Will it be possible to libXNVCtrl.so building from the nvidia-settings tarball without patching the Makefile or calling gcc by hand?
I was about to open an “issue” on github for the official nvidia-settings repository but the button to open issues has been removed.
Something like a switch in the main Makefile that would trigger building the static library inside the main executable (like it is now) or building it with the shared object enabled and link to it. Something like this (installation part missing) where if the compilation sets XNVCTRL_LIB_STATIC to 0 the shared object is built and linked in nvidia-settings:
diff -Naur nvidia-settings-331.20.old/src/libXNVCtrl/Makefile nvidia-settings-331.20/src/libXNVCtrl/Makefile
--- nvidia-settings-331.20.old/src/libXNVCtrl/Makefile 2013-12-23 12:52:57.618242486 +0100
+++ nvidia-settings-331.20/src/libXNVCtrl/Makefile 2013-12-23 18:02:02.075963709 +0100
@@ -19,15 +19,31 @@
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
+VERSION_MK := $(wildcard $(OUTPUTDIR)/version.mk version.mk)
+include $(VERSION_MK)
+ifndef NVIDIA_VERSION
+$(error NVIDIA_VERSION undefined)
+endif
RANLIB ?= ranlib
CFLAGS += -fPIC
+all: libXNVCtrl.a libXNVCtrl.so
libXNVCtrl.a : libXNVCtrl.a(NVCtrl.o)
$(RANLIB) $@
+libXNVCtrl.so: NVCtrl.o
+ $(RM) $@ $@.*
+ $(CC) -shared -Wl,-soname=$@.0 -o $@.$(NVIDIA_VERSION) $(LDFLAGS) $^ -lXext -lX11
+ ln -s $@.$(NVIDIA_VERSION) $@.0
+ ln -s $@.0 $@
NVCtrl.o : NVCtrl.h nv_control.h NVCtrlLib.h
.INTERMEDIATE: NVCtrl.o
clean ::
rm -f libXNVCtrl.a *.o
+ rm -f libXNVCtrl.so libXNVCtrl.so.*
.PHONY: clean
diff -Naur nvidia-settings-331.20.old/src/libXNVCtrl/version.mk nvidia-settings-331.20/src/libXNVCtrl/version.mk
--- nvidia-settings-331.20.old/src/libXNVCtrl/version.mk 1970-01-01 01:00:00.000000000 +0100
+++ nvidia-settings-331.20/src/libXNVCtrl/version.mk 2013-12-23 17:52:31.223697586 +0100
@@ -0,0 +1 @@
+NVIDIA_VERSION = 331.20
diff -Naur nvidia-settings-331.20.old/src/Makefile nvidia-settings-331.20/src/Makefile
--- nvidia-settings-331.20.old/src/Makefile 2013-12-23 12:52:57.619242471 +0100
+++ nvidia-settings-331.20/src/Makefile 2013-12-23 18:04:34.371433858 +0100
@@ -79,6 +79,13 @@
XNVCTRL_DIR ?= libXNVCtrl
XNVCTRL_ARCHIVE ?= $(XNVCTRL_DIR)/libXNVCtrl.a
+XNVCTRL_SHARED ?= $(XNVCTRL_DIR)/libXNVCtrl.so.0
+ifeq ($(XNVCTRL_LIB_STATIC),0)
+ XNVCTRL_LIB ?= $(XNVCTRL_SHARED)
+endif
+XNVCTRL_LIB ?= $(XNVCTRL_ARCHIVE)
XCONFIG_PARSER_DIR ?= XF86Config-parser
COMMON_UTILS_DIR ?= common-utils
COMMON_UNIX_DIR ?= common-unix
@@ -179,9 +186,12 @@
$(MKDIR) $(BINDIR)
$(INSTALL) $(INSTALL_BIN_ARGS) $< $(BINDIR)/$(notdir $<)
-$(NVIDIA_SETTINGS): $(OBJS) $(XNVCTRL_ARCHIVE)
+$(XNVCTRL_ARCHIVE) $(XNVCTRL_SHARED):
+ $(MAKE) -C $(XNVCTRL_DIR)
+$(NVIDIA_SETTINGS): $(OBJS) $(XNVCTRL_LIB)
$(call quiet_cmd,LINK) $(CFLAGS) $(LDFLAGS) $(BIN_LDFLAGS) -o $@ $(OBJS) \
- $(XNVCTRL_ARCHIVE) $(LIBS)
+ $(XNVCTRL_LIB) $(LIBS)
$(call quiet_cmd,STRIP_CMD) $@
# define the rule to build each object file
@@ -191,6 +201,7 @@
$(eval $(call DEFINE_STAMP_C_RULE, $(OBJS),$(NVIDIA_SETTINGS_PROGRAM_NAME)))
clean clobber:
+ $(MAKE) -C $(XNVCTRL_DIR) clean
rm -rf $(NVIDIA_SETTINGS) *~ $(STAMP_C) \
$(OUTPUTDIR)/*.o $(OUTPUTDIR)/*.d
Thanks,
–Simone
