In the Linux host I go to the following directory: *$JETPACK_ROOT/Linux_for_Tegra/kernel/pinmux/t19x/
I paste the generated .dtsi files from the spreadsheet.
tegra19x-jetson_agx_xavier_devkit-gpio-default.dtsi
tegra19x-jetson_agx_xavier_devkit-padvoltage-default.dtsi
tegra19x-jetson_agx_xavier_devkit-pinmux.dtsi
Then I run the following command:
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt --mandatory_pinmux_file mandatory_pinmux.txt tegra19x-jetson_agx_devkit-pinmux.dtsi tegra19x-jetson_agx_devkit-gpio-default.dtsi 1.0 > tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
And got this result:
ERROR: pin dap1_sclk_ps0(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap1_fs_ps3(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_rd3_pf1(0x00022470) field nvidia,lpbk(0x00000020) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_sma_mdio_pf4(0x00022440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin sdmmc4_cmd(0x00002440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio10_pg6(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin soc_gpio13_ph1(0x00000411) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm2_px2(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm3_px3(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin uart2_tx_px4(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart2_rts_px6(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart5_tx_py5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart5_rts_py7(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_tx_pcc5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio22_pq2(0x00000459) field nvidia,pull(0x0000000c) is not matching, val = 0x02 expected = 0x00
ERROR: pin uart1_tx_pr2(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin dap4_sclk_pa4(0x0000c440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap4_fs_pa7(0x0000c440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin ufs0_ref_clk_pff0(0x00022420) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x01
ERROR: pin ufs0_rst_pff1(0x00022420) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
The config file (tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg.txt (30.4 KB)):
#### Pinmux for gpio-input pins ####
pinmux.0x0243d040 = 0x00000000; # GPIO spi1_sck_pz3
pinmux.0x0243d020 = 0x00000000; # GPIO spi1_miso_pz4
pinmux.0x0243d058 = 0x00000000; # GPIO spi1_mosi_pz5
pinmux.0x0243d010 = 0x00000000; # GPIO spi1_cs0_pz6
pinmux.0x0243d050 = 0x00000000; # GPIO spi1_cs1_pz7
#### Pinmux for used pins ####
pinmux.0x0243d040 = 0x00001055; # spi1_sck_pz3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d020 = 0x00001055; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d058 = 0x00001055; # spi1_mosi_pz5: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d010 = 0x00001059; # spi1_cs0_pz6: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d050 = 0x00001059; # spi1_cs1_pz7: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
Then I copy that config file to $JETPACK_ROOT/Linux_for_Tegra/bootloader/t186ref/BCT and flash the device.
