Hi
I have some simple code which basically is just adding numbers. I run this code with the following:
dim3 dimBlock( 16, 8 );
dim3 dimGrid( 16, 16 );
This works fine, and returns the result in less than 1 second. If I increase the block dimension to 16x16, my Matlab simply waits with no CPU usage or memory usage, and I have to kill the thread through windows. Any reason why this would happen?
/Cheers
Henrik Andresen
I have found some new info as well.
This stall happens whenever I start a process with more than 155 threads. Changing the number of blocks also don’t do anything. The moment I execute a thread with 156 threads, my entire process stalls with no CPU usage whatsoever.
I compile using VC++ express 2008, Matlab 2010a and the latest CUDA. I link to the cudartemu.lib as well. I run on a windows 7 32-bit edition.
Would anybody have an idea of what is happening?
Is this the correct part of the forum, or should I post in another place.
Hmm… forums crashed on me. So just a double post
