Hey,
I want to connect an 1-wire temperature sensor to the Xavier DK. How can I implement this?
@JerryChang
hello Ashja,
what’s the protocol of your 1-wire temperature sensor using?
please refer to Jetson GPIO for the python library to control it.
thanks
hey @JerryChang ,
Thanks for replying.Its a dsb18b20 sensor .Does the xavier support 1-w on any pin apart from UART ,I want to write code in C++ for its implmentation
hello Ashja,
you’ll need to enable these two configs, then the driver will get enabled.
for example, CONFIG_W1_SLAVE_THERM
and CONFIG_W1
please also check this similar topic, Topic 157114 as see-also.
thanks
thanks for replying, I did see this post but couldn’t replicate it .I tried the dtb example and was getting a compile error from dtc.also how do you enable the configs mentioned above?
hello Ashja,
it’s kernel configuration, please access public sources via https://developer.nvidia.com/embedded/linux-tegra.
please also check developer guide. Kernel Customization to build nvidia kernel image.
thanks
hey @JerryChang ,
thank you ,ill look into it. also regarding the DTB is there a syntax guide or a sample for it apart from this one:
/dts-v1/;
/plugin/;
overlay-name = "My Jetson Overlay";
compatible = "nvidia,p3449-0000-a02+p3448-0000-a02";
fragment@0 {
target-path = "/";
__overlay__ {
my-custom-property = "This Is My Overlay";
hello Ashja,
it’s Jetson-IO to choose the device tree overlay, please check Configuring the 40-Pin Expansion Header for reference,
FYI, in the next coming release (i.e. JetPack-4.6), it’ll show an example to demonstrate how to create and apply a DTB overlay file.
thanks
okay that would be great,whens the expected date for it?
please check this thread, JetPack 4.6 is currently scheduled for July 2021.
thanks
