETA_D =DYETAETA
ZB_D =ZB
DO TSTEP = 1,TMAX
F_D =F
H_D =H
U_D =U
UKAR_D =UKAR
CALL UNSTBCOND(U,UKAR,H,HIN,G11,G22,DXKSI,DXETA,DYKSI,DYETA,JA,ZB,GRAN,QZ,KKV,VIS,KT)
CALL EQUIL_FORCE_S_COLLIDE<<<GRID,TBLOCK>>>(F_D,U_D,H_D,UKAR_D,EX,EY,&
VIS_D,DT,G,MKH,KHZM_D,JLL_D,KKV,&
MT_D,MINV_D,TSTEP,XDIM,YDIM,TSX,TSY,&
SR2,SR3,SR5,SR7)
F =F_D
CALL STREAM(F,FTUR)
CALL INOUT_BOUND_MACROS(F,FTUR,H,U,IMAGES,JA,HIN,INP,OUTP,BCP,EX,EY,&
UKAR,KG,DXKSI,DXETA,DYKSI,DYETA,TSTEP,OPBND,DEL,DIMTIZP)
! ZAPIS REZULTATA U FORMATU TECPLOT APLIKACIJE U ZADATIM VREMENSKIM PRESECIMA
DO I=1,DIMTEC
PROM1=G22
PROM2=G11
IF (TSTEP.EQ.TEC(I)) CALL TECPLOT(XCOR,YCOR,U,UKAR,H,ZB,&
DXKSI,DXETA,DYKSI,DYETA,JA,G11,G12,G22,&
PROM1,PROM2,VIS,VISE,DIMTP,IMAGE,TSTEP)
ENDDO
!WRITE(,)
!WRITE(,) ‘KORAK=’,TSTEP
!WRITE(,)
10 ENDDO
DEALLOCATE(F_D,U_D,UKAR_D,H_D,VIS_D,VISE_D,KHZM_D,JLL_D,ZB_D,G11_D,G22_D,G12_D,JA_D,&
DJAKSI_D,DJAETA_D,DXKSI_D,DXETA_D,DYKSI_D,DYETA_D,&
G22JAKSI_D,G22JAETA_D,G11JAKSI_D,G11JAETA_D,DXKSIKSI_D,DYKSIKSI_D,DXETAKSI_D,&
DYETAKSI_D,DXETAETA_D,DYETAETA_D,F,U,UKAR,H,VIS,VISE,KHZM,JLL,ZB,G11,G22,G12,JA,&
DJAKSI,DJAETA,DXKSI,DXETA,DYKSI,DYETA,&
G22JAKSI,G22JAETA,G11JAKSI,G11JAETA,DXKSIKSI,DYKSIKSI,DXETAKSI,&
DYETAKSI,DXETAETA,DYETAETA)
WRITE(,)
WRITE(,)
WRITE(,) ‘SPEED=’,DBLE(TMAX) * (DBLE(XDIM * YDIM)) / TIMETOT ,‘cells per second’
WRITE(,)
PAUSE
ISTAT=CUDADEVICERESET()
END PROGRAM MAINLBGK
After running on the emulation mode, I get the following message :
error S0186 : Argument missing for formal argument threadidx
Thank you in advance.
Ljubomir
