I am trying to enable one or more of the I2C devices on the Jetson Xavier NX 40 pin header. I’ve been trying to do it using the jetson-io.py tool, but It is not obvious (to me at least) where to set the I2C configuration for the 40 pin header.
Also, I was expecting to have more than one I2C device available on the Dev kit. When I use the i2cdetect tool, it gives me bus/addr info only for i2c-0.
Is there a DTS file available that has the I2C configured on the 40 pin header?
The I2C pin was default enable as I2C function pins, don’t need configure by jetson-io.
Which pin do you connect to? The PIN 3/5 was i2c bus 8 PIN 27/28 was bus 1
