Hi there,
I wonder if anyone has seen this error before and if so what was the cause of it. The code I’m porting seems to run fine on the GPU but when I changed to emulation mode in order to print an array it resulted in the program failing with a segmentation fault.
How can this be?
I’m quite puzzled as I would have thought that if it didn’t work on 1 thread it certainly wouldn’t work on several.
Any thoughts or wisdom welcome.
Cheers,
Crip_crop
